KAVY Supply OE Quality Ignition Coil
We all experience supply chain issues now and then. Back-ordered parts, delayed shipments and even material shortages can affect our ability to provide the parts and services our customers have come to expect from us. Our collective experience during COVID highlights just how interconnected we are with each link in our supply chain. As wholesalers/retailers, we maintain a particular stocking inventory of parts, supplies and accessories based on the needs of our customer base.
As manufacturers, our vendors also maintain inventories of the raw materials, components and subassemblies that go into creating the products that we sell each day in finished form. Any hiccup in their production process can snowball into a shortage or delay if an alternate solution cannot be found in time. The semiconductor “chip shortage” of 2021-’22 effectively crippled the auto industry, preventing some 12 million vehicles from being completed on schedule. In this example, there were no alternative parts available to fill the demand for specialized semiconductors.
In the manufacturing world, alternative parts are a way for a supplier to meet production schedules and keep an assembly line moving along uninterrupted. If a previously sourced component becomes obsolete or otherwise unavailable, another vendor or supplier might be contracted to fill the order. If a raw material is out of stock, another material with similar properties might be substituted in its place. For those of us behind the counter, sourcing alternative parts is what we do best. Our parts and supplies are already an alternative to the OEM components they are designed to replace, so what happens when our own alternative parts are backordered, delayed or otherwise unavailable?
Our first instinct, in most cases, is to outsource the part from another supplier, or even a competitor. We are lucky to have a great diversity of options in most aftermarket categories, so if our preferred solution isn’t available, there’s a good chance that an alternative is out there… somewhere.
For obsolete, discontinued or otherwise hard-to-find parts, the search often leads us to specialists in NOS (new old stock) or reproduction parts, or even the used market. Just as we have come to know which of our vendors offers a particular product, it is also in our best interest to know where to obtain those things that we don’t have ready access to. When it comes to finding needles in haystacks, your networking skills can be just as important as your catalog proficiency. Over the years, I’ve built up a mental index of industry contacts, former coworkers and clients, and general “know-it-alls” whom I can turn to for help when I’ve hit a dead end. Sometimes another set of eyes on a problem is all it takes to see the answer!
We can’t possibly fulfill every customer request, but even when an elusive part isn’t available to us, we are still uniquely positioned to suggest alternatives. As customers, we all hate to be told “no,” but we can better accept that moment of disappointment if the person across the counter from us cares enough about our needs to point us in the right direction. Be that person.
When it comes to keeping your vehicle running smoothly and efficiently, investing in the right auto parts is crucial. Whether you're a car enthusiast, a professional mechanic, or simply a vehicle owner who takes pride in proper maintenance, the quality of your parts can make all the difference. At Clifford Auto Parts, we understand the importance of using high-quality automotive components, and that's why we're committed to providing the best products and services to our customers.
The Importance of Using High-Quality Auto Parts
Imagine this: You're driving down the highway, and suddenly your car begins to sputter and lose power. More often than not, this is caused by failing or low-quality parts that just couldn't handle the wear and tear. By choosing high-quality, durable parts, you’re not just maintaining your vehicle; you’re investing in its performance and longevity.
Here’s why using premium auto parts is essential:
✓ Improved Fuel Efficiency: High-quality Engine Control Modules (ECMs) and Powertrain Control Modules (PCMs) ensure that your engine operates at optimal levels, helping to maintain fuel efficiency and reduce emissions.
✓ Extended Vehicle Lifespan: Investing in quality parts reduces the risk of sudden breakdowns and costly repairs. Regularly replacing worn-out components with durable ones can extend the life of your vehicle.
✓ Enhanced Safety: Faulty parts can compromise the safety of your vehicle. By using reliable components from trusted suppliers like Clifford Auto Parts, you ensure your car remains safe on the road.
Why Choose Clifford Auto Parts?
