Remember the good old days when you started a vehicle by inserting a metal key into the ignition lock cylinder? Those cars, trucks and SUVs are still out there (adorable, isn’t it?), but imagine a future without the collective jingle-jangle of millions of mechanical car keys in our pockets – because it seems we’re moving in that direction at a rapid clip.
The pace of change really picked up in the 1990s. That’s when remote keyless-entry fobs – you know them as “key fobs” – went mainstream. These handy devices enabled motorists to lock and unlock their car doors and trunks remotely, with the same familiar thumb motion that they’d been using to change channels on their television sets for years.
With the rise of proximity-key systems, we’ve moved into the next phase of the evolution: keyless ignition. In this phase, the key fob is – for all intents and purposes – rendering the mechanical key obsolete. As long as the device is somewhere inside the vehicle, the driver can start the engine by pushing a button or turning a rotary switch. According to the National Highway Traffic Safety Administration, keyless ignition emerged in the early 2000s on some luxury models. Today, however, we’re seeing them on more and more mainstream vehicles – and it doesn’t seem like we’re going back.
Because technology doesn’t seem to know when to stop, even the key fob (or “smart key,” as they’re calling it now) might become a relic of the past. In 2020, Apple introduced the digital car key. If you have an iPhone XS or later, an Apple Watch Series 5 or later and a compatible car (a BMW built in summer 2020 or later), you can use your iPhone or Apple Watch to unlock and start your car – sans key fob.
The digital key uses near-field communication in its first iteration. However, as part of its upcoming iOS 15 software update, Apple in June said its “digital car keys get even better with support for ultra-wideband technology, so users can securely unlock and start their supported vehicle without removing their iPhone from a pocket or bag.”
If you’re not an Apple user, take heart: Hyundai’s version of the digital key, which debuted with the 2020 Sonata, is compatible with most Android phones.
So what does all this mean for the automotive aftermarket?
From a 20,000-foot view, you can expect smart keys to continue to get … well, smarter. “They’re only going to get more advanced,” says James Sanabria, key programming team lead at Autel.
For owners of vehicles that come with key fobs instead of mechanical keys – a growing cohort – it means that adding a key for another driver (a spouse, for example) or replacing a lost, damaged or stolen key is a lot more complicated (and expensive) than it used to be. A new key fob needs to be programmed to the vehicle – although the more accurate way to describe it is the vehicle needs to be programmed to the new key fob.
The good news for consumers is that all this technology makes vehicles tougher to steal, at least in theory. Toyota describes the engine immobilizer as “a state-of-the-art anti-theft system.” When the driver brings the key fob into the vehicle, the key transmits an electronic code to the vehicle. The engine will start only if the code from the transponder chip inside the smart key matches the code in the vehicle’s immobilizer. Having that transponder chip embedded in the smart key is good for security, but it’s also the reason why replacing a key fob isn’t simple (or cheap).
The good news for your parts store is that if you carry the Autel MaxiIM IM608 PRO and/or IM508, you have tools that can help shops – and even your DIY customers, in some situations – program replacement keys, restore immobilizer data and perform related tasks, in addition to the all-systems diagnostics you’d expect from a scan tool. In most cases, these tools will guide the user through the steps needed to complete a key-programming job, Sanabria says.
Just make sure your customers are aware that when it comes to key programming, there are different levels of security access depending on the year, make and model of the vehicle. With some vehicle makes – Nissan, for example – a technician or even a DIYer can plug the tool into the OBD II port “and the tool pretty much self-guides the customer through the process, making it easy to make that key,” Sanabria explains.
European makes, on the other hand, are “notorious” for their strict security-access protocols, which could require the user to produce a secured PIN code that can only be generated by a licensed locksmith. Sanabria sees that as an opportunity, not a challenge, for repair shops, and he encourages technicians to consider obtaining their locksmith license.
  • 2 months later...
On 12/9/2021 at 8:51 PM, llarisaabramova said:
The proximity-key system's really convenient, IMHO. It makes my life so much easier.
Especially when it's snowing or raining outside. And I found out all the shortcomings of a usual key when my digital key'd broken down. I didn't even try to fix it myself, as I got no required skills or knowledge. So I just contacted the
who solved my problem. I can't understand those who try to repair everything with their own hands. I mean, nothing guarantees that you'll fix it. Vice versa, you can do even worse. So what is the point of such risks?
