K&N: Air Intake
- 67 views
- 158 views
- 173 views
- 167 views
- 175 views
By CALEPH Auto Parts
Steps to clean your car's air filter:
1. Find the location of the air filter: It is usually located in the engine compartment, near the side of the engine.
2. Make sure the engine is cool: Before checking or cleaning the air filter, make sure the engine has cooled down completely to avoid burns.
3. Open the hood: Find and open the hood so that you can access the air filter.
3. Locate the air filter box: The air filter is usually located in a black plastic or metal box.
4. Remove the air filter box: Unscrew or unfasten the screws or clips that secure the air filter box.
5. Remove the old filter: Remove the old air filter from the box, being careful not to damage the filter box.
6. Check the condition of the filter: If there is only a small amount of dust on the filter, you can clean it. If the filter is already very dirty or damaged, it is recommended to replace it.
7. Clean the filter: If you decide to clean the filter, you can blow it from the inside out with compressed air to remove dust. Do not use water or liquid cleaners as they may damage the filter.
8. Check the integrity of the filter: After cleaning, check the filter for tears or holes that may affect its performance.
9. Reinstall the filter: If the filter is in good condition, put it back into the filter box and make sure it is properly seated.
10. Reinstall the filter box: Replace the filter box cover, making sure all screws and clips are secure.
11. Close the hood: After cleaning or replacing, close the hood.
Click the link to learn more:
