1994 Chevy suburban,  It's been having trouble starting lately.  Turn the key and nothing, the fuel pump runs and all the lights work. Sometimes banging the steering column where the blinker and light switch is and sometimes it'll work.
 Most days it starts up fine. Im convinced it has a mind of its own!  But it looks like a starter wire might be lose going to the starter. haven't had the time to check it out good yet.
 Any ideas what could be causing it IF it isn't the wire?
Banging the steering column would make me think that the ignition switch is faulty. Maybe its a coincidence?  Could it be an issue with your starter? Is the solenoid clicking at all? Could be that the starter is landing when shut off on a low spot and tapping it with a hammer sometimes will get it to start. If that's the case, you have a bad starter.
No, the only thing that makes a noise when we turn the key is the fuel pump running. no clicking at all.
 And other times it fires right up.
tightened up the starter wire, no longer does it, but then again some times it would start other times it won't.
 fingers crossed :D
  • 2 months later...
Well, it's doing it again. And it doesn't start only when the steering wheel DOESN'T lock. And I wiggle the wires and it'll fire right up.
 I'm wondering if the wires themselves are  falling apart inside the coating ??
Edited by MCT
  • 4 months later...
  On 5/10/2018 at 9:37 PM, MCT said:
well it hasn't done it in 9 days, so i think she's fixed!
Expand
I'm pleased to hear that. Anyway, I believe that could be the wire that goes to spark are not properly connected or the spark plug it self has lot of dirt.
      Upgraded replacement for Suburban/Yukon/Tahoe door handles | Dorman OE FIX 80994 & 80995
    • By MCT
      The power steering hoses run fairly close to the left side exhaust manifold. And the rubber seems to start suffering after 2 years or so and cracking... Replaced another one today.
      I was wondering if that exhaust wrap material coukd be wrapped around the rubber portion of the hoses to help protect it from the heat?
    • By MCT
      Alright, my mother's car has been acting up...
      She went to town day before yesterday, called and said it would start, then die... Then no start at all. got there,it wouldn't even hit with starting fluid into the air intake. A few minutes later, fired right up, ran great.
      she drove as we followed her, then it died again on a feeder road, luckily there were plenty of places of business to pull into, just so happened, it died right in front of a car dealership.
      any how, after it set a minute, fired back up.. Ran great. Drove it around yesterday. Ran flawless.
      My mom went to pickup groceries last night, called, said it died on her.
      Me and my brother grabbed a tow strap and took off... Got there, wouldn't hit a lick.
      Brought it home after it had cooked off, fired up. Ran great.
      This morning we're looking at it, we let it idle for a bit, it died.
      Hooked up  my trusty spark tester to a plug wire....no spark...
      After it set for about 3 minutes, we tried to start it with the tester hooked up to the wire, and plug..It fired once then nothing....after it cooled again, fired right up.... I told my dad, next time it dies, check the spark coming from the coil to The distributor, as one plug wire from the coil to The distributor. So it died again, hooked the spark tester inline from the coil to distributor..Spark!!!  Took the tester off and reinstalled the coil to distributor wire and it fired right up.... So sometimes when it dies, it fires right up, other times, it won't and has no spark.
