If there’s one thing that I know about myself it’s this: I can’t help but modify any vehicles I own. It’s not that I’m unhappy with the vehicles I buy. It’s just that in my eyes, there’s always room for improvement.
Almost without fail, the first thing I’ll upgrade is lighting. In my opinion, halogen headlights shouldn’t still be around in 2022. Nighttime visibility is often overlooked, but it’s critical to occupant safety. The more your headlights can light up the road ahead, the more likely you’ll be able to see obstacles in your path.
Goodbye HID, Hello LED!
High-intensity discharge (HID) lighting, also known as xenon, was mostly seen in luxury vehicles, but it has started to trickle down into other makes and models over the years. HID bulbs are efficient, produce a high-quality light pattern and can be up to 300% brighter than traditional halogen bulbs.
HID bulbs work by igniting an electrical discharge inside a gas chamber.
There’s no filament inside an HID bulb, so they should last longer than a halogen bulb. But they’re not without a few downsides. They’re not cheap; they require ballasts to stabilize the electrical discharge; they can be difficult to diagnose if a bulb stops working; and they lose performance as they age, becoming dimmer
over time.
So, what’s the alternative? Light-emitting diode (LED) lighting has surged in popularity in the past few years, both in OE vehicles and the aftermarket. LEDs are an easy upgrade over halogen and HID lighting systems. They consist of two electrodes (an anode and a cathode). Light is produced when an electrical current passes through the semiconductive materials inside (silicon or selenium).
LED Advantages
LEDs are extremely energy-efficient, requiring significantly less energy than halogen or HID bulbs. The next major advantage would be the sheer variety that can be found in aftermarket LED lighting. Whether you’re looking for LEDs to install in place of halogen bulbs, complete headlight housings with integrated-LED beams or standalone LED housings for off-road visibility, the possibilities seem to be limitless!
But in my eyes, their biggest advantage is in their service life. LEDs can offer an extremely long lifespan, so they won’t need to be replaced nearly as often. This can be especially beneficial in applications where the headlight bulbs are very difficult to reach. My 1998 Mercedes E320 was TERRIBLE to work on, especially when I needed to replace bulbs. And let’s face it: Engine bays aren’t getting any more spacious these days, and modern vehicles aren’t getting any easier to work on.
LED Disadvantages
If you’re looking at replacement LED bulbs, oftentimes they’re not exactly what I would call “compact.” In many cases, you’ll find big, bulky cooling fans built into the back side of the bulb, and these can be difficult to install inside of some headlight housings without interfering with the wiring or protective cap.
The other downside would be their cost. The upfront costs tend to be more than the alternatives, but LEDs can offer a better return on that investment thanks to their superior service life.
You also might find that the LEDs simply don’t seem to perform very well in your factory-equipped headlight housings. This is due to design. The reflector and lens inside the headlight assembly were designed to work with halogen bulbs, not an LED. This can increase the headlight glare to oncoming traffic, and reduce the overall lighting performance.
This leads us to the final and maybe the most significant disadvantage on our list: their questionable legality. That’s right, it’s technically illegal to install HID or LED lighting inside your factory headlight housing.
Are They Really Illegal?
Here in the United States, the Federal Motor Vehicle Safety Standards (FMVSS) are used to regulate the design, construction, performance and durability requirements for motor vehicles on our roads. These regulations specify that your main forward illumination (a.k.a. headlights) must remain as they were fitted from the factory.
So, if your vehicle had halogen headlights when it was new, technically it’s illegal to upgrade to LED or HID. However, they can be used in any of the unregulated auxiliary lights including fog lights, side markers, brake lights and so on.
There also is a chance that your local, county or state government may consider these modifications to be illegal. For instance, here in Ohio we are permitted no more than five front-facing lights, and no high-intensity beam may strike the roadway 75 feet from the vehicle. Off-road lighting bars may not be illuminated on public roads in Kentucky, Montana, North Carolina and Wyoming, just to name a few.
Our advice would be this: Avoid making any changes to the factory headlights. If your customers install off-road lighting, they should only use it off-road. If they want to upgrade their interior bulbs with brighter, whiter LEDs, more power to them. As a counter professional, make sure you’re familiar with the local ordinances and regulations regarding LED lighting, and use your best judgment.
    • By lolly
      We have a professional team of engineers to provide you with customized LED car light module design and development services. Please see the attached is the LED car light module we produced for our customers. Please check our website for more LED modules for other models www.doulux.com. Or you can email me at [email protected].
      link hidden, please login to view introduced a new light to the link hidden, please login to view Xperion 3000 LED Work Light product lineup. The Xperion 3000 Under Bonnet LED light is designed to provide excellent visibility for auto service pros and DIYers while working in the engine bay, the company said. Featuring a selectable light output of 1,200, 600, or 300 lumens, the Xperion 3000 Under Bonnet light easily illuminates the entire working area, allowing for more precise and accurate work.
