Nissan "Pure Electric Vehicle" needs refueling without charging? Annual capacity of 600,000 vehicles
- 2 replies
- 2,638 views
By Nancy Bitter
Programming instructions | Dorman replacement keyless entry remotes for GM vehicles
By Auto News
link hidden, please login to viewWith a majority of vehicle owners living in areas of the country that have stay-at-home orders, many vehicles may be sitting idle for days or weeks at a time. The non-profit Car Care Council recommends starting your car at least once a week and keeping up with routine auto care to help prevent potential maintenance issues. “Just as it is recommended that people stay active during this time of social distancing, your car should get some activity as well,” said Rich White, executive director, Car Care Council. “If your vehicle sits idle for too long, the battery could die, the tires can develop flat spots and the engine oil may start to deteriorate. Just a short solo drive once a week and a little car care will keep your car running efficiently and safely.”
link hidden, please login to view to order the Car Care Council’s free 80-page Car Care Guide. The post
Programming instructions | Dorman replacement keyless entry fobs and programmers for CDJR vehicles
