How To: Test Glow Plugs
- 67 views
- 218 views
- 206 views
- 176 views
- 158 views
Chassis
1.) Who is right?
A. A only
B. B only
C. Both A and B
D. Neither A nor B
A. Steering
B. Suspension
C. Ride control
D. Alignment aids
D. All of the above
A. Adjustments to ride height
A. Springs
B. Ball joints
C. Control-arm bushings
D. Shock absorbers
A. Parts Specialist A only
B. Parts Specialist B only
D. Neither one
A. Shock absorber
B. Ball joint
C. Control arm
D. Sway bar
A. Worn shock absorbers
B. Loose ball joint
C. Worn control arm bushings
D. Leaky strut mount
Cooling Systems
A. PAG
B. Mineral
C. Ester
D. Vacuum
A. Drive belt
B. Front shaft seal
C. Cycling clutch switch
D. Condenser
D. Pump noise
D. Be replaced once a year
ANSWERS: 1-A, 2-D, 3-B, 4-C
Emissions-Control Systems
C. Engine load changes
A. EGR valve
B. PCV valve
C. EVAP canister
D. Catalytic converter
A. EGR system
B. Particulate filter
C. Catalytic converter
D. All of the above
ANSWERS: 1-C, 2-A, 3-A, 4-B
Engine Mechanical
A. A only
B. B only
C. Both A and B
D. Neither A nor B
C. Chrome-plated iron rings
D. Plain cast-iron rings
D. A bent pushrod
A. Cam followers
B. Flat tappet cams
C. Roller lifters
D. Stamped-steel rocker arms
D. A bent pushrod
bearings. Who is right?
C. Both A and B
D. Neither A nor B
D. All of the above
A. Make, model and year.
B. Vehicle build date
C. Model year
D. Vehicle VIN
ANSWERS: 1-A, 2-B, 3-C, 4-C 5-D, 6-D, 7-B, 8-A
Suspension, Steering & Wheels
A. A only
B. B only
C. C Both A and B
D. Neither A nor B
A. True
B. False
A. Ride height
B. Steering return
C. Shocks or struts
A. A only
B. B only
C. Both A and B
D. Neither A nor B
ANSWERS: 1-A, 2-A, 3-D, 4-C
Transmission
A. Driveshaft
B. Drive axle
C. Clutch
D. Differential
A. Failed inner CV joint
D. Worn brake pads
A. Pressure plate
B. Flywheel
C. Release bearing
D. Clutch disc
A. Worn pilot bearing
B. Worn pressure plate
C. Worn release bearing
D. Worn clutch disc
A. 30,000 miles
B. 60,000 miles
C. 90,000 miles
6.) Parts Specialist A says that diaphragm-style clutches have more springs than a finger-style clutch. Parts Specialist B says that finger-style clutches require less pedal effort. Who is right?
A. A only
B. B only
C. Both A and B
D. Neither A nor B
A. ATF+4
B. Dexron VI
C. Mercon V
D. Type F
