Now there’s a way to ensure more reliable power from EcoBoost-powered 2.3-liter engines with the introduction of MAHLE Motorsport’s 4032 alloy Ford EcoBoost 2.3L PowerPak Plus Piston kit.
Designed for heavy-duty applications in which the OE cast piston has been known to fail, MAHLE Motorsport has introduced a 4032 alloy option that not only adds much-needed strength, but also allows for a tighter piston to wall clearance for quieter cold startup, according to the company.
MAHLE Motorsport’s 2.3L PowerPak kit is loaded with value-added features for reliable power production for any 2.3-liter EcoBoost engine, according to MAHLE.
To help correct problems associated with the OE cast piston, MAHLE Motorsport manufactured this kit with a thick slipper-skirt-style forging and an enhanced OE crown design with increased radius for improved strength. Other special features include a heavy-duty 0.200-inch wall thickness; H13 tool steel wrist pins; and a hard anodized top ring groove that is ideal for extreme-duty applications.
The pistons are engineered with thick 0.235-inch top and 0.200-inch second ring lands. The pistons are designed for OE 149.3-millimeter-length connecting rods and OE 22.5-millimeter wrist pins and an OE 32.8-millimeter compression height. Valve pockets and depth accommodates both the 2-liter and 2.3-liter OE EcoBoost heads with a 9.5:1 compression ratio.
The new PowerPak Plus kit is available in 87.51-millimeter (No. 197937145) and 88-millimeter (No. 197937165) bore sizes and includes a nitrided steel 1.2-millimeter top, 1.2-millimeter second, 2.8-millimeter oil-ring set. The pistons are coated with MAHLE’s unique GRAFAL anti-friction skirt coating and phosphate to prevent microwelding and pin galling.
For more information, visit
, or call MAHLE Motorsport toll-free at 888-255-1942.
      link hidden, please login to view link hidden, please login to view link hidden, please login to view announced the release of 181 new numbers for January/February 2025. The company said all units are in stock and ready to ship. The new parts include:
      30 Complete Strut Assemblies 11 Shock Absorber Assembly Kits 3 Heavy Duty Shock Absorbers 72 Suspension Struts 40 Shock Absorbers 25 Lift Supports
      link hidden, please login to viewsaid these new part numbers cover over 30 million vehicles currently on the road in the U.S. and Canada. They include models like the Audi A4, Chevrolet Cruze, Chevrolet Silverado, Dodge Charger, Ford Explorer, Nissan Pathfinder, Toyota Tacoma and more. The post
      Lucas Oil has announced the latest addition to its vehicle performance product lineup: Lucas Emissions Clear. The company said this fuel and exhaust system cleaner addresses the need for effective solutions to reduce vehicle emissions and improve catalytic converter performance, helping vehicle owners meet strict emissions regulations.
      In a news release announcing the product, the company explained that Lucas Emissions Clear Fuel and Exhaust System Cleaner targets the entire fuel delivery system, removing harmful deposits that contribute to excessive exhaust emissions. By reducing particulate matter before it reaches the catalytic converter, the product helps extend its lifespan, optimizes combustion and improves emissions catalyst effectiveness. Formulated for easy integration into routine vehicle maintenance or pre-emissions testing, Lucas Emissions Clear is a one-tank treatment that provides emissions control, promotes cleaner air quality and is compatible with any gasoline engine, the company said.
      “A cleaner engine means a more efficient, more reliable car, and Lucas Emissions Clear delivers exactly that for drivers,” said
      link hidden, please login to view CEO Morgan Lucas. “We take pride in helping our customers save money on repairs and maintenance. Cleaner emissions not only contribute to a healthier environment, but also extend the lifespan of exhaust systems, providing long-term financial benefits for drivers and helping to meet more stringent regulations. With this product, we are making it easier and more affordable to maintain optimal performance and compliance with emissions standards.” Designed for environmentally conscious vehicle owners, fleet managers, automotive enthusiasts and drivers seeking improved fuel efficiency and performance, Lucas Oil said its Emissions Clear can cut harmful pollutants by up to 90% while delivering up to 5% improvement in fuel economy.
      Each
