Now part of the Rislone Hy-per premium performance-chemical family, Rislone Hy-per Cool Radiator Cleaner & Super Flush (p/n HFL400) is formulated to remove damaging coolant deposits that build up over time and cause engine overheating.
It also neutralizes acids and helps prevent the formation of scale deposits for longer system life. Its Heavy Duty Xtreme Clean formula cleans the entire cooling system, removing solder bloom, oily residue, rust and scale.
“One of the unique elements of Rislone Hy-per Cool Radiator Cleaner & Super Flush is that it includes a water pump lubricant and inhibitors that protect the water pump during cleaning,” explains Clayton Parks, vice president of strategic development for Rislone. “This helps prevent other coolant-related issues from developing due to the flushing process.”
Rislone Hy-per Cool Radiator Cleaner & Super Flush is fast, easy and safe to use in all cooling systems. It removes deposits and coolant gel for a complete cleaning in about 30 minutes. Another benefit: Clean systems run cooler. Customers can use Super Flush every time coolant is changed, whether for light system flushing or heavy-duty cleaning. Rislone recommends treating systems of up to 16 quarts with one 16-ounce (473-millileter) bottle.
For best results, add a bottle of Rislone Hy-per Cool Super Coolant when refilling the system to deliver optimal heat transfer performance.
Like all Rislone Hy-per products, Radiator Cleaner & Super Flush is made in the U.S.A. For a limited time, get a $5 mail-in rebate with every purchase of Rislone Hy-per Cool Radiator Cleaner. Visit
 to learn more.
Check out Rislone Hy-per Cool Radiator Cleaner & Super Flush, as well as the full Rislone lineup, in booth 3616 at AAPEX, Nov. 1-3, 2022 at the Venetian Expo in Las Vegas.
    • By Mighty Auto Parts
      Cool vs. correct: JDM window glass
      Rislone announced its new
      link hidden, please login to view (p/n 4400), which it said improves oil performance to eliminate dry starts, reduce friction and wear, prevent oil breakdown and extend engine life. “Its concentrated formula delivers legendary Rislone Hy-per Lube performance in a compact, easy-to-use, and shelf-friendly bottle,” the company added. Hy-per Lube Engine Supplement is a premium additive blend formulated to work with all motor oils, including conventional, high-mileage, and synthetic, to make older, high-mileage, and high-performance engines run better and last longer than they would with oil alone, according to
      link hidden, please login to view. It’s also suitable for use in manual transmissions, differentials and axles. Rislone said it previously offered the supplement in a one-quart bottle, making it easy to swap a quart of oil for a quart of Hy-per Lube at every oil change. Now that most consumers buy oil in larger jugs, Rislone added it took the opportunity to reduce the package size — and the price. Concentrating the formula enabled Rislone to package it in a 16.9 oz. bottle without diluting performance. The smaller bottle also reduces packaging waste and storage space.
      “Adding Hy-per Lube Engine Supplement to petroleum or synthetic oils turns them into hyper-performance lubricants that deliver heavy-duty protection for all driving demands across a wide range of engine and vehicle types,” said Clay Parks, Rislone vice president of development. “In these days of high prices, we’re proud to have found a way to lower ours. Our concentrated formula saves consumers money at the counter and in years to come by helping their engines last longer.”
      Before selling a vehicle, make sure to remove personal data from the infotainment system
