The VVT category continues to grow in the automotive aftermarket. These systems are becoming more and more common as manufacturers try to meet tightened fuel-economy standards. When it comes to meeting those standards, variable-valve timing (VVT) is just one piece of the puzzle. As these vehicles exit the factory warranty period, there’s a huge opportunity for counter pros to serve customers’ repair needs.
Variable-valve timing is the process of altering the timing and/or duration of a valve lift event, to improve performance, fuel economy and emissions.
On a conventional engine, the opening and closing of the valves is based on their fixed position relative to the timing chain or belt, which is driven by the crankshaft. Without VVT, the valve timing remains the same for all conditions. This means that certain compromises must be made by manufacturers; this is achieved by selecting a specific cam profile. The cam profile affects the valve lift and duration.
However, an engine equipped with VVT can make additional adjustments, so it isn’t constrained by the cam profile. VVT systems allow for improved performance over a broader operating range. The ability to alter valve timing at any engine speed gives manufacturers the ability to tune for optimal performance and efficiency. The camshaft’s timing can be advanced to produce better low-end torque, or it can be retarded to have better high-end torque as directed by the ECU.
System Overview
It’s important to point out that VVT is not just a single part or component – it’s an entire system. There are a number of components that all need to work hand-in-hand in order for the system to function. Let’s talk about some of the components that make up the entire system.
The part that actually controls the position of the camshaft is the phaser. Cam phasers may feature a piston-type construction, or a vane-type construction. Regardless of construction, they use engine-oil pressure to push against a strong internal spring. A VVT solenoid is used to adjust the engine-oil pressure into the phaser.
While early VVT systems were active only in higher rpm ranges or under specific conditions, modern systems are actively adjusting the intake and exhaust camshaft positions for the best possible efficiency at all times.
VVT systems have caused one emissions system to become all but extinct: exhaust-gas recirculation (EGR). Since VVT is able to control the way gasses enter and exit the combustion chamber, there’s no need for EGR systems.
EGR systems were designed to reduce nitrous oxides (NOx) by recirculating exhaust gasses back into the intake manifold. This causes the combustion temperature to drop below 2,500 F, preventing the formation of these harmful gasses. EGR systems did work, but lacked the reaction time and precision offered by VVT systems.
Failure Points
In many ways, engine oil is the lifeblood of the VVT system. Inadequate oil pressure or contaminated oil will hamper system performance. It’s very important that customers are following the manufacturer’s maintenance schedule, and using only the specified type, grade and viscosity of engine oil in their vehicle.
Clean engine oil is critical to VVT-system operation. The oil passages of a VVT system are like a dead end, and the oil doesn’t flush out the passages all the time. If a piece of debris finds its way into a phaser or oil-control valve, it could be there for a while. Most manufacturers use a metal-screen filter to prevent debris from reaching the variable-valve timing system. Some manufacturers make the screen serviceable but, on some vehicles, it could be inside the oil-control solenoid and almost impossible to inspect or even clean.
The relationship between the camshaft and crankshaft is critical in today’s VVT systems. The ECU relies on information from the camshaft position sensor and the crankshaft position sensor to determine ignition and valve timing. If either of these sensors produces a faulty signal, the VVT-system performance will suffer. A loose or stretched timing chain or timing belt, or a worn timing guide or tensioner, all could negatively affect the VVT system.
      Dayco, a supplier of engine products and drive systems for the automotive, industrial and aftermarket industries, is expanding its timing chain kit line with 41 part numbers to cover another 49 million vehicles in operation (VIO). Additionally, the company is introducing the next generation of its AutoPartIQ inventory assessment tool—with new features for a more productive customer experience.
      New Parts Bring Timing Chain Kit Coverage to 120+ Million
      Dayco’s aftermarket team launched the line in 2022 due to the car parc shift from timing belts to timing chains at the OE level. The
      link hidden, please login to view, which feature OE-quality components, cover high-volume light-duty engine applications. They include all the necessary components for a thorough and complete repair, building on Dayco’s mission of recommending system replacement as a best practice. Dayco says the kits include: Timing and secondary chains that prevent stretch for the life of the kit – and address the no. 1 replacement issue; Precision-machined cam and crank sprockets for quiet, noise-free performance; Direct fit OE-quality, high-grade plastic guides, as well as VVT solenoids and cam phasers when the application calls for it; and Packaging that features a QR code that links directly to detailed installation instructions. Dayco backs its entire timing chain kit line with an industry-leading two year or 60,000 mile (96,000 kilometer)  link hidden, please login to view, whichever occurs first, giving technicians confidence in what they’re installing. Three of the new part numbers are already available, and the remaining 38 are scheduled for Q1 or Q2 2025.
