Rislone has introduced new High Mileage Power Steering Stop Whine with Leak Repair (P/N 4604), describing it as “a quick and dependable solution for customers suffering steering ‘whine,’ sluggish steering or a power-steering system leak in their high-mileage cars, SUVs and light trucks.”
Power-steering problems are common in older vehicles, especially those clocking 75,000 miles or more. Noise and whining, minor leaks and hard-steering complaints can dull your customers’ driving enjoyment and, if ignored, only get worse over time.
“High Mileage Power Steering Stop Whine with Leak Repair can cost-effectively and quickly solve a range of power-steering issues,” said Clay Parks, Rislone vice president of strategic development. “It’s an affordable solution to noisy power-steering systems that generally occur when the system is low on fluid, there is air trapped in the fluid or the vehicle has some mechanical issues.”
The all-new product contains a special blend of viscosity improvers, anti-wear friction modifiers and extreme-pressure performance additives, according to the company. It’s formulated to stop bearing, piston and valve noises inside the power-steering pump. Special lubricity additives smooth out rough, hard and tight steering and reduce friction. Stop-leak additives repair minor leaks and help prevent new ones.
Customers can use the product to top off existing fluid when low or add a bottle as a preventive-maintenance measure whenever power steering fluid is changed. It’s compatible with all types of domestic and imported power-steering fluids, including petroleum and synthetic formulas, and works with systems that use ATF automatic-transmission fluid.
Most passenger cars and light trucks require one 11.8-ounce (350-millileter) bottle for every 1 to 3 quarts of power-steering fluid. In smaller systems (those under a quart of capacity), use half a bottle. Depending on the power-steering problem, results will either be immediate or noticeable within a few days of driving, according to the company. A second application may be needed for hard-to-stop leaks or to solve other system issues.
Rislone High Mileage Power Steering Stop Whine with Leak Repair is a sister product to Rislone High Mileage Transmission Stop Slip with Leak Repair (P/N 4502) for automatic and manual transmissions.
For more information, visit
      Don’t forget to break in new catalytic converters
      Valvoline announced the launch of its new passenger car motor oil formulas for both the U.S. and Canada. The company said these formulas surpass the updated International Lubricant Standardization and Approval Committee (ILSAC) GF-7 standards, which formally went into effect on March 31.
      Valvoline added that its current ILSAC GF-6 certified synthetic
      link hidden, please login to view motor oils already meet all requirements of the new ILSAC GF-7 specification. The company said its engine lab in Ashland, Ky. allows Valvoline to perform critical engine sequence tests that help define industrywide performance requirements every five to seven years. “These days, everything seems to move just a little bit faster, and our engines have to work even harder to keep up with the pace of our busy lives,” said Dr. Michael Warholic, senior global technology director at Valvoline Global Operations. “By helping car owners maintain their vehicles’ performance and longevity, Valvoline’s dedication to the development of the ILSAC GF-7 standards is protecting engines not just for today, but for the needs of tomorrow as well, delivering improved performance levels in almost every area.”
      link hidden, please login to view said its ILSAC GF-7 full synthetic technology was tested in a single engine for over 500,000 miles across three years without the need to replace any critical component, while significantly reducing sludge and deposits compared to an ILSAC GF-6 quality oil. The ILSAC GF-7 specification continues the A and B designations started with the ILSAC GF-6 upgrade in 2020. The ILSAC GF-7A designation applies to all SAE 0W-20 viscosity grades and heavier. ILSAC GF-7A is backward compatible with all previous GF-6A, GF-5 and older ILSAC specifications. The ILSAC GF-7B designation applies to SAE 0W-16 viscosity grade oils and is backward compatible to ILSAC GF-6B only.
      As ILSAC GF-6 designated motor oils are phased out of distribution channels after the March 31, 2025, GF-7 launch, Valvoline said its new motor oils meeting the ILSAC GF-7A standard will include the “Starburst” API mark on all bottles, while ILSAC GF-7B-compliant oils will have the API “Shield.” Oils meeting API SP will feature an updated API “Donut” with SP designation.
