At the same time the auto industry was dipping its toes into technology, I was your typical high school adolescent who only cared about the cars I could afford – which at that time was nothing newer than mid-‘70s iron.
The only language I knew was that of carburetors, camshafts, headers and hot rods, and growing up in a college town, I thought lambda was a fraternity. In a few short years when I entered both the auto repair industry and technical college, I found out I had a lot to learn.
All of a sudden, I had to learn technology, which required first off to learn the terminology. Oxygen (O2) sensors were new to me, and then throwing in the term “lambda” made it all seem complicated. I eventually learned that it really wasn’t, but I also learned not to get wrapped up in all the overly technical jargon.
From a technician standpoint, I needed to understand how things worked – not re-engineer them – so here’s what I taught myself to know about O2 sensors, and I promise I won’t use the word “lambda” … at least for a while.
O2 sensors have a simple function. They generate voltage, and their job in an automotive context is to provide a varying output voltage in response to the amount of oxygen in the exhaust. Determining the amount of oxygen in the exhaust is what allows modern engine-management systems to calculate the efficiency of the combustion process and adjust the fuel delivery to maintain the correct air/fuel ratio.
So, how do they do this? The principal is an electrochemical reaction that takes place, the catalyst for which is the difference between the amount of oxygen in the air we breathe compared to the amount of oxygen in the exhaust. In order to get the “outside” sample of air, some O2 sensors have provisions that allow air into the body of the sensor; others have a sealed sample inside.
One of the important factors in the operation of an O2 sensor is heat. The bottom line is they can’t produce an accurate signal until they’re warmed up. Until an O2 sensor is warmed up, the computer will run the engine in a mode called open loop. All this means is that it’s running on pre-programmed parameters, but it also means it’s not running efficiently since it’s not yet utilizing the critical data from the O2 sensor that it needs to adjust the air/fuel ratio.
When the O2 sensor warms up, the engine computer will switch to closed-loop operation, meaning it’s now adjusting the air/fuel ratio based on the input it receives from the sensor(s). Since this is so important for emissions, the quicker the O2 sensor warms up, the better. Location or placement in the exhaust has an effect on how quickly they warm up, but the two biggest factors are the addition of built-in heaters and higher idle rpm when the engine is cold.
High rpm also is important to warm up the catalytic converter, since they don’t work efficiently until warm either. But enough of that. Let’s move on.
AFR Sensors
So, you have an idea of what an O2 sensor does and when it does it. It’s time to throw a wrench in the works. There’s another sensor called an air/fuel ratio (AFR) sensor. An AFR sensor also is called (or nicknamed) a wideband O2 sensor. What they ultimately do is the same thing, and up to this point in the article, feel free to switch the term O2 with AFR.
They also look basically the same and mount the same. We often call them all O2 sensors, and nobody gets really hung up on it, because they’re close enough. AFR sensors, however, have different operating parameters because they have a wider range and are able to provide more precise information to the vehicle computer. They simply are a more accurate version of an O2 sensor.
The fact that they operate differently is obviously critical for diagnostics, but it’s also just as important from the standpoint of replacement. The only acceptable replacement is a sensor that is specified for the exact vehicle in the exact location on the vehicle. An O2 sensor won’t work in place of an AFR sensor, or vice-versa. Some vehicles also have both types of sensors installed, making it more important to confirm which sensor is being replaced.
Most modern vehicles have two sensors on each bank of the engine. An inline engine only has one bank (with the exception of a couple strange anomalies out there that you may run across), and any V-configured engine has two banks. When you sell an O2 or AFR sensor, you’ll need to know the location referenced as Bank 1 Sensor 1, Bank 1 Sensor 2, Bank 2 Sensor 1 and so on.
Real-World Operation
Let’s touch briefly on operation. Ideally, we would like to make an engine run at the perfect air/fuel ratio (referred to as stoichiometric ratio) at all times. In the real world, that’s not possible due to constantly changing parameters of engine operation, so the best we can do is allow the engine computer to make constant adjustments.
An O2 sensor (not an AFR sensor) is only able to send basic voltage signals of rich or lean. When it sends either signal, the control unit reacts and adjusts the fuel mixture. So, for example, if it sees a rich signal, it will continue to lean out the mixture until it sees a lean signal. As soon as it sees a lean signal, it then will begin to enrich the mixture until it sees a rich signal. This all happens really fast of course, and on an oscilloscope, normal O2 operation will look like a consistent waveform ranging from about .2 volts (a lean signal) to approximately .8 volts (a rich signal). As long as the average between the high and low readings is about .45 volts (450 millivolts), we know that the sensor is operating correctly, and the control unit is able to maintain the proper fuel mixture.