      “We entered the timing chain kit market to meet the needs of our customers. The line continues to grow with sales increasing year over year and we are supporting our high-quality product line with important investments in warranty and training material,” said Tom Tecklenburg, Vice President, Aftermarket, Dayco North America. “We encourage our customers as well as shop owners to reach out to our tech team to schedule virtual training and to learn more about this line if they aren’t already stocking it.”
      link hidden, please login to view announced the release of an expanded range of timing chain kits and components for Q3 2024. The company said this latest product launch provides aftermarket solutions for a broad selection of popular vehicle makes and models. Cloyes said this quarter’s new offerings include comprehensive timing chain kits for Ford and Subaru vehicles. They’re designed to support Ford models such as the F-150, Mustang, Expedition and Transit, with engine sizes ranging from 2.7L to 3.7L. Subaru models, including the Forester, Impreza, Outback, and BRZ, are also covered, with kits tailored for 2.0L and 2.5L engines.
      Cloyes further expanded its product line with new timing chain kits for Mercedes-Benz and Mazda vehicles. Mercedes-Benz kits are designed for the 2.1L and 2.7L engines found in models such as the E250, GLE300d, and Sprinter vans. For Mazda, owners of vehicles such as the Mazda 3, CX-5, and MX-5 Miata can benefit from Cloyes’ new timing and oil pump chain kits, the company said.
      In addition,
      link hidden, please login to view now offers expanded coverage for Hyundai, Kia, and General Motors vehicles. The new kits support popular Hyundai and Kia models like the Sonata, Optima, Santa Fe and Sorento, with engine sizes ranging from 2.0L to 2.4L. For GM, Cloyes has introduced timing chain kits for 1.4L and 1.5L engines in models such as the Chevrolet Spark, Malibu, and GMC Terrain. Cloyes said each kit is engineered for optimal engine performance and includes a variety of essential components such as timing chains, accessory drive belts, variable valve timing (VVT) components and water pumps, where applicable. The company added that the kits “provide all necessary timing and oil pump chain system components to ensure long-lasting, efficient engine performance, meeting or exceeding OEM standards.”
      Timing Covers | Counterperson Training from Dorman Training Center
      Trouble codes such as P0014 can cause a problem with the variable valve timing (VVT) system and can lead to issues such as ...
      If you were buying a new vehicle, what would you want the engine to have: a timing belt or a timing chain? You may have an opinion, you may not. Either way, let’s compare the two; then you can decide.
      The Chain Gang
      For many years, timing chains were the go-to for engine design. Generally speaking, they were dependable and didn’t require any specific maintenance. They were lubricated by the engine oil, so if you changed it on a regular basis, the timing chain would hold up well.
      Or would they? A lot of people still say, “They don’t build them like they used to.”  This is true, and coming from someone who is an old-car enthusiast, I’ll defend a level of workmanship that we don’t see in today’s vehicle. But the statement, while true, doesn’t always mean they built them better.
      In the case of timing chains, they sometimes wore quicker than a lot of people realized. What happened when they did? On an old car, nothing right away. At least nothing of which the owner was aware.
      A timing chain, just like a belt, is there for one reason: to connect the crankshaft to the camshaft at exact points so the valves open and close at the correct time for engine operation. A traditional, old-school timing chain was tight upon installation, and the overall timing set consisted of a crankshaft gear, a camshaft gear and a chain. There was no adjustment or no tensioner.
      When the chain or the drive gears began to wear, engine performance would suffer, but it would degrade slowly, and most vehicle owners had no idea there was a problem. They wouldn’t know at all until they started to get a hard-start or no-start symptom. And why? There was no crank sensor or cam sensor, and no computer to translate the signals into a crank/cam correlation diagnostic trouble code (DTC). So, we just drove the cars until they wouldn’t drive any more.
      Early engine design was split between gears or chains, but chains ultimately became more popular because they took up less space and ran quieter, and by the early ‘80s, the majority of cars produced had timing chains.
      An evolutionary change of timing-chain design included nylon-tooth cam gears. They ran quieter than a traditional steel gear, but they wore out a lot quicker and created problems long before vehicle owners expected, which didn’t do much for their reputation. The tried-and-true timing chain was simple and generally dependable, but times were changing.
      Buckle Your Belt
      As the ‘80s rolled on, electronics, emission controls and technology were on solid cruise control and like flipping a switch, timing belts were suddenly in the picture.
      Although timing-belt-driven overhead camshaft engines weren’t new by any means, the value of the design began to be recognized and auto manufacturers started to change over to this concept. The camshaft was now located on the cylinder head, which eliminated push rods and, on some designs, the rocker arms were eliminated as well, saving weight, lowering cost, reducing valvetrain inertia and making multi-valve designs possible.