      “Advances in engine oil performance wouldn’t be possible without the dedication, expertise and leadership of our Valvoline engineers and scientists, who work tirelessly to help define and shape the industry standards, continually raising the bar to benefit us all,” said Warholic.
      Standard Motor Products, Inc. (SMP) announced it released a total of 170 new part numbers in the first quarter of 2025, including introductions from
      link hidden, please login to view’s Vehicle Control and Temperature Control divisions. New coverage for late-model import and domestic vehicles was added across multiple powertrains, the company said. Ignition Coils have been added for Hyundai cars and SUVs, including the 2024-21 Elantra and 2024-22 Kona, and multiple new applications have been added to Standard’s Advanced Driver Assistance Systems (ADAS) Program. New coverage in this category includes Park Assist Cameras for import and domestic vehicles like the 2024-18 Chrysler Pacifica and 2024-20 Voyager, as well as Nissan, Toyota and Honda vehicles. Seven new ABS Speed Sensors were added, offering coverage for over one million Hyundai vehicles through the 2025 model-year, as well as the 2023-20 Kia Soul and General Motors vans through 2024. Also included in the release were Collision Repair components such as Hood Latch Assemblies, Tailgate Latch Assemblies, and Multi-Function Connectors for over one hundred million vehicles, according to
      link hidden, please login to view. Four Seasons New Numbers
      New numbers from Four Seasons include nearly 70 Hose Assemblies, adding coverage for over nine million import and domestic vehicles. This new offering includes Liquid Lines for the 2023-19 Subaru Forester, Discharge Lines for the 2024-21 Kia Sorento and 2023-21 Hyundai Santa Fe, and Suction and Liquid Lines for the 2023-21 Toyota Tacoma. Air Door Actuators were introduced for over three million General Motors trucks, as well as the 2021-19 Nissan Altima and 2020-19 Infiniti QX50. Four Seasons’ Reman and New Compressor programs have expanded as well, offering coverage for popular vehicles like the 2022-18 Honda Accord and 2023 Honda Civic. Additional categories that see expansion include Electric Coolant Pumps, Water Inlets, Thermal Management Modules, Heater Cores, Engine Coolant Auxiliary Pumps and more.
      Certain statements herein are “forward-looking statements” within the meaning of the Private Securities Litigation Reform Act of 1995. Forward-looking statements are usually identifiable by words such as “anticipate,” “believe,” “could,” “estimate,” “expect,” “forecast, “guidance,” “intend,” “likely,” “may,” “plan,” “position,” “possible,” “potential,” “probable,” “project,” “should,” “strategy,” “target,” “will,” or similar language. All statements other than statements of historical fact are forward-looking statements, including, but not limited to, statements about the Company’s strategic initiatives, restructuring and asset optimization plans, store and location opening plans, operational plans and objectives, and statements regarding expectations for future business and financial performance, as well as statements regarding underlying assumptions related thereto. Forward-looking statements reflect the Company’s views based on historical results, current information and assumptions related to future developments. Except as may be required by law, the Company undertakes no obligation to update any forward-looking statements made herein. Forward-looking statements are subject to a number of risks and uncertainties that could cause actual results to differ materially from those projected or implied by the forward-looking statements. They include, among others, the Company’s ability to hire, train and retain qualified employees, the timing and implementation of strategic initiatives, risks associated with the Company’s restructuring and asset optimization plans, deterioration of general macroeconomic conditions, geopolitical factors including increased tariffs and trade restrictions, the highly competitive nature of the industry, demand for the Company’s products and services, risks relating to the impairment of assets, including intangible assets such as goodwill, access to financing on favorable terms, complexities in the Company’s inventory and supply chain and challenges with transforming and growing its business. Please refer to “Item 1A. Risk Factors” of the company’s most recent Annual Report on Form 10-K filed with the Securities and Exchange Commission (“SEC”), as updated by the company’s subsequent filings with the SEC, for a description of these and other risks and uncertainties that could cause actual results to differ materially from those projected or implied by the forward-looking statements.
