According to the cooling medium used, engine cooling methods can be divided into water-cooled and air-cooled.
1. Water-cooled one by one with water as the cooling medium, heat first from the machine to water, by the flow of water to heat away and then into the atmosphere. After heat dissipation, the water flows back to the hot part again. The normal working temperature of the engine can be maintained by properly adjusting the water and cooling intensity. At the same time, hot water can also be used to preheat the engine, which is convenient for starting in winter.
The structure of water-cooled cooling system: water pump, radiator, fan, thermostat, expansion tank, warm air, engine water jacket, cooling pipe.
2. the heat of air-cooled parts is directly scattered into the atmosphere.
At present, most of the cars are water-cooled.
  • 4 months later...
  • 3 months later...
    • By Mighty Auto Parts
    • By ctplg
