      Don’t forget to break in new catalytic converters
      link hidden, please login to viewannounced it is now offering Advantage automated series clutch and Cummins flywheel kits for the Eaton-Cummins Endurant automated manual transmission (AMT). The two will be sold in the same kit for the first time, according to Eaton. An
      link hidden, please login to viewnews release announcing the product launch explained that a flywheel, which is the interface between the engine and clutch, is bolted to the engine and spins when in operation. The clutch cover, which is bolted to the flywheel, also spins, and the driven disc of the clutch engages against the flywheel, which over time can cause wear. “Today’s manufacturers recommend that flywheels should be replaced, rather than the previous practice of resurfacing worn flywheels,” said Leandro Girardi, director, aftermarket, Eaton’s Mobility Group. “This ensures the flywheel fits correctly to engage with the clutch, and prevents fault codes, excessive wear and vibrations.”
      Eaton said its Advantage Automated clutch is the original equipment clutch used in the Endurant transmission.
    • By Phil
      I am looking to buy a clutch for a 2L diesel Jeep renegade. It’s Sm65RWW vin number 1C4BU0000FPC29385.
      1. Does anyone know of anything that would fit this that is available?
      2. Is this the correct vin number?
      Can’t break that crank bolt loose? You need a crank socket
      Australian clutch manufacturer Clutch Industries is launching two versions of its UniClutch system in the United States.
      UniClutch and UniClutch Sport will be the first iterations of the system to launch in the United States.
      UniClutch’s dual-core technology significantly boosts torque capacity without compromising drivability, according to the company.
      “Its one-of-a-kind, patented and adaptable design fits a multitude of vehicles, simplifies inventory management, expedites clutch replacement time, and lessens common installation problems,” Clutch Industries said in a news release.
      Compared to UniClutch, UniClutch Sport offers 15% more torque capacity and a sport-tuned pedal feel for more serious enthusiasts, the company noted.
      “We’re thrilled to introduce UniClutch to the United States after seeing strong early success in the Australia market,” said Brad Davis, CEO of Clutch Industries. “Auto repair shop feedback has been very positive, especially from technicians praising a faster and easier installation process. It’s also been our experience that shops can carry 20 times less inventory without impacting their ability to service any vehicle. We feel confident that UniClutch has the potential to redefine the performance clutch market with this revolutionary design.”
      Clutch installation typically is an expensive, complicated and lengthy process. UniClutch’s sealed design eliminates the need for flywheel machining, while the Flex Fit technology and pre-alignment allows for hassle-free “bolt-on” installation in minutes. The patented modular technology adapts to different engines and transmissions, greatly reducing installation times and empowering technicians to quickly service a wider range of vehicles.
      “For parts distributors, UniClutch’s patented Flex Fit technology will be transformative in inventory management, simplifying thousands of product variations to just a few,” Clutch Industries said. “This creates a solution for the complex ordering process for distributors, avoiding the challenges faced by an ever-changing supply chain. With UniClutch, parts distributors can provide consistent service to customers with a better return on investment.”
      A unique QR code found on every UniClutch contains manufacturing and performance specifications for each unit.
      At launch, UniClutch will retail exclusively at select NAPA Auto Parts stores across the United States and is available for purchase online via
