Starfire Products
STARFIRE’s Tec-A line of products for front-line maintenance and service is growing with the addition of three new offerings:
  • STARFIRE TEC-A-Carb Carb/Choke Cleaner gets to hard-to-reach passages and sliding surfaces to eliminate carbon, gum, sludge, varnish or corrosive deposits that interfere with performance. It is safe for oxygen sensors and catalytic convertors.
  • STARFIRE Tec-A-Nut Penetrating Oil cuts through grease and corrosion while dissolving rust to free seized components. It also is effective for water displacement, leaving a protective film in cracks and crevices to prevent rust or corrosion.
  • STARFIRE Tec-A-Glass is ammonia-free and quick-drying. Its clinging foam formula quickly removes fingerprints, smudges, light grease, bugs, dirt and smoke residue from windows, mirrors and other glass surfaces without rinsing. It leaves a streak-free shine and a pleasant, fresh aroma.
The new additions join STARFIRE Tec-A-Brake Low VOC Brake & Parts Cleaner and Tec-A-Start Starting Fluid in the company’s line of maintenance and service products.
All STARFIRE lubricants and additives meet or exceed manufacturer requirements. For bulk orders or technical specifications, or to locate a local distributor, call 888-258-8723 or visit starfire1.com/contact.php.
      Certain statements herein are “forward-looking statements” within the meaning of the Private Securities Litigation Reform Act of 1995. Forward-looking statements are usually identifiable by words such as “anticipate,” “believe,” “could,” “estimate,” “expect,” “forecast, “guidance,” “intend,” “likely,” “may,” “plan,” “position,” “possible,” “potential,” “probable,” “project,” “should,” “strategy,” “target,” “will,” or similar language. All statements other than statements of historical fact are forward-looking statements, including, but not limited to, statements about the Company’s strategic initiatives, restructuring and asset optimization plans, store and location opening plans, operational plans and objectives, and statements regarding expectations for future business and financial performance, as well as statements regarding underlying assumptions related thereto. Forward-looking statements reflect the Company’s views based on historical results, current information and assumptions related to future developments. Except as may be required by law, the Company undertakes no obligation to update any forward-looking statements made herein. Forward-looking statements are subject to a number of risks and uncertainties that could cause actual results to differ materially from those projected or implied by the forward-looking statements. They include, among others, the Company’s ability to hire, train and retain qualified employees, the timing and implementation of strategic initiatives, risks associated with the Company’s restructuring and asset optimization plans, deterioration of general macroeconomic conditions, geopolitical factors including increased tariffs and trade restrictions, the highly competitive nature of the industry, demand for the Company’s products and services, risks relating to the impairment of assets, including intangible assets such as goodwill, access to financing on favorable terms, complexities in the Company’s inventory and supply chain and challenges with transforming and growing its business. Please refer to “Item 1A. Risk Factors” of the company’s most recent Annual Report on Form 10-K filed with the Securities and Exchange Commission (“SEC”), as updated by the company’s subsequent filings with the SEC, for a description of these and other risks and uncertainties that could cause actual results to differ materially from those projected or implied by the forward-looking statements.
      link hidden, please login to view announced its new CO₂-reduced filters impregnated with plant-based raw materials, manufactured using renewable energy and packaged in sustainable, recycled material. Filters with cellulose media have previously been impregnated with fossil-based phenolic resin, which provides stability, rigidity and chemical resistance, according to
      link hidden, please login to view, which said it has partially replaced this crude oil-based treatment with the plant-based raw material lignin, a natural product contained in wood. Lignin is what makes wood stable and can also have the same effect on filter media, the company explained. This technology is initially being used in selected MANN-FILTER air and oil filters, with more filters will follow. As a result, MANN+HUMMEL said it is reducing the CO2footprint of the relevant lignin impregnation during production by up to 5 percent compared to regular phenolic resin impregnation. In addition, this reduces the amount of crude oil used for impregnation by around 27 percent.
      The calculation of the CO₂ values and the calculation method for determining the crude oil savings have been externally verified and validated by ClimatePartner, a German organization that supports companies in calculating, reducing and offsetting CO₂ emissions and offers climate neutrality labels.
      Thanks to the switch to lignin, the MANN-FILTER C 17 237 air filter, for example, saves 3.93 tons of CO₂ and more than 4,500 liters of crude oil annually, based on 2024 sales figures, the company said, with the material being used coming from certified sources. Lignin is produced in large quantities as a waste product in paper and pulp production—several million tons are generated worldwide every year.
      In the independent aftermarket, the innovative and more sustainable air filters are now available as MANN-FILTER applications for almost 70 million cars and transporters in Europe, while oil filters are ready to use for almost 17.6 million vehicles, the company said. The improved impregnation will now be incorporated into defined series products, with MANN-FILTER products are gradually being converted to lignin.
      “This means that customers do not have to choose between different versions, no additional storage space is needed, and no additional part numbers are required,” explains Dr. Lars Spelter, lead engineer for filtration materials at MANN+HUMMEL. “Everything should be kept as simple as possible for our customers. Externally, the partially plant-impregnated filters differ from the conventional ones. They are slightly brownish due to the characteristic color of the lignin they contain and they have a pleasant, natural odor. The innovative products are easy to recognize by the green leaf pictogram on the packaging. Our lignin impregnation is a successful example of how ambitious CO2 reduction targets in product development can also be implemented in series products.”
      The new filters combine sustainability with consistently high performance in the usual original equipment quality and meet the strictest requirements of the automotive industry, MANN+HUMMEL explained.
      To further reduce CO2 emissions during production, MANN+HUMMEL added it will only use electricity from renewable sources or a combination of green electricity and certificates and guarantees of origin from hydro, solar, or wind power plants from 2025. Energy sources for the generation of process heat are also to be CO2 neutral from 2035 in order to achieve a significant milestone in CO2-free production.
      link hidden, please login to view Professional Series fuel pump modules in March, 2025. Fuel pump assembly application coverage includes several Audi, Toyota, Infiniti and Nissan models.
      APA announced Axon US as the newest addition to TruStar. Founded in 2008, Axon US began with a small office in Midtown Manhattan and a basement workspace in Long Island City. Its founder, Siyao Ji, started Axon independently, building the company from the ground up. He established the company with a clear vision: to create a streamlined supply chain system that efficiently meets the needs of the auto industry.
      Axon initially operated solely as an online retailer but expanded its presence to better serve customers through offline channels. In 2021, the company moved into a 20,000 sq. ft. warehouse in Queens to accommodate its growing inventory and improve order fulfillment. Today, Axon US serves both online and offline customers through its warehouse showroom, with plans to open a dedicated brick-and-mortar store that is aiming to open in Q4.
      link hidden, please login to viewsaid Natasha Huang has been with Axon US for about six months as a buyer. Previously a salesperson for an Asian auto parts wholesale distributor, she joined Axon to deepen her understanding of the auto supply chain and continue growing in the industry. “Axon US is eager to expand its presence in the automotive industry by joining TruStar, fostering connections with other members and strengthening relationships with key brands,” said Huang.
      “We are excited to welcome Axon US to the TruStar family and look forward to the collaboration and innovation they will bring to our network,” said Steve Tucker, President of APA.