An AFR sensor operates in conjunction with the control unit through current flow. The current flow changes direction for rich or lean, and when the mixture is at the stoichiometric ratio, current flow stops. The AFR sensor also increases or decreases the current flow (in either direction) in direct proportion to the changing rich or lean condition. This provides much more information to the control unit, allowing it to better predict and control fuel mixture.
On an oscilloscope, normal operation is similar to that of an O2 sensor, but the voltage can vary in a range from 0 up to 5 volts. Lower voltage indicates a rich signal, whereas higher voltage indicates a
lean signal.
I may have bridged the gap of too much technical information, but it’s all more knowledge you can share with your customer and use to your advantage when explaining the importance of a quality sensor. Undoubtedly, you’re also going to be asked two things. One, how to tell if a sensor is bad; and two, tips about replacement.
Diagnosis
Diagnosing a sensor can be difficult when it comes down to the level of using an oscilloscope, primarily because it takes a lot of experience to get familiar with reading the waveforms. So, here’s a good way to approach it when your customer asks.
Generally speaking, a customer buying an O2 sensor is almost always trying to “fix” the “Check Engine” light because of an O2-sensor code. If the stored code is related to the sensor heater, diagnosis should be easy. The control unit provides power and ground to the heater, and wiring problems are very common. Check for power and ground at the sensor connector wires. If you have it, the sensor heater is bad and the sensor needs replaced. If you don’t have it, there’s a wiring issue.
If the code is related to sensor operation, it could be a bad sensor, bad wiring or another problem such as a vacuum leak or leaking injector. You have to be careful about misdiagnosis, so it’s fair to recommend your customer have the problem professionally diagnosed. However, it’s a fact that O2 and AFR sensors will wear out with age.
Since we know it’s a chemical reaction that takes place to make them work, think of it like a traditional car battery. A chemical reaction takes place to generate electricity in a battery, and over time the ability for that chemical reaction to take place diminishes. The same is true with an O2 or AFR sensor. They simply wear out. Don’t be afraid to recommend them based on age.
O2 and AFR sensors also are very sensitive electronic devices, and they can be damaged by coolant, engine oil, incorrect fuel or silicone and sealants that are not safe for use with them, so beware of these other outside possibilities that can
ruin them.
Installation Tips
When asked about installation, here are some tips. All sensors, O2 or AFR, are 22 millimeters. There are many different O2-sensor sockets, which are designed to allow you to remove the sensor without damaging the wiring harness. This is really only important if you are removing a sensor for access to another repair.
If the sensor is bad, there’s no need to worry about the wires. Cut them off at the sensor and use a 22-millimeter wrench or socket. The most common thing that happens during replacement is that you break the sensor loose, get about a quarter-turn on it and it locks up. You have to be patient at this point and allow penetrating oil time to work its way in, then slowly work the sensor back and forth until you can remove it.
Thread damage is common, but almost always repairable using a thread chaser or tap. Most new sensors come with a little anti-seize on the threads, but if not, use a high-temp anti-seize for installation.
The ‘L’ Word
I know I promised I wouldn’t use the “L” word, but just for the record, lambda is a numerical representation of stoichiometric ratio, which itself is a reference to air/fuel ratio. Most of us know 14.7:1 – the stoichiometric ratio for gasoline, which is necessary for complete combustion, or for all fuel to burn with no excess air left over. What’s tricky is that the stoichiometric ratio is different for alternative fuels.
In other words, all fuels don’t require the 14.7:1 ratio for correct combustion. E85, for example, has a stoichiometric ratio of 9.77:1 for correct combustion. The lambda value for the ideal stoichiometric ratio, regardless of fuel type, is 1.00. Basically, it’s just a different scale, like using the metric system vs. fractional. Utilizing the lambda value has become more popular in recent years, primarily due to the interest in aftermarket vehicle tuning. Many tuners utilize lambda simply for consistency, but you have to be careful. Some control units use lambda numbers, some use stoichiometric, so when you’re at that level, you just need to know what you’re dealing with.
      ✔️ Poor Fuel Efficiency
      ✔️ Starting Problems
      ✅ Final Thoughts
      What Are OEM Control Modules?
