Meguiar's: Ultimate Wash & Wax
- 67 views
- 157 views
- 218 views
- 206 views
- 176 views
By NAPA
Benefits of a Ceramic Car Wash
The only thing that can make cruising around in your prized ride more delightful is cruising around with it stunningly shiny. Properly washing and detailing your vehicle at home is a great way to keep it looking the way you want. And, because an at-home car wash means you’re going over your vehicle from top to bottom, you can check for any cosmetic issues like damaged trim or chipped paintwork.
If you’ve stuck to the basic hands-free automated car washes in the past, you may have noticed a range of cosmetic issues surfacing after the dirt and grime is rinsed away. While swirling and micro scratches are just a bothersome eyesore, chipped paint can expose the metal underneath to rust and corrosion. At best, this can decrease your resale value and, at worst, you’re dealing with costly body damage.
The latest advancements in car wash detergents and polymers have led to improvements in the way we maintain our vehicles, both with professional car washes and at home. Enter, the ceramic car wash. Check out all the benefits of ceramic coating and ceramic car washes here plus shop NAPAOnline.com for everything you need to get a resilient, brilliant shine on your vehicle.
What is a Ceramic Coating and How Does It Perform?
In the 1900s, enamel coating was used to help protect vehicles from rust and corrosion. As automotive paint developed,
link hidden, please login to view became the most common way to safeguard the paintwork and buff out small scratches. Harvested from palm trees native to Brazil, this wax has a wide variety of uses in the cosmetics, food and medical industries. In the 1950s, scientists developed blends of silicone dioxide and titanium dioxide that would one day become the link hidden, please login to view we know today. Then came the 1980s, a big decade for vehicle wax (and not just thanks to the “wax on, wax off” technique featured in “The Karate Kid”)! Teflon coatings were developed; however, these coatings deteriorate with repeated washing and only provide approximately six months of durability. Then a new ceramic coating known as nano ceramic hit the market. Using a synthetic silicon dioxide blend, this unique formula creates a chemical bond with automotive paint, and the resulting polymer layer provides a super-protective lacquer-like coat with a brilliant candy-shell shine that really turns heads.
A nano-ceramic coating is the perfect addition to any car enthusiast’s cleaning routine. The initial application fills in swirling and micro scratches plus the hydrophobic properties repel water and protect against harmful UV rays. Best of all, ceramic coatings help maintain a beautiful finish for months and even years at a time. With proper maintenance, you can enjoy fewer and less labor-intensive vehicle washes.
Because applying ceramic coatings requires a long curing time in a stable environment, many drivers avoid this process at home by having the formulation applied professionally. But for those brave souls, NAPAOnline.com has
link hidden, please login to view, ceramic car wash and link hidden, please login to view, as well as soaps that work with your existing ceramic coat, such as link hidden, please login to view. You can find every product you need to apply and maintain a successful ceramic coat at NAPA. NAPA Expert Tips: Sustaining That Showroom Shine link hidden, please login to view
Even if you choose to skip a ceramic coating altogether, you can still get great results at home using a
link hidden, please login to view or ceramic car wash like the link hidden, please login to view and link hidden, please login to view. The key to getting all the benefits of a ceramic car wash is using the proper
link hidden, please login to view. Use two link hidden, please login to view outfitted with link hidden, please login to view so the water does not fill with small contaminants that can cause swirling and micro scratches to appear on paintwork. Grit guards keep dirt trapped at the bottom of the bucket and out of the washing mixture and rinsing water. A good link hidden, please login to view, a link hidden, please login to view and link hidden, please login to view delivers a professional-grade vehicle wash at home. Tip #1: Always use a foaming prewash. Using a link hidden, please login to view that hooks directly to your hose nozzle makes this first step easy. Tip #2: Wash in the shade. To avoid UV damage and water spots, you should try to wash your vehicle in the shade or in the early morning or late evening. Worst case, keep a pop-up tent on hand to make a perfect shady area for wash days, right in your driveway. Tip #3: Wash tires separately. Start with washing your tires because they are the dirtiest parts of your vehicle, and you don’t want all that dirt and grime to end up back on your freshly washed vehicle. Begin with a preliminary cleaning, then add polishes and link hidden, please login to view once the whole vehicle is cleaned and waxed. Tip #4: Avoid washing with circular motions. If you follow these steps, you should have little or no debris contacting your paintwork. However, if there is a bit of debris present, the micro scratches will appear less obvious if they are in a line rather than a light-diffusing swirl pattern. The experts at NAPA know how much fun it is to drive a pristine, gleaming machine. A well-maintained vehicle inside and out will love you back and get you down the road longer. So, let us help you keep your ride shining and protected. Shop our range of ceramic car washes and ceramic coating kits plus get in and out faster than ever! Participating NAPA Auto Parts stores now offer a convenient
link hidden, please login to view option so you can get back on the road in no time. Featured image courtesy of
link hidden, please login to view. You Might Need These
link hidden, please login to view link hidden, please login to view link hidden, please login to view link hidden, please login to view link hidden, please login to view link hidden, please login to view
The KBS Coatings Ultimate Frame Coater Kit provides everything needed for ultimate inside-out rust protection for auto frames, auto bodies and more.
The easy-to-use DIY kit employs the KBS 3-Step System combined with KBS Cavity Coater to prepare and coat up to 50 square feet of metal, according to the company.
KBS Klean, a nontoxic and biodegradable super cleaner, removes dirt, grease, grime and other contaminants. Next, water based and biodegradable RustBlast effectively dissolves rust and corrosion while etching metal for best adhesion of KBS RustSeal. RustBlast also leaves a zinc phosphate coating to stop flash rust from forming.
