Lucas Oil Products recently announced the rollout of customer-centric QR codes across the entire lineup of racing, everyday car care, motorcycle, marine and industrial products.
Lucas Oil’s new QR-code smart packaging provides a simple and effective improvement to the customer experience, allowing the company to offer customers instant access to relevant product details, including:
  • Performance information
  • Complementary products
  • Environmental and ecological information
  • Disposal considerations
  • Formulation and chemical properties
  • Handling, transport and storage information
“We are excited for Lucas Oil to be among the first in our industry to include QR codes on packaging across our entire product lineup,” said Morgan Lucas, president of Lucas Oil. “In addition to providing instant access to practical product information, we’re excited to expand the available information to include rich media and videos featuring our in-house experts and the many professional mechanics, race teams, detailers and everyday automotive enthusiasts who rely on our products every day.”
      Lucas Oil has announced the latest addition to its vehicle performance product lineup: Lucas Emissions Clear. The company said this fuel and exhaust system cleaner addresses the need for effective solutions to reduce vehicle emissions and improve catalytic converter performance, helping vehicle owners meet strict emissions regulations.
      In a news release announcing the product, the company explained that Lucas Emissions Clear Fuel and Exhaust System Cleaner targets the entire fuel delivery system, removing harmful deposits that contribute to excessive exhaust emissions. By reducing particulate matter before it reaches the catalytic converter, the product helps extend its lifespan, optimizes combustion and improves emissions catalyst effectiveness. Formulated for easy integration into routine vehicle maintenance or pre-emissions testing, Lucas Emissions Clear is a one-tank treatment that provides emissions control, promotes cleaner air quality and is compatible with any gasoline engine, the company said.
      “A cleaner engine means a more efficient, more reliable car, and Lucas Emissions Clear delivers exactly that for drivers,” said
      link hidden, please login to view CEO Morgan Lucas. “We take pride in helping our customers save money on repairs and maintenance. Cleaner emissions not only contribute to a healthier environment, but also extend the lifespan of exhaust systems, providing long-term financial benefits for drivers and helping to meet more stringent regulations. With this product, we are making it easier and more affordable to maintain optimal performance and compliance with emissions standards.” Designed for environmentally conscious vehicle owners, fleet managers, automotive enthusiasts and drivers seeking improved fuel efficiency and performance, Lucas Oil said its Emissions Clear can cut harmful pollutants by up to 90% while delivering up to 5% improvement in fuel economy.
    • By abiztime
      5, Pallet
      How To: Change the Oil In a 2005 to 2015 Toyota Tacoma
