It’s no secret that the heart of an electric vehicle is its high-voltage (HV) battery.
There are a number of electrical circuits and protection devices found within an HV battery assembly. These circuits work in conjunction with the vehicle’s battery-management system (BMS) to ensure safety and battery longevity.
It’s not uncommon to have several hundred lithium cells in an EV and more than 25 cells in a hybrid vehicle. These cells must be properly balanced to one another, while their temperature and the packs’ overall voltage and amperage must be closely monitored by the BMS.
Often, when a battery has been properly tested and is found to be bad, a remanufactured battery may be the best option due to the price.
Typically, remanufactured batteries include a number of improvements, such as nickel-plated terminals (to avoid corrosion); optimized cell mounting to eliminate the risk of case cracking due to vibrations; individual cell testing and balancing of the pack; and other comprehensive testing to ensure long life.
For example, Dorman’s remanufactured hybrid battery pack for the 2004-2009 Toyota Prius features “nickel-plated bus bars and corrosion-resistant terminals for increased reliability,” according to the Dorman website, while “proprietary software uses [a] multi-dimensional grading process to select battery cells that will perform ideally together.” The battery packs are subjected to “multiple stringent validation gateways, including on-vehicle tests using EPA performance standards,” according to the company.
Remanufactured batteries should be an attractive option for your customers – especially those who own hybrid vehicles, as they’re likely seeking a cost-effective solution. Dorman’s remanufactured hybrid battery packs come with a two-year warranty, according to a recent sales flyer, compared to the eight- to 10-year warranty for most OE batteries. Generally speaking, however, remanufactured batteries should have the same life expectancy as a new one.
It’s important to note that when a remanufactured battery is sent to the warehouse, there’s an expiration tag applied to the outside of the shipping container. Make sure you’re not installing a battery that’s due to return to the manufacturer to receive an updated charge and testing procedure.
A word about handling HV batteries, whether they’re new or remanufactured: These batteries are heavy! They’re packaged in clamshell cases to minimize the risk of electrical shock. Because of their weight, HV batteries should be stored low to the ground, and counter pros (and customers) should take great care when lifting them, to avoid injury.
Let’s discuss a few add-on sales opportunities. I firmly believe that all shops working on electric vehicles need high-voltage gloves, insulated handtool sets and a Level 2 charger. Remember, all EVs use electrons the entire time they’re in a shop – as opposed to ICE vehicles, which only use gasoline when the engine is running.
Advanced diagnostic tools represent another great sales opportunity. When it comes to diagnosing EVs and their batteries, the current level of diagnostics only allows a technician to see what’s transmitted over the data bus lines of communication. This is because a traditional diagnostic scan tool gets its information from the OBD II connector located under the dash. Autel has addressed this challenge with its MaxiSYS MS909EV platform.
With the MaxiSys MS909EV system, technicians can analyze an EV battery by plugging into the OBD II port or connecting directly to the battery. By connecting to the BMS, technicians now have full insight into battery state of health and individual battery-cell state of charge; access to all the thermistors; and visibility into the “handshake” that occurs between a charger and the vehicle. The MS909EV screen displays detailed graphics and in-depth connection guidance to provide safe and secure testing, as well as comprehensive diagrams of high-voltage system blocks, components and sockets. In addition to providing rapid analysis of high-voltage systems in electric and hybrid vehicles, the MS909EV’s intelligent diagnostic capabilities extend to U.S., European and Asian gasoline and diesel vehicles.
      Bosch Mobility Aftermarket announced the re-launch of its passenger car and light duty truck battery offering, now known as the Bosch Premium Battery Program. The company said this revitalized program embraces a new name emphasizing its exclusive focus on premium batteries and includes new stock-keeping units (SKUs) for the Bosch S5 Premium Power Flooded Batteries and the Bosch S6 High Performance AGM Batteries.
      “This emphasized focus on premium batteries, with 90% market coverage, guarantees shop owners and end-users alike will confront less complexity in our battery line, while enjoying greater inventory efficiency,” said Dennis Krob, senior product manager at
      link hidden, please login to view. “We’ve been listening to customers and understand these two areas are critically important in today’s market. We’re proud to be refreshing our offerings at a premium level to meet these demands, while helping drive business and streamline operations.”
      link hidden, please login to view said it will expand its portfolio of S5 Premium Power Flooded Batteries by 13 new SKUs. These batteries boast a three-year warranty and provide dependable starting power, a long service life and reduced risk of acid leakage in newer car models with high electronic demand. The new program also includes three new SKUs for the Bosch S6 High Performance AGM Batteries. According to the company, these batteries promise a lifespan up to two times longer than conventional alternatives and provide consistent, optimal power for start-stop vehicles and models that use regenerative braking. The S6 batteries offer a warranty guaranteeing free replacement for four years after the date of purchase.
