Selling shocks and struts simply comes down to knowledge, and sometimes it’s a little tricky because many of our customers confuse the difference between shocks, springs and struts. So, let’s start by clarifying the difference with information you can pass on the next time you get into the conversation across the counter.
The suspension of a vehicle includes every component that supports the weight of the vehicle and travels up and down in response to the road surface, driving conditions or vehicle load. Springs are the components that support that actual weight of the vehicle, but they’re just one part of the suspension. Shock absorbers are the components that dampen the movement of the springs, but again, they too are just one part of the suspension.
In a traditional upper and lower A-arm front suspension (one of the oldest styles), the shocks and springs mount in separate locations, and the springs are either coil or torsion-bar type. Vehicles with this type of suspension – such as older full-frame vehicles and full-size trucks – typically have solid-axle leaf- or coil-spring rear suspension, in which, of course, the springs and shocks also are separate components.
Struts
The term “strut” is a shortened reference to the MacPherson strut design of suspension. A strut suspension differs from a “traditional” suspension in the manner that the spring and shock are assembled together as a unit that mounts to the vehicle body on top, and an axle component on the bottom. The top of the assembled unit includes rubber mounting, and in the case of front suspension, a bearing to allow it to rotate in response to steering (Figure 1).
The assembled coil-spring and shock-absorber unit is referred to as the strut, but from a functional standpoint, you can still think of them as a shock, spring and related mounting components – because that’s all they are.
Coil-Overs
So, what’s a coil-over? It’s a coil spring mounted over a shock absorber (Figure 2). Sound sort of like a strut? Guess what? It’s basically the same thing. The only difference is that coil-overs typically are smaller with adjustable coil-spring perches, which makes them a very versatile choice for performance suspensions, allowing adjustable ride height and use in a variety of suspension designs. But again, don’t let the fancy name throw you: It’s just a spring and a shock.
In addition to these, there are many different types and variations of suspension; definitely a topic for another article, but for the sake of this discussion, regardless of what they are, there are always springs that support the weight of the vehicle and shocks that dampen the movement. Most new cars and small SUVs have strut front suspension. Some have strut rear suspension, but separate coil-spring/shock-absorber rear suspensions are just as common. Full-size trucks and SUVs typically have upper/lower A-arm suspension in front and leaf-spring suspension in the rear.
For many years, suspension springs in general were never a problem for technicians. They rarely broke, and it took a long time before they sagged or weakened, regardless of the style of suspension. Shocks wore out frequently – a common problem – and we’ve all replaced many shocks over the years. If it was a car that had strut suspension front or rear, you removed the strut assembly, compressed the coil spring, removed the top plate and disassembled the strut.
Parts of a strut included the upper plate/bearing, coil spring, bump stop, dust boot, various washers or spacers and the shock-absorber/strut housing itself (Figure 3). Sometimes, the lower spring perch is a separate piece that slides onto the shock/strut housing, and sometimes it’s part of the strut housing. The shock-absorber/strut housing may be one piece (not serviceable), but often, replacing the shock absorber itself was yet another step that included removing a large nut on the top of the strut housing and sliding it out.
The strut housing was reused, a new shock was installed (or if not serviceable, the housing was replaced), then the original spring was reinstalled along with a new upper mount and hardware. I’ve probably done it a thousand times, until … dun, dun dun …the quick strut!
But before we get into that fast fix, let’s drive it home with a final word of wisdom: Shocks are not struts, and struts are not shocks, but a shock is part of a strut. The closest you get is when the strut housing isn’t serviceable, and the shock absorber and strut housing are one piece. On a vehicle that has separate suspension springs and shocks, you can replace one or the other. On a vehicle that has strut suspension, you also can replace one or the other. Think about it like this: Regardless of the type of suspension, the same components are there, and they do the same things – they just differ in the way they are put together.
Every time a shock absorber is collapsed or expanded, oil is forced between different chambers, through a small orifice inside. The effort that it takes to force the oil through is what dampens the suspension movement, and you can feel the resistance when you attempt to move the shock rod by hand.
What makes them good or bad? If there’s no resistance in the movement of the shock rod, the shock is bad. It can’t dampen the movement of the suspension, and when you hit a bump, the car will bounce like a pogo stick. On the freeways around here, I see it at least once a day.
