It is important to bed in your new brakes during the installation of new brake pads or brake rotors. Race Brake offers a very simple procedure to
. Our installation process should be followed as per the application-specific brake pad installation instructions. The total bedding process should not take more than 10-15 minutes.
    • By abiztime
    • By abiztime
      5, Pallet
    • By abiztime
