Centerforce - How A Clutch Works
- 110 views
- 199 views
- 259 views
- 247 views
- 217 views
Visit
link hidden, please login to viewannounced it is now offering Advantage automated series clutch and Cummins flywheel kits for the Eaton-Cummins Endurant automated manual transmission (AMT). The two will be sold in the same kit for the first time, according to Eaton. An
link hidden, please login to viewnews release announcing the product launch explained that a flywheel, which is the interface between the engine and clutch, is bolted to the engine and spins when in operation. The clutch cover, which is bolted to the flywheel, also spins, and the driven disc of the clutch engages against the flywheel, which over time can cause wear. “Today’s manufacturers recommend that flywheels should be replaced, rather than the previous practice of resurfacing worn flywheels,” said Leandro Girardi, director, aftermarket, Eaton’s Mobility Group. “This ensures the flywheel fits correctly to engage with the clutch, and prevents fault codes, excessive wear and vibrations.”
Eaton said its Advantage Automated clutch is the original equipment clutch used in the Endurant transmission.