At Clifford Auto Parts, we specialize in providing a wide range of automotive components, including:
Engine Control Modules (ECMs) Powertrain Control Modules (PCMs) Transmission Control Modules (TCMs) We cater to major brands like Chevrolet, Dodge, Ford, GMC, and Chrysler, and many more. ensuring that you get the exact parts you need for your vehicle. Here’s what sets us apart:
1. Uncompromised Quality
We understand that your vehicle deserves the best. All of our parts are rigorously tested to meet or exceed OEM standards. When you purchase from Clifford Auto Parts, you’re not just buying a product; you’re investing in quality that you can trust.
2. Fast & Free Shipping Across the U.S.
We know how important it is to get your car back on the road quickly. That’s why we offer fast, reliable shipping throughout the United States, free of charge. Order today, and we’ll have your parts at your doorstep in no time.
3. Lifetime Warranty on All Parts
We stand behind the quality of our products, which is why we offer a lifetime warranty on all parts. If something goes wrong, we’ve got you covered.
4. Dedicated Customer Support
Not sure which part you need? Our experienced team is here to assist you. Whether you have questions about compatibility or need help troubleshooting an issue, we’re just a call away.
Top-Selling Products at Clifford Auto Parts
Here’s a look at some of our best-selling products:
🚗 Chevrolet Engine Control Modules (ECM)
Ensure your Chevy runs smoothly with our top-rated ECMs, designed to optimize engine performance and fuel efficiency.
🚚 Dodge Powertrain Control Modules (PCM)
Experience smooth gear shifts and improved performance with our Dodge PCMs, specifically designed to enhance the driving experience.
🚙 Ford Transmission Control Modules (TCM)
Our Ford TCMs are engineered to provide precise control over your vehicle’s transmission, ensuring reliability and longevity.
Customer Testimonials
"Clifford Auto Parts has been a game-changer for me. The lifetime warranty and free shipping made it an easy decision to choose them over other suppliers. My car's performance has never been better!" – David S., New York
"I was impressed by the fast shipping and the quality of the parts I received. The customer support team was very helpful in guiding me to the right ECM for my Dodge Ram." – Sarah P., California
Join the Clifford Auto Parts Community
Are you tired of dealing with subpar auto parts that leave you stranded on the side of the road? It's time to make the switch to Clifford Auto Parts. Our parts are designed to keep your vehicle performing at its best, ensuring you get the most out of every drive.
Visit our website today at
link hidden, please login to view to browse our full range of automotive components.
Engage with Us We’re always here to help and love connecting with automotive enthusiasts. If you have any questions or need advice on choosing the right parts for your vehicle, don’t hesitate to reach out to us. Let's keep your car running smoothly!
🔧 Clifford Auto Parts – Driving quality, performance, and satisfaction.
NexaMotion Group (NMG) announced the acquisition of
link hidden, please login to view, NexaMotion’s third acquisition of the year. The company has a total of three wholesale distributor locations: two in San Francisco, CA, and one in Honolulu, HI. City Auto Supply was represented by Schwartz Advisors, and the terms were not disclosed. City Auto Supply is a U.S. veteran-owned corporation founded in the San Francisco Bay Area in 1986. The company carries over 100,000 individual parts and is a leading distributor of automotive parts and supplies to the auto repair industry, the company said.
“An organization like
link hidden, please login to view is a great partner for City Auto Supply customers and team members. Our business is strategically aligned with NexaMotion Group and its leaders, and most importantly, we share the same values,” City Auto Supply Owner Larry Chew said. “NexaMotion Group and its subsidiaries are known for providing top-quality parts and exceptional service in the aftermarket industry.” “This marks our fifth acquisition in the general repair space over the past 18 months, and we’re just getting started,” Neil Sethi, president and CEO of
link hidden, please login to view, said. “Our mission has always been to simplify complex vehicle repair, and with each acquisition, we strengthen our ability to serve customers more effectively. We’re eager for what the future holds as we continue to expand and innovate.” The post
