        Stamping direction selection is an important part in die design. It not only determines whether a satisfactory drawing piece can be drawn, but also affects the number of supplementary parts and the shape of blanking surface. The stamping direction includes two aspects, that is, the location of the production and the processing direction of the technological characteristics. Locally, each process feature has its best punching direction. However, the stamping process of panel often contains many process features, and the optimal stamping direction of each process feature is not consistent. Therefore, to determine the stamping direction of a process feature, not only the stamping feasibility of this feature should be considered, but also the coordination with other process features should be considered. Therefore, in the process of process design, it is an optimization problem to determine the stamping direction of all process characteristics of a process.
        Most automotive panels are of complex spatial curved surface shape, which is formed by sheet metal drawing. The deformation is very complex, so it is necessary to optimize the stamping direction. In the process of optimizing stamping direction, the material flow in the stamping process is analyzed firstly, and the principle of determining the stamping direction is put forward. According to the principle, a mathematical model is established, and then the CAD technology is used to optimize the stamping direction.
      Smarter IMRC design for KIA/Hyundai 3.5L V6s | Dorman OE FIX 615-472
      Airbag Direction | ASE Test Practice Question 15
    • By garryhe
      When it comes to the safety and performance of your vehicle, selecting the right brake pads is paramount. As a leader in the industry, Ketulla is dedicated to providing high-quality brake pads tailored to meet the diverse needs of drivers worldwide. Whether you're in search of OEM, ODM, or aftermarket brake pads, let us guide you through the process of choosing the perfect fit for your vehicle.
      Understanding Ketulla Brake Pads: At Ketulla, we offer a comprehensive range of brake pads, each designed to deliver exceptional performance and reliability:
      Ketulla OEM Brake Pads:
      Brake pads types: Ceramic, semi-metallic, low metallic brake pads Crafted to meet the exact specifications of leading vehicle manufacturers. Engineered for precision fit and optimal performance. Designed to maintain the integrity of your vehicle's braking system while ensuring safety and reliability. Ketulla ODM Brake Pads:
      Tailored solutions for OEM manufacturers and distributors. Customized to meet specific performance requirements and branding preferences. Engineered with cutting-edge technology and premium materials to exceed industry standards. Ketulla Aftermarket Brake Pads:
      High-quality alternatives for drivers seeking performance and value. Designed to provide consistent braking performance and durability. Available in a variety of formulations, including organic, semi-metallic, and ceramic, to suit different driving needs and preferences. Choosing the Right Ketulla Brake Pads: Selecting the ideal Ketulla brake pads for your vehicle is a straightforward process when you consider the following factors:
      Vehicle Compatibility:
      Ensure that the brake pads you choose are compatible with your vehicle's make, model, and year. Consult your vehicle manufacturer's specifications or contact Ketulla customer support for assistance in selecting the right brake pads. Driving Conditions and Habits:
      Tailor your brake pad selection to match your driving habits and conditions. For daily commuting and city driving, consider Ketulla's OEM or aftermarket brake pads for reliable performance in varied conditions. If you frequently tow heavy loads or engage in performance driving, opt for Ketulla's ODM or aftermarket high-performance brake pads for enhanced stopping power and durability. Budget and Performance:
      Ketulla offers brake pads to suit every budget and performance requirement. Choose from our range of OEM, ODM, and aftermarket options based on your budget constraints and desired level of performance. Rest assured that with Ketulla brake pads, you're investing in quality and reliability, regardless of your budget. If you want to know more, just look through our webpages(
      link hidden, please login to view), our professional team always be at your service.
      Which Brake Pads Are Right For My Vehicle? | Brake Pad Selection
      Litens Aftermarket recently introduced its latest OE improvement, the 999420A belt tensioner.
      This new tensioner boasts improvements to the OE design, enabling an efficient belt-tensioner replacement process by a single technician, according to Litens.
      “This tensioner was engineered to improve upon the OE design by addressing the challenges technicians encounter during the installation of belt tensioners, particularly in the confined spaces of engine compartments,” Litens explained in a news release. “Focusing on ease of installation, Litens integrated a design advancement to simplify the installation process significantly.”
      The design upgrade is the lift feature, strategically placed in an offset position between the mounting bolts that secure the tensioner – adding an extra inch under the lip for a technician, providing greater ease of access.
      Typically, a tensioner is located at the side of the engine compartment where there’s very little room for working hands to get a wrench on the tensioner to loosen the belt during installation. The configuration in the Litens tensioner facilitates easy access for technicians to position their wrench when loosening the belt, streamlining the installation process even in the tightest engine compartments, according to the company.
      Additionally, the lift feature is designed for a 14-millimeter hex wrench consistent with OE design, rather than using a 15-millimeter hex wrench traditionally used on aftermarket tensioners. Consequently, Litens says, the technician has one less tool to keep track of throughout the replacement process.
      “As an engineering company that manufactures parts, we recognize the struggles that come with installing these parts in tight space,” said Randy Wolters, product manager, belt-tensioning products, Litens Aftermarket. “With these design improvements we’re able to give the tech an extra set of hands and save them from the bloody knuckles you get when working in such a tight space.”
      link hidden, please login to view is available for all Mazda applications between the years 2006 through 2017, covering a total of 30,000 vehicles in operation. The post
