Car with 3-5 years, the following 7 rubber parts must be checked and replaced.
1.Engine foot glue
The purpose of the engine foot glue is to isolate the engine vibration from the cockpit and fix the engine foot and frame with rubber pads, so as to achieve a certain damping effect and make the engine work smoothly.
Usually the engine is oxidized when the driving distance exceeds 50,000 kilometers or the driving time exceeds 5 years. The elastic corpse reduces the damping effect of the engine and can not effectively isolate the vibration of the engine from the frame so that the vehicle leaves the vehicle. Now the boom is loud, but it's fast or abnormal. Many toll collectors often overlook this problem, when the engine appears, think about it, first check the engine itself, but ignore the foot glue oxidation. Replacing the foot glue is not complicated, to the roadside general automobile repair shop can be replaced, the cost is only a few hundred dollars, you can solve the car engine abnormal sound idle jitters problem.
2.Suspension swing arm rubber bearing
The suspension swing arm rubber bearings are common in the McPherson front suspension which is now used in driving vehicles. Because of its mechanical characteristics, rubber bearings are needed to cushion and limit vibration and play a supporting role. Many consumers are very strange to suspension swing arm rubber bearings, because it is possible to love the car will not be replaced, but it does affect our car driving experience. Thanks for the help and support of Chongqing Feilong jianglis  Technical department.Many consumers will feel that after a few years old cars are no longer as easy to drive as new cars, suspension jump response is not very sensitive, and even the road conditions are not very good road surface, the body will jump very seriously, steering at high speed and the stability of the vehicle at high speed is reduced, these are the impact of aging suspension brackets.
Replacing the rubber bracket of the suspension arm requires the use of a professional lift, so consumers had better go to a professional body for replacement.
3.Shockproof top rubber bearing
The rubber bearing of the shock absorber roof is a cushioning mechanism which can alleviate the vibration of the suspension when the suspension jumps and transmit to the fulcrum of the frame. The early rising part of the vehicle, the inverted suspension is fixed and manufactured. Instead, it uses insomnia so that the body can be used only after the stability of the road surface is reduced. The rubber is used as the material of manufacture, but the design life is five years left. Right. Vehicles passing through the bumpy road caused by suspension ministries to issue abnormal sound, or suspension jump ten people response, not very sensitive, usually suspension too much vibration, resulting in a reduced sense of carriage ride.
4.Crankcase rear oil seal
Crankcase oil leakage is a problem many owners will encounter, especially in the use of several years of old cars, crankcase oil leakage let many owners are very distressed. Usually the main reasons for oil leakage of crankcase are: first, there is no use of professional lubricant seal in the manufacturing process, in the use of the process of vibration displacement caused by oil leakage. Secondly, because of the engine oil seal design problems, the use of a period of time after the force caused the deformation of the oil seal groove, and ultimately oil leakage. The above two are the quality problems of the manufacturer, but after more than five years of engine life, crankcase tank with aging aggravated, will produce small cracks, will also lead to oil leakage.
5.Drive shaft damping rubber
For some rear-drive and four-drive vehicles after several years of use will encounter the need to replace the transmission rubber shock absorber, the replacement of shock absorber rubber is very time-consuming, labor-consuming, very high, but if not replaced in time will cause permanent deformation damage to the transmission shaft, causing resonance in the front and rear transmission of the car, affecting the line. The car is safe. In our normal driving process, the transmission shaft vibrates with the body and this traditional process is not smooth, so the need for such damping rubber to prevent the transmission shaft should be centralized vertical damage, so the transmission shaft needs transmission rubber shock absorption.
6.Frame sealing strip
The replacement of the frame sealing strip is also a problem that many car owners will ignore. The frame sealing strip is pressed on the special rail groove by external force. Exposed to oxidation outside the car, the sealing of the car body will decrease. The infiltrated rain will penetrate into the car body through the crack. The acid rain will corrode the car body inside, and eventually lead to the corrosion. The rust inside the car body is very difficult to deal with. The strength of the car body gradually decreases, and eventually the car body may be rusted through. Therefore, changing the frame seal strip in time is one of the main measures to protect the body from rust.