      How To: Replace a Key Fob Battery
      The smart way to remove an oil drain plug | Oil change tips part 8
      Simple trick to get all the oil in the pan | Oil change tips part 7
      Get spare supplies for time and cost savings | Oil change tips part 4
      The standard automotive powertrain for the majority of the 20th century was the front engine, rear-wheel-drive (RWD) design. The rear axle assembly housed the differential and individual axles, and it is through this assembly that power was transferred to the wheels.
      Even though both front-wheel-drive (FWD) and four-wheel-drive (4WD) cars were also designed and manufactured during the early years of the automobile, they didn’t flourish and the durability and simplicity of the typical RWD design made it the sole choice of automobile platforms for many manufacturers.
      In a typical RWD vehicle, the power generated by the engine is transferred through the transmission to the driveshaft, differential and axles to the rear wheels. In a typical 4WD vehicle, a differential/axle assembly is located at the front of the vehicle, and to transfer power to the front, a transfer case is also installed after the transmission and a short driveshaft is installed between the transfer case and front axle.
      You will also notice that the front differential/axle assembly is different in two ways. One, the differential location is offset for clearance since the engines were always mounted in the center and, two, since the front wheels must turn to steer the vehicle, the axles must have some type of articulating joint at the end, the most common of which is the traditional Universal Joint (U-Joint.)
      The transfer case transfers the power that exits the transmission to either the rear wheels (RWD), or the front and rear wheels at the same time (4WD.) Another feature of a traditional transfer case is that it offers both high and low ranges in either RWD or 4WD positions, as well as a neutral position. This is so that if the vehicle must overcome particularly difficult terrain, it can be placed in the low range so the engine will operate at a higher RPM to provide additional torque to the wheels. The high range is 1:1, which means the output speed of the transfer case is the output speed of the transmission. The low range ratio varies depending on manufacturer.
      An important aspect of all this is differential operation. The differential itself transfers the power from the driveshaft to the axles, and it is necessary because it allows power to be transferred to the wheels, but also allows them to travel at different speeds when turning a corner. A conventional differential is considered an “open” design. An operating characteristic of an open differential is that it transfers power to the wheel that spins the easiest.
      As an example, if one wheel is on ice, that wheel will spin, resulting in minimal traction. The same affect is what causes a car under heavy acceleration to “burn rubber” with only one wheel. To combat this problem, there is another type of differential that is referred to as “limited slip.” There are many different names for this type of differential depending on the manufacturer, but their operation is the same.
      A limited slip differential contains clutch packs built in between the side gears and the differential case. When one wheel begins to spin from loss of traction, the clutches will grab and transfer power to the other wheel. The same clutches will slip just enough to allow the wheel speeds to differ when going around a corner, so the normal differential action is still available.
      The majority of cars and trucks on the road come standard with open differentials, due to the additional cost of limited slip. Limited slip differentials have always been an option, just not standard. So, on a four-wheel-drive vehicle equipped with open differentials, technically speaking, the maximum number of wheels that can put power to the ground at any given time is two…kind of funny on something known as a 4×4, but it’s still twice as much traction as RWD only, and for the most part it got the job done. Most people who were really going to be in some serious off-road situations would be sure they were equipped with limited-slip differentials.
      4WD, as it was originally developed, was a rather primitive system that required input from the driver, from engaging to transfer case to engaging hubs on the front wheels in many cases. Technology was the eventual downfall of rudimentary 4WD systems as we know them, but the drive to utilize this technology came from the safety benefits of AWD.
      The ability to transfer power to all four wheels has incomparable benefits for traction, vehicle stability and handling. Not only does this translate to the safety of daily driven vehicles, but it translates to performance, as well.
      With the advancement of computer and electronic technology, antilock braking systems (ABS) and traction control systems (TCS) all of a sudden knew exactly what was happening at each wheel at all times. Was it losing traction, was it locking up under braking? All this data was now available, and engineers knew that the key to vehicle performance, safety and handling all together, was in the ability to precisely control what happened at each wheel at any given point in time.
      Traditional differentials, even limited slip, were mechanical devices. There was no external control of how they operated. With electronics and computer control, the traditional differential became a technologically advanced unit containing not only gearsets, but clutch packs like those in an automatic transmission, and their own pumps to pressurize the fluid.
      The same technology is present in both front and rear differentials, as well as center differentials/transfer cases. AWD systems have the ability to precisely control the amount of torque that is transferred to any given wheel at any point in time, providing absolute control of the vehicle.
      In conclusion, 4WD is functional, durable, rough and tough, but not user friendly. AWD, the product of technology, computers and electronics, is technologically superior, and provides the safety feature we rely on in today’s vehicles.