      To help improve efficiency while working, Lumileds said the Xperion 3000 Under Bonnet light can be mounted to any location under the vehicle hood, utilizing either the integrated magnet in the base of the light or one of two fold-out hooks. The light features two adjustable LED lightbars that pivot and tilt, to direct the light exactly where it is required.
      “We originally designed our Xperion 6000 LED work light line with automotive professionals in mind,” notes Jason Dreger, Lumileds product manager for aftermarket accessories. “We created the Xperion 3000 LED work light line to give DIYers a more affordable option, but we’ve seen that pros appreciate the quality, performance, and value of the Xperion 3000 line as well. The Xperion 3000 Under Bonnet light is maneuverable, adjustable, and provides incredible light for as long as the job takes. The multiple hands-free operation choices let you concentrate on the job at hand without needing to constantly reposition your light.”
      Continental announced that the NightViu premium line of professional driving and working lights will be made available to consumer markets, including off-road enthusiasts, recreational vehicles (RVs) and marine.
      Originally designed for use on construction, mining and off-highway equipment, “the NightViu lighting line provides a level of rugged design, durability and performance not normally seen in consumer-lighting products,” according to Continental.
      Built to withstand extreme temperatures, vibration, dust and moisture, NightViu lights feature advanced LED technology that provides excellent lighting performance and exceptional energy efficiency, according to the company.
      NightViu driving lights provide a focused beam of light for long-distance illumination. They’re ideal for applications such as desert/rally racing or any activity where maximum beam distance is required, Continental noted.
      NightViu working lights provide beams that are shorter but wider. This makes them suitable for applications such as rock crawling, lighting up pickup beds and sport fishing boats.
      “The NightViu line was created for some of the toughest applications you can imagine including mining, construction and agriculture,” said Edwin Betancourt Jr., product manager, Continental. “Some might consider them over-engineered for consumer applications, but we believe there are folks out there who simply want the best they can get for their lighting. That’s why we’ve decided to make NightViu available for off-road enthusiasts, RV owners, and others who want a professional level light source for their off-road activities. These lights can be used for ATVs, UTVs and SUVs, as well as Jeeps, snowmobiles, work trucks and even riding lawnmowers and go-karts. The build quality and housing seals make them suitable for marine applications as well including blue-water cruising and fishing.”
      NightViu working lights are available in a choice of ultra-wide, wide, flood and spot beam patterns.
      Each of the beam patterns is offered in a choice of 1,500, 2,500, 3,500 and 4,500 lumen performance for a total of 16 lights in the NightViu range of working lights.
      NightViu driving lights are available in a variety of designs and configurations including five light bars, three multifunctional lights and two reversing lights. They provide up to 5,500 lumens and a beam field length of up to 440 meters. The lights feature free-form curved reflectors that direct the light beam exactly where it’s needed.
      NightViu Lights are built to withstand temperatures ranging from minus 40 F to 194 F and are rated IP68 for ingress protection (IP) from dust and water. They produce approximately 100 lumens per watt and have been designed to ensure that they do not create electrical interference that could affect the vehicles existing electronics.
    • By Buy Auto Spare Part
      Upgrade the look and performance of your BMW E46 M3 with
      link hidden, please login to view high-quality LED tail lights. Designed specifically for the E46 M3 model, these tail lights combine style and functionality to enhance your driving experience. Featuring advanced LED technology, these tail lights offer brighter and more noticeable illumination compared to traditional halogen lights. This not only improves your visibility on the road but also
      link hidden, please login to view a modern and sleek look to your vehicle. Looking for top-quality spare parts at budget-friendly prices? Look no further! We offer a wide selection of well-conditioned spare parts from the best dealers, available for
      link hidden, please login to view. With our professional service, you can trust that you're getting the best value for your money. link hidden, please login to view
      For more info
      Contact:+1 (405) 283 2648
      Email: [email protected]
      [email protected]
      Continental has introduced 10 new professional-quality driving lights as part of the company’s NightViu line.
      The new lights have been designed to help improve operational safety by dramatically increasing nighttime visibility.
      Engineered for use in agriculture, construction and mining, the new NightViu driving lights also are suitable for marine and powersports applications. They feature rugged aluminum diecast housings with cataphoretic coating, and resilient shatterproof polycarbonate lenses. Depending on the model, they are rated IP69K or IP67K for ingress protection (IP) from dust and water, according to the company.
      NightViu multi-function driving lights and lightbars feature free-form reflectors that direct the light beam exactly where it’s needed. NightViu reversing lights feature Fresnel lenses to create a broad field of illumination directly behind the equipment. NightViu driving lights provide up to 5,500 lumens and a beam field length of up to 440 meters.
      NightViu driving lights feature an integrated electronics driver and thermal management system to allow them to operate safely from minus 40 F to 190 F. They produce from 50 to 100 lumens per watt, depending on the model, and have been designed to ensure that they do not create electrical interference that could affect the vehicle’s existing electronics.
      “Our new NightViu driving lights provide the illumination that operators need for maximum nighttime safety,” said Edwin Betancourt Jr., product manager, Continental. “With three styles and a choice of configurations, they offer the right light for just about every application.”