7.Rubber hose for engine oil circuit
The oil pipeline of the engine needs to withstand the high temperature and pressure of the engine, so the consequences are very dangerous once it aging and finally ruptures. Usually the service life of the engine input pipeline is about four years, and cracks will appear on the surface of the aging pipeline as time goes on, which is very easy to spontaneous combustion in the high temperature environment of the engine compartment. Once the driver smells a smell of gasoline through the air conditioner, he must be on the alert.
      Certain statements herein are “forward-looking statements” within the meaning of the Private Securities Litigation Reform Act of 1995. Forward-looking statements are usually identifiable by words such as “anticipate,” “believe,” “could,” “estimate,” “expect,” “forecast, “guidance,” “intend,” “likely,” “may,” “plan,” “position,” “possible,” “potential,” “probable,” “project,” “should,” “strategy,” “target,” “will,” or similar language. All statements other than statements of historical fact are forward-looking statements, including, but not limited to, statements about the Company’s strategic initiatives, restructuring and asset optimization plans, store and location opening plans, operational plans and objectives, and statements regarding expectations for future business and financial performance, as well as statements regarding underlying assumptions related thereto. Forward-looking statements reflect the Company’s views based on historical results, current information and assumptions related to future developments. Except as may be required by law, the Company undertakes no obligation to update any forward-looking statements made herein. Forward-looking statements are subject to a number of risks and uncertainties that could cause actual results to differ materially from those projected or implied by the forward-looking statements. They include, among others, the Company’s ability to hire, train and retain qualified employees, the timing and implementation of strategic initiatives, risks associated with the Company’s restructuring and asset optimization plans, deterioration of general macroeconomic conditions, geopolitical factors including increased tariffs and trade restrictions, the highly competitive nature of the industry, demand for the Company’s products and services, risks relating to the impairment of assets, including intangible assets such as goodwill, access to financing on favorable terms, complexities in the Company’s inventory and supply chain and challenges with transforming and growing its business. Please refer to “Item 1A. Risk Factors” of the company’s most recent Annual Report on Form 10-K filed with the Securities and Exchange Commission (“SEC”), as updated by the company’s subsequent filings with the SEC, for a description of these and other risks and uncertainties that could cause actual results to differ materially from those projected or implied by the forward-looking statements.
    • By abiztime
      2025 Longkou lihe machinery parts co.,ltd (rdbrake.com) global exhibition schedule.
      4.22-26, Sao Paulo. Booth: D275 at AUTOMEC EXHIBITON BRAZIL.
      5.21-24.5 at Autopromotec in Italy.
      Welcome to visit the booth.
      link hidden, please login to view, a division of link hidden, please login to view, announced it is adding new general repair parts commonly used by transmission repair shops in over 50 locations. With the addition, these general repair parts will now be available at the majority of Transtar’s 70 locations, simplifying complex vehicle repair by enabling repair shops to find the parts they need in one location, the company said. The aftermarket brands with which Transtar is partnering as part of the expansion, and their respective repair parts, include:
      • Denso – ignition coils, oxygen sensors, spark plugs
      • ProMax – Brake pads, rotors, chassis, control arms
      • Sunsong® – Brake hoses
      • GSP® – CV axles, hub assemblies
      • DFC – Brake pads, rotors, calipers
      “The addition of general repair parts at a significant number of our locations is an exciting enhancement and one that is a part of Transtar’s overall commitment to becoming a one-stop solution for our customers,” said Tom DeMille, executive vice president, sales and marketing. “We’re committed to supporting shops in all types of repairs. Whether that’s a general automotive repair or more complex transmission repair, Transtar has the parts needed to keep the world moving.”
      For a complete listing of Transtar locations and products, visit
