Due to the limitation of installation space and performance requirement, automobile engine cooling water pump has the characteristics of small volume, simple manufacture, and is conducive to mass production. The cooling water pump is usually made up of main parts such as pump body, impeller, shaft, bearing, water seal and pulley.
According to the different structure of the engine cylinder block, the pump pressurized water chamber can be integrated on the engine cylinder block, and the impeller can also be separately configured as the core functional components of the pump, its diameter, outlet width, blade structure shape and other parameters and structure design directly determine the performance of the cooling water pump.
There are many kinds of cooling water pump structure, according to the impeller material is different, can be divided into cast iron impeller, stamping impeller and plastic impeller; according to the impeller has no cover plate can be divided into open impeller and closed impeller; according to the impeller blade shape is different, can be divided into straight blade impeller, single curvature blade impeller and space twisted blade impeller. Feilong Jiangli has all the kinds of impellers.
With the development of science and technology, cast iron impellers are still used in the cooling water pumps of trucks, buses and other heavy-duty vehicles and a few self-owned passenger cars. Pressed impellers are mostly used in Japanese passenger cars, plastic impellers are mostly used in European and American advanced countries, and three kinds of impellers are used in domestic self-owned brand cars, but with With the introduction of new technology from abroad, plastic impellers have been used in newly developed machines. When cooling water pumps work, the coolant rotates with the impeller on the one hand, and flows out of the rotating impeller on the other.
      Visit
      Electric Pump vs Air Compressor Vertical Shop Press Promo Video
      link hidden, please login to view has launched the new BKS1002 fuel pump kit. This new model is engineered specifically for high-pressure, in-tank applications and is the highest flowing fuel pump in the TI Automotive catalog, according to the company. The BKS1002 fuel pump kit will feature:
      High-pressure, high-flow E5LM brushless screw pump 3’ long wire harness for tank mounting High-performance inlet filter Support of 1,000+ horsepower “The BKS1002 further expands our line of fuel pump kits with another high-pressure, high-performance technology, but adds additional flexibility for enthusiasts,” said Brian Altenberger, aftermarket business director, TI Automotive. “There has been a significant demand in the market for the option to purchase a standalone pump and the BKS1002 now provides that option.”
      TI Automotive Aftermarket said its BKS1002 must be driven with a sensorless 6-step commutation method or other suitable methods such as Sinusoidal or Field Oriented Control (FOC). The BKS1002 pump, filter and wire harness are all components from the BKS1001, but without the controller. The BKS1001 will remain available, however customers who already utilize a controller may now opt to purchase a kit without one, offering additional build flexibility.
    • By 1772668470
      Installing a power steering pump involves several steps. It’s important to have the correct tools and follow safety precautions. Here’s a step-by-step guide to help you through the process:
      Tools and Materials Needed:
      New power steering pump
      Power steering fluid
      Wrench set
      Screwdrivers
      Pulley puller (if necessary)
      Jack and jack stands
      Drain pan
      Safety glasses and gloves
      Torque wrench
      Steps to Install a Power Steering Pump:
