How To: 303 Touchless Sealant
- 67 views
- 167 views
- 175 views
- 159 views
- 189 views
Dana Incorporated has added RTV sealing product Victor Reinz Reinzosil to its Spicer commercial-vehicle (CV) service kits.
“Spicer CV service kits are designed to increase uptime and make the service and repair process more efficient,” said Bill Nunnery, senior director, sales and marketing, global aftermarket for Dana. “Now Dana customers will not only get all the components they need in one kit, but it will include Reinzosil silicone, the one-product solution that can take the place of more than a dozen RTV varieties and does not affect the warranty if used with Spicer CV kit products.”
Victor Reinz Reinzosil room-temperature vulcanizing (RTV) silicone is resistant to fluids, including mineral and synthetic oils, lubricants, gasoline, diesel fuel, greases, water and detergents. The sensor-safe RTV silicone provides superior resistance under load, even at high temperatures, and is ideal for use on two-dimensional flat surfaces where there is a sealing gap, according to the company.
The product also is suitable for rough sealing surfaces and can be used universally for all motor and vehicle makes.
“Unlike other RTV products, which may incorporate plasticizers of minor quality such as calcium carbonate or limestone, Reinzosil sealant will not shrink or lose weight in high-heat environments,” Dana asserted in a news release.
In addition to newly added Reinzosil silicone, Spicer CV kits contain key service components such as an oil seal, bearing cup, bearing cone, shim, thrust washer, flat washer, lock washer, D washer, snap ring, O-ring, V-ring, dowel pin and spacer, according to Dana.
By OReilly Auto Parts
Get 303® Automotive Protectant now at O'Reilly Auto Parts! 303® Protectant keeps your car looking new by protecting vinyl, ...
Just like your skin, the sun's UV rays can cause damage to your car. Causing your car's plastic or rubber to fade, crack, and ...
Proper care of your vinyl or fabric convertible top or tonneau cover is important to extend its life. Check out the 303 Convertible ...