Traditional shock absorbers commonly experience aeration, meaning air bubbles mix in the oil. This causes a similar effect as air in brake fluid, and the performance of the shock absorber diminishes. The solution? A gas-charged shock. The pressure keeps the air bubbles from forming, creating consistent performance. Traditional shocks tend to provide a slightly smoother ride; the type of ride we are used to in a big-old car, whereas gas-charged shocks will stiffen up the ride feel slightly but offer better handling performance.
Service Life of Shocks
How long a shock absorber lasts depends on many factors such as age and mileage, but one of the biggest is initial quality. I’ve seen them last anywhere from one to 15 years, and with all the variables, it just comes down to one question: Are they still good? There are two things to look at. One, are they leaking? If they leak oil, they are probably bad, but not always. Some shocks can exhibit minor signs of seepage, yet they still operate correctly. The second – and the ultimate determining factor – is the bounce test.
With the vehicle sitting on the ground, quickly push down on the suspension and release it. Focus on one spot of the vehicle and watch closely. The vehicle should return to its original height and stop dead. No wiggle, no jiggle – a dead stop exactly where it started. A slight hop above, then a return to original height, means the shocks are worn. If they’re completely wasted, it’ll pogo-stick where it sits.
The bounce test is the only way you can accurately assess performance, and a visual inspection for leaks or worn mount bushings, coupled with age and mileage, can help you determine if it’s time to replace the shocks, or if it’s time to plan for it in the near future. Recognizing the fine line between good and bad shocks can take some experience, and there’s a point where they can begin to adversely affect tire wear and braking distance before any noticeable handling or ride-related symptoms appear, so tire and brake wear should also be considerations when assessing shock condition.
At this point shocks may seem cut-and-dry, but there are some additional topics that may come up when selling them, and it’s good to be prepared with an answer.
Compression/Rebound
When the shock rod travels in, it’s considered the compression stage of operation; when the rod travels back out, it’s considered the rebound stage. The percentage of compression and rebound stage can differ depending on the application of the shock, but normal shock operation is about 25% compression stage and 75% rebound. This allows the suspension spring to react quicker to the road surface for the
best ride.
One of the most common examples of different compression/rebound rates is on the front shocks of a drag car. A 90/10 shock absorber is the most common application here, meaning 90% of the effort to move the shock rod occurs during compression, and it only takes 10% of the force to allow the shock to rebound. On a drag car, under heavy acceleration, this allows the front end to come up easily – shifting the weight to the rear wheels for traction – then slowly allows the suspension to settle to prevent bouncing in the front.
You’ll also see 60/40 or 50/50 percentages depending on the type of racing, performance or ride intended by a manufacturer, and maybe even something different than what I’ve listed here. Generally, you’ll be selling shocks by application, so you won’t have to be concerned about the numbers. But, you never know when someone might ask, so it’s always good to know.
Adjustable Shocks
Many performance shocks are built with adjustable valving, allowing you to change the compression and rebound rates to suit your needs. The adjustments can generally be made by an accessible knob on the side or top of the shock. Some shocks offer adjustment for only one aspect, some offer it for both. This also is the basic idea behind many modern suspensions that offer adjustable dampening, such as luxury or sport mode options. Instead of a manual adjustment to change compression and rebound rates, the adjustment is performed by a built-in electronic actuator that receives its signals from the vehicle control unit.
Measuring Shocks
Sometimes it becomes necessary to measure the required length of a shock absorber for a vehicle that’s been raised or lowered, changing the suspension travel. This is especially common for lifted trucks. If the question comes your way, it’s not hard to do. The specs you will need are compressed and extended height, but there are three measurements to take to get them.
Park the vehicle on level ground, then first measure the static height, which is simply the distance between the upper and lower shock mounting points. For this to be an accurate measurement, you’ll have to remove the shock. Next, with the vehicle still on level ground, measure the distance between suspension bump stop and the contact point for the bump stop. Subtract this from the static height and you have your compressed height.
To get extended height, jack up the vehicle so the wheel is off the ground, support it with a jack stand (for safety), then measure again between the upper and lower shock mounting points.
Load-Supporting Shocks
Many traditional shock absorbers are designed to assist the suspension when towing or hauling heavy loads. These are available as both air- and spring-assisted types. They are not designed to increase the load-carrying ability of a vehicle, but rather to help maintain the proper ride height and prevent bottoming out with a heavy load. Spring-assisted shocks offer a consistent load assist without affecting ride quality, and air shocks are adjustable to handle a wider range of varying loads but are designed to have the additional pressure released when the load is removed so the ride height returns to normal.
