Ignition Coil Installation - Dodge Chrysler Plymouth 2.7L
- 68 views
- 179 views
- 159 views
- 173 views
- 167 views
MAHLE Lifecycle and Mobility (formerly MAHLE Aftermarket) announced the addition of its latest MAHLE Manifold Installation Set (MIS) – MIS19945. Available for GM 5.3L and 6.2L engines in various models of Cadillac, Chevrolet and GMC-branded vehicles, the set includes all the gaskets and seals for a technician to properly re-install the intake manifold, the company said.
The MAHLE gasket MIS portfolio represents the most complete gasket kits available on the market today, covering more than 5 million applications in operation across North America,
link hidden, please login to view announced said in news release. “When a technician invests in one of our MAHLE gasket kits, they can trust that every part needed for the job from beginning to end is packed nicely in the blue MAHLE box,” said Ron McCrum, gasket team product manager, MAHLE Lifecycle and Mobility, North America. “True to OE Form, Fit & Function, customers never have to look elsewhere for a missing component and our easy- to-follow instructions make the installation process simple and convenient.”
Each
Repair for sloppy or broken Dodge/Ram shifter bracket | Dorman OE FIX 905-670 & 905-671
Highlighted Part: Sliding Door Handle Repair Kit for Select Chrysler and Dodge Models
Upgraded repair for Dodge/Ram shift lever brackets | Dorman OE FIX 905-670 & 905-671
