Pump is a very widely used general machinery, is a machine to convert the mechanical energy of the original motor into liquid energy;
Pump performance is the external manifestation of the movement of liquid in the pump, and the movement of liquid is determined by the geometric shape of the flowing part.
Therefore, different from general machinery, the hydraulic runner designed by the pump has a unique core function in the structure, and the accuracy of the hydraulic runner after manufacturing and assembly is particularly important.
Hydraulic runner is a special geometrical shape existing in the parts by hot-working casting, and then after mechanical processing group
The location of the installation is determined in the whole machine. Therefore, it is the decisive factor to ensure the precision reserve of the pump and to meet the performance of the product to take reasonable technological measures in each process of production and manufacturing.
The hydraulic flow passage of the pump is mainly arranged on the pump body and the impeller. The flow passage of the pump body is fixed.
The impeller rotates with the axis. Due to the action of the impeller blade, the movement of the liquid in the impeller is caused by implicated motion and relative motion
A composite motion.
In the pump manufacturing process, often because of every aspect, caused the pump after processing, the assembly, the rotor's actual hydraulic flow design of the rotary center and geometric center misalignment (as shown in figure, figure -), such changes in the flow field inside the pump, the liquid is impact to the pump performance parameters such as flow rate, lift and efficiency, to reduce the energy consumption of shaft power of increase;
Also may cause the rotor force imbalance, shadow pump vibration, overload overcurrent and other faults.
      Certain statements herein are “forward-looking statements” within the meaning of the Private Securities Litigation Reform Act of 1995. Forward-looking statements are usually identifiable by words such as “anticipate,” “believe,” “could,” “estimate,” “expect,” “forecast, “guidance,” “intend,” “likely,” “may,” “plan,” “position,” “possible,” “potential,” “probable,” “project,” “should,” “strategy,” “target,” “will,” or similar language. All statements other than statements of historical fact are forward-looking statements, including, but not limited to, statements about the Company’s strategic initiatives, restructuring and asset optimization plans, store and location opening plans, operational plans and objectives, and statements regarding expectations for future business and financial performance, as well as statements regarding underlying assumptions related thereto. Forward-looking statements reflect the Company’s views based on historical results, current information and assumptions related to future developments. Except as may be required by law, the Company undertakes no obligation to update any forward-looking statements made herein. Forward-looking statements are subject to a number of risks and uncertainties that could cause actual results to differ materially from those projected or implied by the forward-looking statements. They include, among others, the Company’s ability to hire, train and retain qualified employees, the timing and implementation of strategic initiatives, risks associated with the Company’s restructuring and asset optimization plans, deterioration of general macroeconomic conditions, geopolitical factors including increased tariffs and trade restrictions, the highly competitive nature of the industry, demand for the Company’s products and services, risks relating to the impairment of assets, including intangible assets such as goodwill, access to financing on favorable terms, complexities in the Company’s inventory and supply chain and challenges with transforming and growing its business. Please refer to “Item 1A. Risk Factors” of the company’s most recent Annual Report on Form 10-K filed with the Securities and Exchange Commission (“SEC”), as updated by the company’s subsequent filings with the SEC, for a description of these and other risks and uncertainties that could cause actual results to differ materially from those projected or implied by the forward-looking statements.
