Dodge Ram Cummins 5.9 Fuel Pressure Sensor Replacement
- 68 views
- 176 views
- 160 views
- 189 views
- 158 views
To kick off its yearlong
link hidden, please login to view celebration, Federated has brought back the Federated Free Fuel Fridays contest. This time, there will be a total of 40 winners of gift cards that can be used for free fuel. Each Friday through April 11, Federated will announce four randomly selected winners on its link hidden, please login to view and link hidden, please login to view Facebook pages. A $50 gift card will be sent to each of the lucky winners. “As we celebrate 40 years of Federated, we knew we had to bring back one of our most popular contests for those who follow Federated on Facebook,” said John Marcum, director of marketing for Federated Auto Parts. “It’s easy to enter Federated Free Fuel Fridays. With a total of 40 lucky winners, a lot of free fuel will be awarded in recognition of this major milestone.”
To enter, visit Federated on Facebook or click on the special
link hidden, please login to view or link hidden, please login to view contest links and fill in the entry form. Extra entries can be earned by sharing the contest with Facebook friends. Winners will be announced each Friday starting Feb. 7, with the final four winners announced April 11, 2025. The post
Series Supplier