Selling Struts
When a customer comes in and wants to buy struts, the first thing that should come to your mind is what do they really need? Do they need a complete strut assembly? Or do they just need a strut housing? Maybe they only need shocks and just have their terminology wrong. Once you determine they indeed need struts, most likely you will direct them to a quick strut.
As I mentioned earlier, we always used to rebuild struts. It never seemed like a problem to me, but then again, I was used to it, and broken coil springs were never much of a problem. Then, all of a sudden, coil springs started breaking frequently, and some cars were known for it. When it came to a repair, it was common to find the shock leaking, and since you had everything apart, it didn’t make sense to replace the spring with an old shock. Then you found that the strut mounts were worn, so you ordered those too.
No matter how you looked at it, you had a lot of parts and a lot of labor involved. Then came the quick-strut: a fully assembled strut with new spring, shock, strut mounts and everything, ready to bolt in. On vehicles that needed everything, this proved to be an efficient solution.
Do I use them all the time? No. They’re not available for all vehicles, and in some cases on certain performance vehicles, the OE equipment is the best and only option for quality and customer satisfaction. You may have to do it the old-fashioned way.
But for many applications – especially on older high-mileage vehicles – if the shock is completely worn out, you can bet the rest of the components are too, and it just makes sense. Sure, a lot of technicians like them because it makes the job much quicker and you don’t have to fight with a coil spring, but it more importantly gives you a big advantage in selling to DIYers, because most likely they don’t have the tools to compress the spring.
Some final extras are sway-bar links, which often attach to a bracket on the strut housing. They’re often hard to remove and it’s probably a good time to replace them too. Shock absorbers should come with all needed hardware, and some shocks and struts are bushing-mounted at the bottom. As with any suspension bushings, these should be tightened with the vehicle at ride height to prevent premature wear of the bushing.
      link hidden, please login to view, brand of the ADD Group, announced an expansion of Complete Strut Assemblies in the North American Aftermarket. The new applications cover light vehicles, SUVs and pickups. The launch includes models like Honda Pilot, Acura MDX, Jeep Compass, Audi Q5 and BMW X3, among others, according to PRT. “Our highly automated factories support both OE and Aftermarket production, providing the latest in innovation and technology,” explains Bruno Bello, director of global marketing at
      link hidden, please login to view. “PRT is continually developing new products, bringing the best solutions to the aftermarket. These new additions expand our range and strengthen our presence in the North American market. The new items are in stock and ready to ship!” The new items represent nearly 9 million vehicles in coverage.
      There are just a few weeks left for you to nominate someone for the 2024 Counter Professional of the Year award. Counterman has proudly honored the winner of this award every year since 1986.
      link hidden, please login to view, a long-time sponsor of the award, is once again sponsoring the Counter Professional of the Year for 2024. The winner receives an all-expenses paid trip to Las Vegas, where he or she will be honored in-person at
      link hidden, please login to view, scheduled for November 5-7. The Counter Professional of the Year will also enjoy a VIP experience at the Babcox Media/WIX Filters recognition program. The winner also will be featured in the cover story in the December 2024 issue of AMN/Counterman. The Counter Professional of the Year award recognizes America’s most trusted “go-to” men and women behind the parts counter. The 2023 winner was
      link hidden, please login to view, an assistant manager at an O’Reilly Auto Parts store in Chicago. link hidden, please login to view “I wanted to do parts. That was always my main thing,” said Shambro. “I enjoyed it. Back in the day, I had part numbers memorized, so I could pick them up right off the shelf without looking anything up.”
      If you know a counter professional with the dedication, passion and knowledge similar to Shambro’s, visit our
      link hidden, please login to view and fill out the form. We will continue to accept nominations through August 16. The post
      Description: The program is designed to receive and display diagnostic information about engine operation via the OBD-II interface.
      To connect, you need an OBD-II bluetooth adapter.
      The program itself is able to receive all the information via the OBD2 interface.
      There are 15 customizable screens. You can display information in the form of graphs, digital values, dial. There are several predefined widgets, you can create your own.
      The program is able to display the current parameters of the engine, display and decode error codes, erase errors from the car's ECU (turn off the check engine light on the dashboard).
      a detailed description of the standard parameters is available on the OBD-II_PIDs wikipedia.
      You can set alarms for various sensor values, for example, coolant temperature, engine speed, speed.
      You can download or customize the extended set of OBD2_PIDs defined by the car manufacturer.
