When I hear good and bad in the same sentence, I think of the classic Clint Eastwood movie, “The Good, the Bad and the Ugly.”
This isn’t the Old West, but I can draw a perfect parallel between the title and the fight we sometimes have with alternators.
When they’re good, they’re good. When they’re bad, they’re bad. So, what’s the ugly? That’s when they’re good, but we think they’re bad because there’s an electrical problem that prevents them from working properly. It gets even uglier when the problem is hard to find, and probably the ugliest when a good alternator is called bad.
What an alternator does is simple, or at least we’ll keep it that way for now. It outputs direct current (DC) to power vehicle electrical systems and maintain and recharge the vehicle battery. An alternator is aptly named because it generates an alternating current (AC), which is, in turn, converted to DC.
We can divide the alternator into two different systems: the mechanical and the electrical. On the electrical side, you have the components that are responsible for generating and managing the electrical current, which include the rotor, stator, regulator and rectifier. The rotor and stator are the main components that generate electricity, based on fundamental electromagnetic principals. The regulator is what controls the output of the alternator, and the rectifier is what converts AC to DC.
The Good
When an alternator is good, alternating current is being generated by the rotor and stator, the rectifier is converting it to direct current and the regulator is controlling the output. If a problem develops with one of these, the result is either no voltage, too much voltage or an AC-voltage output. Any of those are bad.
If this seems too simple, it is on purpose. We can get much deeper into it, which will make it more difficult, but the way we do things today has changed the process of diagnosing the charging system. Things were different years ago. We used to take alternators apart. We’d check the windings of the rotor and stator. Then we’d check the diodes in the rectifier, and finally check the regulator. As a matter of fact, regulators used to be separate from the alternator and they were mechanical devices compared to solid-state electronics. We’d take everything apart, check it all, determine what was bad and replace only what was needed.
We don’t do that anymore. Alternators have been self-contained for many years. Regulators are built in. If an alternator isn’t working, we replace it. That’s it. We don’t think about why, nor do we even toy with the idea of taking it apart. Just send me a new one.
On the mechanical side, you have the bearings that support the rotor, and the pulley that’s driven by the belt. If the bearings are bad, they’re loose or noisy. Pulleys used to be fixed chunks of metal. Now we see overrunning alternator pulleys (OAP) or overrunning alternator decouplers (OAD). When these go bad, they’re often noisy, or they may not spin the alternator.
The brushes in an alternator are another mechanical part of it. They’re made of conductive materials that physically contact and rub against the slip rings. This is how the electrical current from the regulator flows into the rotor. But we don’t replace brushes anymore, nor do we replace bearings. We don’t even think about taking the alternator apart. We just replace it. The pulleys are the only parts we may replace separately.
The Ugly
When an alternator needs replaced, the process usually isn’t too difficult, but that’s when it can get ugly.
As counter professionals, you deal with technicians, and you deal with do-it-yourselfers. Either way, when they ask for an alternator, you’re hoping the diagnosis is correct. The last thing you want is an alternator return. You might ask a few questions to see if they’ve done some basic diagnosis, but you’re in a tough spot. You don’t want to show disrespect, but you don’t want the original coming back covered in grease, because they found the “real” problem after they replaced it and it didn’t fix the problem.
Do DIYers make mistakes? You bet. Do professional technicians make mistakes? We sure do. It’s not always easy, and diagnosis can be difficult. Any time electrical diagnosis is involved, the potential for mistakes can be greater, and charging systems are no exception. One problem is that alternator failure isn’t uncommon, and if the charging-system indicator is illuminated, that’s likely the problem.
It’s easy to see the warning light, and even maybe check battery voltage with the engine running. If the battery voltage is at or below 12.6 volts, the alternator must be bad, right? After all, we would normally see 13.5 to 14.5 volts. This is what I like to call a reactive diagnosis. We react based on what we know is common and think that what we initially see tells the story. Sure, it’s possible that the alternator may be bad, but only possible. A fact of electrical diagnosis is that the majority of all electrical problems are caused by higher-than-normal resistance – in other words, a poor connection.
Diagnostic Tips
How, as technicians do we keep from making this mistake? We have to remember that electrical systems are far more complicated than they have been for years, and they require correct system voltage in order for all of the computers and electronics to work properly.
Battery condition is critical, and a weak battery can prevent an alternator from properly charging. It’s also not unheard of to get a vehicle in that has both a bad alternator and a bad battery. It does happen.
When diagnosing charging systems, an important detail not to overlook is performing a voltage-drop test on the battery and alternator cables. It’s safe to say that higher than normal resistance is responsible for the good majority of misdiagnosis and comebacks.
The traditional tools we use for battery and charging-system diagnosis are a digital battery tester, a multimeter, a load tester and an amp clamp. However, for modern charging-system diagnosis, a scan tool has become a must-have. Modern charging systems are no longer stand-alone systems, with the vehicle ECM playing a large part in their control and operation.