      Common Signs of ECM Failure:
      One resource to explore is
      The parts industry is a very diverse marketplace. While the landscape is mostly dominated by retail chains and jobber stores serving the general automotive and light truck segment, there are several other specialized parts vendors catering to imports, collision and refinish, powersports, ag and turf, and OEM vehicle brands. Each requires its own unique set of skills, including the heavy truck market.
      For many of us behind the counter, our only experiences with heavy trucks are when stock orders are delivered to our stores. Heavy-duty parts specialists work in a very different setting than the “year, make, model” format of retail parts, or the VIN-driven world of a dealership parts department. On those occasions when even a veteran P2-certified parts specialist is presented with a request for heavy-duty parts, we are required to think a little differently and be prepared to dig a little deeper to find solutions.
      Trucks are classified by their gross vehicle weight rating (GVWR), with light trucks like Tacoma, Silverado 1500, F-250, and Ram 3500 representing classes 1-3, up to 14,000 pounds. Medium duty (14,001 to 26,000 pounds) covers class 4, 5, and 6, including models like the Ram 4500, F550, and Kodiak 6500. These medium-duty trucks all feature hydraulic brake systems, and are sometimes catalogued alongside their light-duty counterparts. Heavy-duty vehicles, on the other hand, are catalogued primarily by the major components used to build the vehicle.
      Heavy duty generally describes class 7 and 8 trucks, with a GVWR over 26,000 pounds. Some class 7 trucks feature hydraulic or air-over-hydraulic brake systems, but the majority of trucks in these two classes rely on air brakes to stop these heavily loaded vehicles. Air brakes operate much like hydraulic brakes, using air pressure instead of hydraulic fluid to apply brake force when the pedal is depressed. Air pressure is created by an on-board compressor, and distributed through a series of valves and tubing to the foundation brakes (disc or drum brake components). Semi-trailers, when coupled to the tractor’s air supply, operate the same way. In case of a drop in air pressure, spring-loaded parking brakes serve as an automatic emergency brake.
      Cataloguing foundation brake parts often requires a combination of measurements, identification of manufacturer-specific design elements, and even axle model numbers. Air components require the understanding and identification of thread pitch and sizing, cross-referencing numbers from multiple vendor information sources, and a solid understanding of what each type of valve does within the system.
      Engine, drivetrain and suspension components are similarly dependent on how an individual truck was spec’d from the factory. A cement mixer or tri-axle dump truck requires a considerably heavier suspension design than an over-the-road tractor regularly hauling van body trailers full of potato chips. Even within the same model range, a truck manufacturer might offer engines from Cummins, Caterpillar or Detroit, each one mated to one of several manual or automatic transmission options from Eaton, Fuller or Allison. Throw in Rockwell, Eaton or Dana axle packages in one of a dozen different gear ratios, and the combinations become nearly unmanageable.
      In our automotive cataloguing, those drivetrain options (and most other parts requests) would generally be found through a simple year/make/model search, but with HD parts, that’s only the beginning. At the dealership level, VIN entry yields a copy of the build sheet or bill of materials (BOM) with the relevant options identified, and OE part numbers called out in the electronic catalog. For aftermarket professionals, its off to various manufacturer catalogs, searching individual component or assembly model numbers and/or serial numbers to collect part information. With more focus on identification of standalone parts that are not necessarily exclusive to one vehicle manufacturer, it simply requires a different approach than what many parts specialists are used to.
      There are instances when traditional aftermarket catalog skills come into play, and many of your existing light vehicle vendors also offer HD parts solutions. Your WD or DC might not stock a full line of heavy-duty parts, but many basics like filtration, lighting, belts, rotating electrical and batteries are often only a daily order away. For slower-moving HD-specific parts, special ordering from existing vendors is often a realistic possibility, assuming your customer can absorb the downtime.
      Most heavy-duty customers are commercial operators, and time spent waiting on parts is money lost for their businesses and yours. Quick turnaround times for these orders are an everyday expectation in the HD world, so last-moment requests and expedited shipping charges are common. For a parts specialist who enjoys a challenge, the occasional HD parts lookup represents a chance to flex their interchange and cross-reference muscles, and maybe even learn new ways of problem-solving that can be applied to their “regular” daily tasks!
    • By Muhammad
      When it comes to vehicle maintenance, auto spare parts play a crucial role in ensuring optimal performance, safety, and longevity. Every vehicle is composed of thousands of individual components, and over time, wear and tear can lead to the need for replacements. Whether you're a DIY enthusiast or rely on professional mechanics, understanding the significance of quality auto spare parts can save you time and money while keeping your vehicle in top condition.