      The program can automatically send logs of sensor values to the web server and then you can see the route and sensor values at different times.
      Some of the program's features:
      • Measurement of torque.
      • Reading and display of information about the temperature of the engine and passenger compartment.
      • Customizable panels.
      • Determination of speed and location using a GPS tracker.
      • Sending your routes by email or social network.
      • Reading and display of vehicle errors, as well as their reset.
      • Resetting the Check-Engine.
      • Various plugins for Torque Pro.
      • Lots of different themes.
      • Compass with GPS support.
      • Connections of third-party applications, simple interface.
      What's new:
      A small update before the next update cycle starts:
      * Adjustment of a timer to fix a small startup issue on some obscure android devices
      Type: Modification
      Version: 1.12.100
      Download Link:
      f you read automotive articles on a regular basis, you’ve no doubt read about the scientific side of brakes many times. They convert kinetic energy, which is the energy of motion, into heat energy through friction between the brake linings and the drum or rotor. Because of this, brakes get hot…real hot…and dissipating the heat is one of the most critical factors affecting brake operation.
      So, would you believe that shock absorbers work off the same scientific basis of converting kinetic energy into heat energy? It’s true, and here’s how it works.
      Kinetic energy is the energy of motion. The springs on a vehicle support the weight of it and allow the suspension to move. But what would happen if there were no shock absorbers? Every time you hit a bump, the springs would compress then expand, and do this over and over again until they finally settled down.
      If you’ve never experienced the sensation, which is something like rocking on a boat, you’ve likely seen it on a car going down the road. The front or rear goes up and down, up and down, literally “bouncing” down the road. It happens, in this case, not due to the lack of shocks, but due to the fact that they are simply worn out, so for all practical purposes, they may as well not exist.
      link hidden, please login to view The springs absorb the kinetic energy from hitting a bump, but since springs are considered elastic objects, the energy is turned into potential energy. And, in the case of a spring, or any elastic object, the potential energy is then released, and the energy output equals the energy input. The spring will return to its original shape. At that point, the momentum of the car body creates kinetic energy, which in turn acts on the spring in the opposite direction. As you can see, this is a vicious circle, and we need shock absorbers to control it.
      The job of a shock absorber is therefore to control the kinetic and potential energy of a spring by dampening its movement. Shock absorbers are filled with hydraulic oil, separated between two different chambers. Between the two chambers is a piston and valve assembly. (See Figure 1). The piston is connected to a piston rod which moves in and out of the shock as the suspension moves.
      Compression is when the piston rod is forced into the shock; rebound is when the piston rod is pulled back out. The key lies in the valving, which restricts the flow of oil between the two chambers. Forcing the oil through these valves creates friction, which in turn creates heat. Yes, shocks do get hot, and now the shock has turned kinetic energy into heat energy.
      Changing the size of these valves changes the amount of force it takes for compression or rebound, which ultimately changes the ride characteristics of the vehicle. This is one of the main reasons there’s a difference in feel between a sports car and a luxury car.
      The more restrictive the compression and rebound, the less the suspension spring will move, which provides improved handling and stability characteristics, such as those desired on a sports car, but this also results in a firmer ride. Less restrictive compression and rebound allows greater spring movement and a softer ride, but not as good handling characteristics. There’s always a tradeoff.
      The comparison between the compression and rebound forces in a shock absorber is the shock ratio. Many standard shocks have a 50/50 ratio, meaning the compression and rebound forces are equal. Unequal forces one way or the other can have a drastic effect on handling, and one of the best examples to demonstrate this is with some old school drag racing tech. In drag racing, it’s important to shift the weight to the rear of the vehicle to increase traction while launching. One of the ways to attain this is by using 90/10 shock absorbers on the front.
      What this means is that of the total compression and rebound forces, 90% of the force is required to compress the shock, but only 10% of the force is required to extend the shock. When launching, the front of the car wants to lift as weight shifts to the rear. With a 90/10 shock, the front will unload easily and allow the weight to shift to the rear. Then, since it takes a much greater force to compress the shock, instead of the car coming right back down and bouncing in the front after hitting the track, the shocks will remain extended with the weight shifted rearward, and slowly settle as the car goes down the track.
      It often takes a while and a few different adjustments with shock ratio, both front and rear, to get a drag car suspension properly “tuned” in. By the same token, stock vehicles, either performance or luxury, are engineered to find the best of both worlds in handling versus comfort. So, the next time you talk about shocks to your customer, make it fun and talk a little science.
