MAHLE Motorsport has announced the availability of the company’s new 2023 Application Guide.
The 38-page application guide features all of the company’s high-performance PowerPak piston sets and Pro Series Race pistons and provides complete product information for seven new PowerPak sets in addition to multiple new rings, pins and rails.
A sample of the new PowerPak piston sets available for 2023 include the Ford Godzilla 7.3-liter PowerPak; SBC 22°/23° Flat Top Gasported PowerPak; Forged SBC 23° USRA-approved PowerPak with press-fit pins; SBC 22° ASCS 360 Sprint Dome gas ported with asymmetrical valve pockets; LS 5.3L (Gen 4) Flat Top drop-in forged replacement assembly compatible with LS1/2/6 style cathedral port heads; Big Block Mopar 440 Dish; and a BB Mopar 383/400 Flat Top and Ford 5.0-liter Modular Coyote (Gen 3) Direct Injected (2018+).
Also, new cast piston PowerPak sets are available for the Ford Powerstroke including a 6.0-liter piston set that also is offered with 0.100-inch deep valve pockets, and a Ford 6.4-liter Powerstroke available with 0.10-inch-deep valve pockets.
MAHLE Motorsport PowerPak piston sets provide engine builders with their best value based on a reputation of reliability, durability and added features, according to the company. Most PowerPak sets come complete with a high-performance ring set with pins and clips. Also, the pistons are dual coated with a phosphate dry lubricant to reduce friction and GRAFAL skirt coating to reduce drag and skirt fatigue.
The PowerPak sets featured in the guide include a broad selection of SBC, LS, BBC, SBF, Ford Modular PowerPaks and a growing list of Hemi, Powerstroke and Diesel PowerPak sets. MAHLE Motorsport also offers PowerPak sets for many imports and sport compacts including Mazda, Subaru, Nissan, Ford EcoBoost, BMW, Audi, VW and Toyota applications. The guide also includes a section on ring gap instructions with illustrations and samples based on the high-performance street, circle track/drag racing, turbo/supercharger, diesel turbocharged and more.
The new application guide is available to download now at
, or can be picked up at the 2022 PRI show at booth No. 1601.
      link hidden, please login to view link hidden, please login to view link hidden, please login to view announced the release of 181 new numbers for January/February 2025. The company said all units are in stock and ready to ship. The new parts include:
      30 Complete Strut Assemblies 11 Shock Absorber Assembly Kits 3 Heavy Duty Shock Absorbers 72 Suspension Struts 40 Shock Absorbers 25 Lift Supports
      link hidden, please login to viewsaid these new part numbers cover over 30 million vehicles currently on the road in the U.S. and Canada. They include models like the Audi A4, Chevrolet Cruze, Chevrolet Silverado, Dodge Charger, Ford Explorer, Nissan Pathfinder, Toyota Tacoma and more. The post
      Lucas Oil has announced the latest addition to its vehicle performance product lineup: Lucas Emissions Clear. The company said this fuel and exhaust system cleaner addresses the need for effective solutions to reduce vehicle emissions and improve catalytic converter performance, helping vehicle owners meet strict emissions regulations.
      In a news release announcing the product, the company explained that Lucas Emissions Clear Fuel and Exhaust System Cleaner targets the entire fuel delivery system, removing harmful deposits that contribute to excessive exhaust emissions. By reducing particulate matter before it reaches the catalytic converter, the product helps extend its lifespan, optimizes combustion and improves emissions catalyst effectiveness. Formulated for easy integration into routine vehicle maintenance or pre-emissions testing, Lucas Emissions Clear is a one-tank treatment that provides emissions control, promotes cleaner air quality and is compatible with any gasoline engine, the company said.
      “A cleaner engine means a more efficient, more reliable car, and Lucas Emissions Clear delivers exactly that for drivers,” said
      link hidden, please login to view CEO Morgan Lucas. “We take pride in helping our customers save money on repairs and maintenance. Cleaner emissions not only contribute to a healthier environment, but also extend the lifespan of exhaust systems, providing long-term financial benefits for drivers and helping to meet more stringent regulations. With this product, we are making it easier and more affordable to maintain optimal performance and compliance with emissions standards.” Designed for environmentally conscious vehicle owners, fleet managers, automotive enthusiasts and drivers seeking improved fuel efficiency and performance, Lucas Oil said its Emissions Clear can cut harmful pollutants by up to 90% while delivering up to 5% improvement in fuel economy.
      Each
      For more information, visit
