PRT Offers Complete Struts For 2019 Honda CR-V
PRT announced the latest additions to its portfolio of complete strut assemblies and shock absorbers in the North American Aftermarket. The 27 new products represent more than seven million vehicles in new coverage.
The launches include important models like the Chevrolet Malibu, Dodge Challenger and Suzuki SX4, in addition to brand new applications including the Chrysler Voyager and Pacifica 2023, as well as the Ford Transit 250 and 350 HD 2023, among others.
“At PRT, we are continually investing in research and development of new products, bringing innovative and premium-quality solutions from OE to our clients in the aftermarket,” said Bruno Bello, director of global marketing at PRT. “The new items are in stock in the U.S. and ready for shipment!”
For more information, call 1-770-238-1611, visit
link hidden, please login to view, a brand of ADD GROUP, announced it is exhibiting an extensive portfolio of heavy-duty product applications at Heavy Duty Aftermarket Week (HDAW) ‘25, January 20-23, at the Gaylord Texan Resort & Convention Center, Grapevine, Texas, in Booth 1723. The brand is showcasing 100% Gas-Charged Shocks covering more than 5,000 OE references for Trucks, Trailers, Buses, Commercial Vehicles and more. Applications include the 2024 Kenworth W900, 2020 Volvo VNL 740, 2020 International HV Series and 2020 Freightliner Cascadia, among others. In addition, the company is also presenting medium-duty applications, including pickups such as the Ford F-250 and Ram 2500, as well as cargo vans like the Ford Transit and Mercedes-Benz Sprinter.
As a highlight, PRT HD is also presenting a full line of Air Springs, which are designed for superior performance, made with OE-quality materials and premium rubber mixtures, guaranteeing a maintenance-free and long-lasting product, according to
link hidden, please login to view. “We are delighted to present this leading portfolio of H-D and Medium-Duty applications to our clients at HDAW 2025. PRT Heavy Duty is synonymous with Top Performance, Technology and Leading coverage,” said Bruno Bello, director of global marketing at PRT.
For more information about
link hidden, please login to view products, call 1-770-238-1611, visit link hidden, please login to view, or follow @prtautoparts. The post
By ctplg
