Throttle Position Sensor (TPS) Installation - Dodge Chrysler Plymouth 2.7L
- 93 views
- 185 views
- 195 views
- 177 views
- 208 views
MAHLE Lifecycle and Mobility (formerly MAHLE Aftermarket) announced the addition of its latest MAHLE Manifold Installation Set (MIS) – MIS19945. Available for GM 5.3L and 6.2L engines in various models of Cadillac, Chevrolet and GMC-branded vehicles, the set includes all the gaskets and seals for a technician to properly re-install the intake manifold, the company said.
The MAHLE gasket MIS portfolio represents the most complete gasket kits available on the market today, covering more than 5 million applications in operation across North America,
link hidden, please login to view announced said in news release. “When a technician invests in one of our MAHLE gasket kits, they can trust that every part needed for the job from beginning to end is packed nicely in the blue MAHLE box,” said Ron McCrum, gasket team product manager, MAHLE Lifecycle and Mobility, North America. “True to OE Form, Fit & Function, customers never have to look elsewhere for a missing component and our easy- to-follow instructions make the installation process simple and convenient.”
Each
link hidden, please login to view gasket MIS set includes everything from valve cover gaskets, plenum gaskets and coolant gaskets to injector O-rings, water and emissions connections, and other miscellaneous gaskets. The post
By Dorman Products
Repair for sloppy or broken Dodge/Ram shifter bracket | Dorman OE FIX 905-670 & 905-671
By Dorman Products
Highlighted Part: Sliding Door Handle Repair Kit for Select Chrysler and Dodge Models