The third step is RustSeal, a rust-inhibitive and preventative paint that’s applied by brush, roller or spray gun. RustSeal chemically bonds to metal, including rusted metal, to isolate it from moisture and oxygen. Without those present, metal can’t rust.
RustSeal comes in 11 colors and flows out to provide a beautiful, smooth finish that resembles a powder coat. RustSeal provides a flexible, yet rock-hard barrier that’s extremely resistant to abrasion and impact – so it won’t crack chip, or peel, according to the company.
For ultimate protection, KBS Cavity Coater Aerosol provides rust protection in hard-to-reach areas such as inside frame rails, rocker panels, doors, tailgates and more. Cavity Coater, a self-healing corrosion-inhibiting coating (CIC), provides long-term protection and wicks into welds and seams that primers and top coats can’t reach.
For especially hard to-reach-areas, the KBS Cavity Wand is provided to extend the reach of aerosol Cavity Coater with a reusable 48-inch hose featuring a 360-degree spray tip.
For more information, visit
link hidden, please login to view or call 888-531-4527. The post
By NAPA
Get the Best of Both Worlds
Are you looking for the perfect vehicle accessory for that new driver in your life? Spread some holiday cheer by shopping the best vehicle add-ons for those who aren’t quite sure what they need! We’ll walk you through the best tips and gift ideas for car accessories as you shop NAPA’s selection of
link hidden, please login to view with Free One-Day Shipping. With an
link hidden, please login to view that can seriously enhance driving conditions, you can easily improve cabin comfort, upgrade navigation assistance and make that ride your own with personalized flair. Those who are avid vehicle modifiers probably already know what they need to round out their ride, but when it comes to first-time drivers, it’s nice to give them a nudge in the right direction. While safety always is the priority when it comes to driving success, there’s a ton of room to boost levels of comfort, functionality and preparedness while truly elevating a beginning driver’s experience on the road. The Power of Personalization link hidden, please login to view
To many, vehicles start out as a semi-blank canvas ready for customization with performance enhancers, accent pieces, electronic capability, comfort upgrades, interior protection and so much more. Gone are the days when your vehicle was simply a transportation vessel and not an extension of the driver’s personality. Now, more than ever, automotive enthusiasts and average car owners alike are flocking to the automotive accessories market to help them create their ideal vehicle beyond the manufacturer’s confines.
But when you think of ‘vehicle customization,’ you might envision outdated
link hidden, please login to view, hanging ornaments (like those fuzzy dice) or classic bumper stickers. There’s nothing inherently wrong with these add-ons, but they only scratch the surface of the vehicle accessorizing world. Nowadays, you can easily shop for and install custom-fitted link hidden, please login to view, link hidden, please login to view, link hidden, please login to view and LED add-ons that transform a commuter ride into an off-road, road tripping, beach cruiser machine. If you’re looking for practical and unbeatable upgrades, there’s no better way to level up your ride than with
link hidden, please login to view or link hidden, please login to view. Gifting a set of quality interior seat covers or floor mats are an excellent and sensible gift that’ll most definitely get used, especially by those who want to keep the investment of their ride intact. Modern Upgrades for the Beginner Car
Now, more than ever, people are demanding that their vehicles keep up with their lifestyles, which means they’re not willing to compromise when a higher standard of luxury and personalization exists! However, more likely than not, someone’s first car is not a high-end vehicle decked out in the latest electronics. They might sport an older model with an analog radio and cigarette lighters—a hand-me-down ride that’s still kicking but could use a little TLC to make it feel ‘new’ again. That gives you the perfect opportunity to gift some car accessories that bring modern touches to an old reliable machine.
While most newer vehicles come equipped with Bluetooth radio capability, some drivers still don’t know the beauty of an upgraded stereo system with clean, rich sound quality and wireless connection. If you’re shopping for someone who would appreciate a fine-tuned radio for jam-sessions or crisp voice calls, shop NAPA’s selection of
link hidden, please login to view and pick up something like the link hidden, please login to view for an affordable audio upgrade. For more tips on tech upgrades for older vehicles, check out NAPA’s article on link hidden, please login to view Safety Enhancers That Offer Function and Flair
Consider a classic
link hidden, please login to view or link hidden, please login to view for a more budget-friendly console gift. Because many drivers use smartphones as a tool for navigation, these products are vital for a hands-free driving experience.
link hidden, please login to view is another great dashboard improvement to illuminate your instrument cluster and make it easy to see at night, plus it just looks cool! There are tons of LED add-on options for link hidden, please login to view, link hidden, please login to view, link hidden, please login to view, link hidden, please login to view and more. Lighting upgrades boost safety and style, thus it is a great gift choice for new drivers who can use all the visibility they can get! Whether you’re a new driver or not, it’s always important to stay well-stocked with emergency preparedness supplies. These are not the flashiest type of accessories, but they are incredibly useful and easily hold the power to avoid an inconvenient or dangerous situation. A can of
link hidden, please login to view, link hidden, please login to view and some link hidden, please login to view are just a few essentials that you should include in link hidden, please login to view. You can’t go wrong with an assortment of affordable, stylish and functional aftermarket accessories that are sure to excite anyone about customizing their ride. There’s no better way to feel like your vehicle is all your own! Remember to shop NAPAOnline.com for some automotive holiday cheer and receive one NAPA Rewards point for every dollar you spend.
Photo courtesy of
By Garage Gurus
Designed to display voltage signals on a graph, an oscilloscope is a valuable tool in diagnosing electrical issues on a vehicle.