A power-management system is a more accurate name than charging system, and it includes the alternator, battery and ECM. These systems have been developed to improve fuel economy, battery life and alternator operation, and not only do they monitor battery condition, but some systems also can estimate battery condition as well. They control and adjust charging output and they also can perform diagnostics and set diagnostic trouble codes. Good alternators can go bad, but if you’re faced with answering questions and giving advice to your customers at the counter, make sure they’re covering all the bases of diagnosis, so a good alternator doesn’t turn ugly.
      Silverado or Sierra leaking coolant? Fix that connection for good
      In business, as in life, mistakes WILL happen. How you respond will make the difference in whether your customer will remain loyal and continue to do business with your store. Customer relations are easy as long as things go well – when they don’t, you and your team have the opportunity to shine or look like the proverbial pile of…well, you know.
      Let me underscore this with a recent experience I had at a global coffee chain. I love heading out to the coffee house with my wife, Marlene, to grab a cold brew or blended beverage. While we are hanging out there, we’ll plan trips, discuss an upcoming event – this has been our “date night” routine for many years.
      You see, this chain had pioneered the “third place” experience, where customers and non-customers alike are welcomed to their stores. People could experience some great tunes, meet with friends or business associates, work on homework, read a book, and sip on a tasty beverage. In the post-Covid world though, I worry that the customer experience has suffered.
      We recently endured a visit to our nearby location that gave me pause. From that experience I began to consider our clients’ and your store’s interactions with your customers and the fragile nature of the relationship. I began to recognize the creep of “Customer Experience Decline” (let’s call it CED) that can occur if you take your eyes off the ball, like this coffee chain has.
      Back to the coffee house: we ordered two blended beverages and a water, three drinks total. Marlene’s drink and the water came up first, then several minutes went by. After waiting patiently, I decided to head back to the counter, where the staff found creative ways to ignore my presence with world-class ease. Drinks zipped through the blender and were handed off to the drive-through attendant.
      I wondered when I would see mine. Perhaps the drink label they affixed to the cup didn’t print, so I bided my time and waited. Finally, my drink was delivered to the counter, where its maker hollered my name. Keep in mind, I was standing right in front of her.
      Before she scampered away, I asked, “Could you help me to understand the reason my drink took five minutes longer than my wife’s?” The look on her face was priceless, as though I had asked a question worthy of a Mensa exam! Pausing a moment, she responded, “We are shorthanded,” an answer you hear far too often today. Still, I thought, why did I see eight other drinks processed before mine was delivered?
      I pursued the first question again, with the same answer, this time delivered without a smile. Again, trying to understand, I asked the question a different way. Her next response absolutely floored me: she glared at me as though I’d fallen off a turnip truck, raised her hands to the side of her head, palms up and then just shrugged. Essentially, she communicated nonverbally, “I really don’t care! Here’s your drink, now go away!!”
      For a coffee chain that had built its reputation of being a welcoming location, outstanding interactions with their guests and building a sense of community had fallen to a simple act of indifference to a loyal customer’s request.
      Handling Customer Challenges
      How are challenges handled at your store? Does your staff have the same passion to care for your clients that you do? Have you kept an eye on things, one of the many things a parts professional is responsible for on a daily basis?
      Are you aware that, according to a study commissioned by the White House Office of Consumer Affairs, 75% of customers leave a business due to apathy, also known as indifference?
      The good news of that staggering figure is that if we can control our behavior and our team, we can eliminate 75% of the reason a customer would stop buying from us! All we need to do is to provide exceptional customer service and experience!
      Let’s look at five simple ways you, your counter pros and anyone who interacts with a customer can meet and exceed your customers’ expectations.
      Listen
      You’d be surprised how often we miss the mark. The counter is busy, the phone is ringing, parts drivers need your signature, the computer is slow and the customer is standing in front of you. With all the distractions, how do you make sure things don’t fall through the cracks with the customer? Stay engaged, keep your eyes on them, focus and ask questions. Write or type the information down and, most importantly, review the requests with them before the leave the store.
      Don’t rush! I am sure you and they alike would rather wait an extra minute or two so you can make sure all their requests are noted and handled, rather than them showing up to pick the car up and learning that your team missed the oil change or state inspection they needed!
      Be Present
      Being present is pretty simple – tune into the customer, whether you’re in-person or on the phone. It’s really off-putting when a person (often the advisor) disengages from a conversation to answer a question coming from the background, or worse, laughs at something that might be out earshot of your customer.
      Ask Questions
      This one is even easier. By listening (highlighted in the first bullet point), your team will be armed with the information needed to ask the right follow-up questions. Your customer, your techs and you, as the owner, are all relying on the advisor who is at the tip of the spear to get it right. When we listen, ask the right questions and write the answers down, everyone in the process can participate in ensuring the job is done completely and accurately every time.
      Don’t Make Excuses!
