Rubber bushing knowledges
Economic factors may lead to a decline in new car sales in the United States in 2019
By 袁春凤 (Tiffany),
- car
- light vehicles
- (and 2 more)
- 2,058 views
Toyota's sales in China surpassed Honda's in 2018, with 1.47 million vehicles "left room"?
By 袁春凤 (Tiffany),
- toyota
- auto parts
- (and 1 more)
- 1 reply
- 1,675 views
- 1 reply
- 1,667 views
- 1,507 views
- 1 reply
- 1,834 views
OTC said each suspension bushing kit features Hendrickson rear suspensions, including Primaax EX, Comfort Air and FCCC V-Ride Pivot and D-Pin suspension bushings, and freightliner rear suspensions, including double and single-wrapped FAS II Airliner rear suspension bushings. Both also include centering adapters to align tool and bushing for clean installation. Both are available through OTC distribution partners and resellers.
By mfp2097
Having my Ford Fairlane repaired this weekend, and the shop has asked me to find a drag link bushing for them. Looked around the internet and the image provided is the best I’ve found. It’s for the left side control arm. Wondering if it is the correct part.
By Dionysis Kampouris
Hello,
Does anyone know where i can find the thermostat shown in the picture?
I already have a new one with the correct part number but this rubber is missing and it seems that is fixed on thermostat cannot be removed.
Thank you
By 袁春凤 (Tiffany)
Inspection rules for rubber parts for automobiles
1.rubber hardness
Test method of indentation hardness based on GBT531.1-2008 rubber pocket hardness tester
contents and requirements
Instruments and equipment: Shahr hardness tester (type A, D)
Environmental conditions: the laboratory temperature is 23 C + + 2 C, the relative humidity is 60%~70231
Test method: the specimen thickness is at least 6mm. If the thickness of the sample is less than 6 mm, it can be stacked with no more than 3 layers of smooth, parallel samples with each layer thickness not less than 2 mm. The specimen must have enough area to make the needle and specimen contact position at least 12mm from the edge.
Place the specimen on a solid plane, hold the hardness tester, press the pin at least mm from the edge of the specimen, press the pin smoothly on the specimen, and read it within 3 seconds after the full contact of the pin with the specimen.
Results: the hardness values were measured 5 times at different locations of 6mm, and the median was taken.
Feilong Jiangli will update the more inspection rules for automobile rubber parts
By 袁春凤 (Tiffany)
Rubber shock absorber for automobiles
With the development of social economy, the automobile industry at home and abroad is facing a period of rapid change, which is characterized by further improving the service life of the automobile under the premise of ensuring driving safety, riding comfort, high speed and luxury. Damping products are used to control the vibration and noise of automobiles and to improve their handling stability. They are generally placed in the engine frame, rod holder, suspension shaft lining, center bearing bracket, bump limiter and torsional vibration absorber to improve the safety and comfort of automobiles. Damping products can be divided into four categories: bracket type, shaft lining type, buffer type and damping type. The main requirements of damping, heat resistance and fatigue resistance are good. Automobile shock absorber rubber products include engine bearings, suspension components, rubber springs, rubber air springs and impact rubber protective parts. In recent years, in order to improve the safety, comfort and maneuverability of automobiles, the variety and quantity of shock absorber rubber products for automobiles are increasing as the number of shock absorber rubber products on a car has reached 50-60 pieces.