      The Importance of Quality Auto Spare Parts
      Quality should always be a priority when it comes to auto spare parts. Genuine parts are manufactured by the original equipment manufacturers (OEMs) and are designed specifically for your vehicle's make and model. They ensure compatibility and reliability, which is vital for safety. Aftermarket parts, while often more affordable, can vary in quality, and it's crucial to choose reputable brands when opting for these alternatives.
      Investing in high-quality auto spare parts can lead to several benefits, including:
      Enhanced Performance: Quality parts work seamlessly with your vehicle’s existing systems, leading to improved performance and efficiency.
      Increased Safety: Reliable components ensure that essential systems, such as brakes and steering, function correctly, reducing the risk of accidents.
      Longevity: Genuine and high-quality aftermarket parts typically last longer, minimizing the frequency of replacements and associated costs.
      Warranty Protection: Many manufacturers offer warranties on genuine parts, providing peace of mind and protecting your investment.
      Common Types of Auto Spare Parts
      Auto spare parts can be categorized into several types, each serving a distinct purpose in vehicle operation. Here are some of the most common categories:
      Engine Components: These parts are crucial for the functioning of your vehicle's engine. They include pistons, cylinder heads, timing belts, and gaskets. Regular inspection and timely replacement of engine components can prevent significant issues and costly repairs.
      Braking System Parts: The braking system is one of the most vital safety components of any vehicle. Brake pads, rotors, calipers, and brake lines are essential for ensuring your vehicle stops effectively. Using high-quality brake components can dramatically improve braking performance.
      Suspension and Steering Parts: These parts include shocks, struts, control arms, and tie rods. They are essential for vehicle handling, ride comfort, and safety. Worn suspension components can lead to poor handling and uneven tire wear.
      Electrical Components: Modern vehicles rely heavily on electrical systems for everything from ignition to entertainment. Auto spare parts in this category include batteries, alternators, starters, and fuses. Ensuring these parts are functioning properly is essential for vehicle reliability.
      Transmission Parts: The transmission system is responsible for transferring power from the engine to the wheels. Components like clutches, gears, and seals must be in good condition to ensure smooth gear changes and optimal performance.
      Body and Interior Parts: While these parts may not directly affect vehicle performance, they play a significant role in aesthetics and comfort. Components such as mirrors, windows, upholstery, and body panels are essential for maintaining the vehicle's appearance and comfort.
      How to Choose the Right Auto Spare Parts
      Choosing the right auto spare parts can sometimes be daunting, especially with so many options available. Here are some tips to help you make informed decisions:
      Identify the Exact Part Needed: Use your vehicle’s manual or consult with a professional to identify the specific part you need. Having the correct part number can save time and avoid compatibility issues.
      Research Brands and Suppliers: Look for reputable brands known for their quality. Research online reviews and testimonials to ensure you’re choosing reliable suppliers.
      Consider Your Budget: While it may be tempting to opt for the cheapest option, remember that quality should not be compromised. Investing in slightly more expensive, high-quality parts can lead to long-term savings.
      Check Warranty Information: Always check if the parts come with a warranty. This not only provides peace of mind but also indicates the manufacturer's confidence in their product.
      Seek Professional Advice: If you’re unsure about which parts to choose, consult with a professional mechanic. They can provide valuable insights and recommendations based on their experience.
      The Role of All Makes Auto Parts
      At All Makes Auto Parts, we understand the significance of having access to quality
      link hidden, please login to view. Our mission is to provide a reliable source for both genuine and aftermarket parts for all vehicle makes and models. Located in the heart of Dubai, we offer an extensive inventory that ensures you can find exactly what you need, whether for routine maintenance or urgent repairs. Our dedicated team is passionate about automobiles and committed to delivering exceptional customer service. We work tirelessly to ensure that our customers receive the right parts at competitive prices, along with expert advice to guide their choices.
      Auto spare parts are an essential aspect of vehicle maintenance, contributing to performance, safety, and longevity. Understanding the importance of quality components, knowing the different types available, and being informed about how to choose the right parts can significantly impact your driving experience. At All Makes Auto Parts, we strive to be your trusted partner in keeping your vehicle in optimal condition. Whether you need engine components, braking parts, or anything in between, we’re here to help you every step of the way.