      Mistakes will happen. If it really is your fault, don’t try to hide behind an excuse or try to give a complicated reason for the issue. Just say, “We made a mistake and we’ll make it right.” Remember to choose your words wisely though, so as not to give away the farm. In most cases, the customer understands that everyone is human, and won’t put the screws to you.
      Say I’m Sorry
      Remember my coffee shop story? I was literally blown off and figuratively given the middle finger. The likelihood that I’ll grace that store’s doors again is slim at best.
      To be honest, a simple apology for the wait would have sufficed and disarmed my frustration, along with letting me know how valuable my business is. A well placed “I’m sorry” goes a long way.
      You have many roles as a counter professional, but it all starts with setting the tone as a leader, training your team on what you expect. Occasionally inspecting their work and consistent review of your store’s culture will go a long way toward ensuring your customers KNOW that YOU care about them, their cars and the experience they receive each time they head to your shop.
      Don’t let something as controllable as indifference alienate loyal clientele.
      The water pump is a vehicle component that needs no introduction. For most vehicle owners, however, they don’t think about it until something goes wrong.
      As the only moving part of the cooling system, the water pump plays a vital role in keeping the vehicle running optimally in all weather conditions. Water pumps usually last a long time – 100,000 miles or more on average. When a water pump fails, though, the results can be catastrophic for the engine.
      Let’s talk about some common causes of premature water-pump failure.
      Coolant Contamination
      Coolant can become contaminated with dirt, debris or other substances that can wear down the water pump’s internal components, including the seals and bearings. This contamination can accelerate wear and lead to early failure.
      Cavitation
      This phenomenon occurs when vapor bubbles form in the coolant near the pump’s impeller blades, causing shock waves when they collapse. Over time, this can lead to pitting and erosion of the impeller blades, reducing the pump’s effectiveness.
      Improper Coolant Mixture
      Many water-pump failures are caused by factors other than a faulty pump. Using the wrong coolant mixture or water-to-coolant ratio can cause corrosion and deposits within the pump, reducing its efficiency and lifespan. Additionally, incorrect coolant types can chemically react with pump components, causing deterioration.
      Bearing Failure
      Bearings within the water pump allow the impeller to spin smoothly. Over time, these bearings can wear out or fail – often due to tension from a misaligned or overtightened belt – leading to noise, leaks or a seized pump.
      Thermal Stress and Fatigue
      Constant exposure to fluctuating temperatures can cause the metal components of the water pump to expand and contract, leading to stress fractures and eventual failure.
      Leakage and Seal Failure
      The water pump’s seals are prone to wear and degradation over time, leading to coolant leaks. Such leaks not only reduce the efficiency of the cooling system but also can cause overheating and further damage to the water pump and surrounding components.
      Warning Signs
      Recognizing the early signs of water-pump failure can prevent more significant engine damage. Here are some key indicators:
      1. Coolant leak – One of the most straightforward signs is a coolant leak at the front of the vehicle, typically near the center. This can indicate a failed seal or gasket in the
      water pump.
      2. Overheating engine – If the water pump isn’t circulating coolant effectively, the engine temperature can rise, leading to overheating. Persistent overheating, especially under normal driving conditions, should prompt an inspection of the cooling system, including the water pump.
      3. Strange noises – A failing water pump can produce a variety of noises, such as whining or grinding, often due to bearing failure or an impeller rubbing against the pump housing.
      4. Steam from radiator – Seeing steam emanate from the radiator is a clear sign of overheating, which could be due to a malfunctioning water pump.
      5. Corrosion and deposit build-up – Visible corrosion or significant scaling on the water pump or surrounding components can indicate a failing pump, often due to improper coolant use or leaks that allow air into the system.
      While the service life of most OE water pumps should be 100,000 miles or longer, a cheap replacement pump might not make it 30,000 miles before it starts to leak. To keep your customers happy, it’s always a good idea to recommend a well-built, high-quality water pump from a trusted manufacturer. And when they’re replacing the water pump, you’ll want to check if they need any gaskets, hoses, coolant, belts or a thermostat.
      Also, if your customer who just purchased a new aftermarket water pump from you doesn’t flush the system and use new coolant when they install the new pump, there’s a good chance you’ll be hearing from them sooner rather than later with a warranty return. You should encourage your customers to follow the vehicle’s recommended flush-and-fill schedule, and to always use the coolant specified by the vehicle manufacturer. Most coolant suppliers do not recommend intermixing different brands or types of coolant in the same cooling system, due to the risk of coolant-gelling, corrosion or abrasion of water-pump seals.
    • By Alan
      To Importers in the Global Tire Industry:
      Please read this  as it might inspire you. Many international friends have been perplexed about how to import tires manufactured in China and sell them in their home countries. China's tire industry has experienced rapid growth over the past decade, marking a period of significant dividends. Many early investments in large factories have yielded substantial returns. However, with an increasing number of factories and brands, the competition has intensified. For those who wish to enter this industry but are unsure about how to proceed, please follow my website. I will periodically update it with information about China's tire industry for your reference.
      please follow: link hidden, please login to view