      Electric Pump vs Air Compressor Vertical Shop Press Promo Video
      Plews & Edelmann will showcase its Edelmann Electric Power Steering (EPS) repair program through live demonstrations at the Automotive Aftermarket Products Expo (AAPEX), Nov. 5–7 in Las Vegas, at the Live Product Demo Area, Level 1 – Booth J8233. The company said the demonstrations will feature a complete belt replacement on an EPS rack and pinion unit using the Edelmann drive belt replacement kits and proprietary chamfer ring removal tools. Each 40-minute demonstration will highlight how shops can save over 50% compared to full rack replacement costs while eliminating the need for specialized equipment, the company added.
      “We are excited to demonstrate how our EPS repair solutions are transforming the automotive aftermarket,” said Dennis Mullen, ASE-certified automobile technician and parts specialist and regional sales manager at
      link hidden, please login to view. “These demonstrations will show service repair professionals firsthand how they can offer cost-effective EPS repairs without the need for expensive programming or alignment, especially crucial now when replacement racks are increasingly scarce or unavailable.” Demonstration Schedule:
      Tuesday, Nov. 5: 11 a.m., 12 p.m., and 3 p.m. Wednesday, Nov. 6: 11 a.m., 12 p.m., and 3 p.m. Thursday, Nov. 7: 11 a.m., 12 p.m., and 3 p.m. To add additional value to the demonstrations,
      link hidden, please login to view said it will give away one Chamfer Ring Spanner Wrench kit each day of the show to lucky attendees who have their badges scanned at the demo booth. After viewing the demonstrations, the company encourages attendees to visit the main Plews & Edelmann booth (A4245) to learn more about the complete EPS repair program, including belt replacement kits, couplings and specialized tools, as well as discuss distribution opportunities.
      “This comprehensive EPS repair program represents a significant advancement in steering system repair,” added Mullen. “We’re providing the automotive aftermarket with solutions that make previously unavailable repairs both accessible and profitable.”
      Advanced low-voltage battery solutions provider
      link hidden, please login to view, announced a strategic investment in Altris, a pioneer in sustainable sodium-ion battery technology, with the aim of manufacturing low-voltage, sodium-ion (Na-ion) batteries for the automotive sector.
      link hidden, please login to view expects its investment to initially enable Altris to finalize and start pilot production of Na-ion automotive batteries, followed by commercial production beginning in 2026. This equity stake builds on a joint development agreement (JDA) between Clarios, producer of one in three of the world’s low-voltage car batteries, and Altris, a leader in sodium-ion cathode material and battery cell technology, focused on low-voltage Na-ion batteries, according to a news release announcing the strategic investment.
      Clarios said it will leverage its expertise in Battery Management Systems (BMS), software and system integration to design the Na-ion low-voltage automotive battery system to optimize battery performance.
      Altris, on the other hand, will focus on developing the sodium-ion cell technology for this low-voltage application. Every vehicle, including hybrid electric and fully electric vehicles, requires a low-voltage energy source to power an increased number of software-based functions such as steer-by-wire, break-by-wire, autonomous functions, and enhanced in cabin experiences.
      The Clarios low-voltage system architecture, comprising multiple networks and battery power sources, is essential for powering critical safety features and ensuring redundancy in vehicle electrical systems, the company said. Sodium-ion batteries are well suited to meet these increased power demands. At the same time, they are inherently sustainable and easy to recycle.
      “A sodium-ion battery solution perfectly complements our chemistry-agnostic portfolio, neatly dovetailing with lithium-ion and lead-acid options to capture the best attributes of both: high performance and lower cost,” said Federico Morales-Zimmermann vice president and general manager, global OEM customers and technology at Clarios. “A sodium-ion battery system provides agility for automakers seeking options in meeting intensifying low-voltage demands created by advanced vehicle technologies.”
      The materials used to produce sodium-ion cells – salt, wood, iron and those found in air – are abundant globally and are free from harmful chemicals or minerals mined in conflict zones. Developing Na-ion batteries for vehicles would represent an important advancement in automotive battery technology, while advancing the auto industry’s circularity goals, Clarios said.