      The easiest way to drive the camshaft was via a timing belt. Since timing chains suffered from inherent gear wear and stretching, engineers decided that belts were the way to go. They were quieter and lighter than a chain and less expensive to manufacture.
      The tensioning systems were simple, and the belts remained tight for a long time without wearing the cam or crank gear.
      Seemingly, all was good, but even with the advantages of a timing belt, they required replacement at specific intervals, and the one disadvantage that became known quickly was that if not replaced, they would break with no warning. Simple tensioning systems required adjustment from time to time, and oil leaks also were a problem with timing belts, as they would degrade the rubber quickly and lead to a broken belt. A broken belt could mean a very expensive repair on interference engines.
      Belt quality and tensioner design improved quickly, eliminating many of the early timing belt troubles, and by the mid- to late-‘90s, timing belts were used on the majority of automobile engines. Belt-service intervals became longer, and consumers were getting used to this being a part of normal maintenance. But you still cannot ignore the replacement interval, and was it possible times were changing again?
      The Old Ball and Chain
      As we said “Happy New Year” to a whole new century, engine technology was a freight train out of control. Materials and manufacturing were better, RPMs were higher, turbochargers were boosting like never before and horsepower wars like we hadn’t seen since the ‘60s were heating up again.
      Smaller engines were producing more power than ever, and variable valve timing was pushing engine performance to the limit. Just like that, engine design required something that was narrower, more durable and more dependable than a timing belt, and consumers no longer wanted the associated maintenance. Hello chains.
      As of the last decade, timing chains have risen back to the top. Design is far different than that of old, with modern chains traveling around awkward paths of sprockets, hydraulic tensioners and chain guides, offering a high level of dependability and performance. But they couldn’t do it without one critical thing on their side: lubricant technology.
      A primary reason for timing-chain wear always has been related to lack of oil changes, lower-quality oil, and poor or non-existent positive crankcase ventilation (PCV) systems, which wreaks havoc on engine oil.
      Modern engine oil is not only far superior than it was just a few decades ago, but PCV technology also is eliminating the majority of blow-by-related contaminants and moisture from building up, resulting in cleaner oil and better lubrication throughout the engine.
      Timing chains and variable valve timing systems are dependent on clean, healthy lubrication and now they have it, but then again, does everyone change oil as often as they should?
      Talk to the Techs
      Timing belts generally are easier to service. This is primarily because they’re located on the outside of the engine and run dry, with no lubrication. When replacing a belt, there’s less cleanup and no time required to reseal engine covers. On the other hand, the engine water pump is frequently driven by the timing belt, so when you replace it, it’s a good practice to replace the pump, as well as any tensioners or rollers.
      Timing belts came into prominence along with the inline four-cylinder engine. What this brought was more than just cam/crank timing, but also balance shafts and intermediate shafts that often drove distributors and oil pumps. These weren’t hard to work with, but had to be timed correctly during belt replacement.
      As the timing belt migrated to V-configuration engines, it became a lot longer with additional rollers and a more difficult installation, plus some components such as thermostats were all of a sudden underneath. Some things got better, some got worse.
      Inspection is an advantage with a timing belt; it’s usually just a couple of bolts and you’re looking right at it. One problem, and a challenge especially on a second-owner vehicle: If the mileage is over that of recommended timing-belt replacement and the owner doesn’t know if it was done, replacement is always recommended.
      Many belts can look great on the outside but strip the teeth off a day later. The only way to inspect them closely enough to really look at the integrity of the teeth can be to remove them. And then, does it make sense to put the old one back on, and is there a technician who would want to take that gamble? One solution to this is the bright yellow replacement decal that’s included in almost every timing-belt kit, for a technician to fill out and affix under the hood. If only they got used more often.
      Timing chains, as good as they have become, are not without faults. They can be a bear to inspect and replace, mainly because they’re located inside the engine so they can be lubricated by the engine oil. There’s a lot more cleaning to do and usually a seal or two that needs replaced. Just as with belts, there’s often a water pump that’s driven by the chain that should be replaced.
      While the chains are more durable and dependable, if oil changes aren’t religious, the guides have a tendency to wear out really quickly. Most guides are steel with some type of nylon or plastic that the chain rides along. Remember the nylon-tooth cam gears? These guides do the same thing and beyond a certain point in wear, the tensioner can no longer take up the slack in the chain.
      This often leads to a rattling noise and a “Check Engine” light. Most engines still run perfectly fine at this point, with the most common complaint a “Check Engine” light and a cam/crank correlation DTC.
      Timing-chain replacement is often very expensive due to labor time, but, then again, so is engine repair when a timing belt breaks. They both require special tools at times, so there’s no winner on that argument. And, one more thing: Did we mention the latest technology of belt-in-oil drive systems? Here we go again. So, do you have a preference, or do you agree with my conclusion?
