If you were buying a new vehicle, what would you want the engine to have: a timing belt or a timing chain? You may have an opinion, you may not. Either way, let’s compare the two; then you can decide.
The Chain Gang
For many years, timing chains were the go-to for engine design. Generally speaking, they were dependable and didn’t require any specific maintenance. They were lubricated by the engine oil, so if you changed it on a regular basis, the timing chain would hold up well.
Or would they? A lot of people still say, “They don’t build them like they used to.”  This is true, and coming from someone who is an old-car enthusiast, I’ll defend a level of workmanship that we don’t see in today’s vehicle. But the statement, while true, doesn’t always mean they built them better.
In the case of timing chains, they sometimes wore quicker than a lot of people realized. What happened when they did? On an old car, nothing right away. At least nothing of which the owner was aware.
A timing chain, just like a belt, is there for one reason: to connect the crankshaft to the camshaft at exact points so the valves open and close at the correct time for engine operation. A traditional, old-school timing chain was tight upon installation, and the overall timing set consisted of a crankshaft gear, a camshaft gear and a chain. There was no adjustment or no tensioner.
When the chain or the drive gears began to wear, engine performance would suffer, but it would degrade slowly, and most vehicle owners had no idea there was a problem. They wouldn’t know at all until they started to get a hard-start or no-start symptom. And why? There was no crank sensor or cam sensor, and no computer to translate the signals into a crank/cam correlation diagnostic trouble code (DTC). So, we just drove the cars until they wouldn’t drive any more.
Early engine design was split between gears or chains, but chains ultimately became more popular because they took up less space and ran quieter, and by the early ‘80s, the majority of cars produced had timing chains.
An evolutionary change of timing-chain design included nylon-tooth cam gears. They ran quieter than a traditional steel gear, but they wore out a lot quicker and created problems long before vehicle owners expected, which didn’t do much for their reputation. The tried-and-true timing chain was simple and generally dependable, but times were changing.
Buckle Your Belt
As the ‘80s rolled on, electronics, emission controls and technology were on solid cruise control and like flipping a switch, timing belts were suddenly in the picture.
Although timing-belt-driven overhead camshaft engines weren’t new by any means, the value of the design began to be recognized and auto manufacturers started to change over to this concept. The camshaft was now located on the cylinder head, which eliminated push rods and, on some designs, the rocker arms were eliminated as well, saving weight, lowering cost, reducing valvetrain inertia and making multi-valve designs possible.
The easiest way to drive the camshaft was via a timing belt. Since timing chains suffered from inherent gear wear and stretching, engineers decided that belts were the way to go. They were quieter and lighter than a chain and less expensive to manufacture.
The tensioning systems were simple, and the belts remained tight for a long time without wearing the cam or crank gear.
Seemingly, all was good, but even with the advantages of a timing belt, they required replacement at specific intervals, and the one disadvantage that became known quickly was that if not replaced, they would break with no warning. Simple tensioning systems required adjustment from time to time, and oil leaks also were a problem with timing belts, as they would degrade the rubber quickly and lead to a broken belt. A broken belt could mean a very expensive repair on interference engines.
Belt quality and tensioner design improved quickly, eliminating many of the early timing belt troubles, and by the mid- to late-‘90s, timing belts were used on the majority of automobile engines. Belt-service intervals became longer, and consumers were getting used to this being a part of normal maintenance. But you still cannot ignore the replacement interval, and was it possible times were changing again?
The Old Ball and Chain
As we said “Happy New Year” to a whole new century, engine technology was a freight train out of control. Materials and manufacturing were better, RPMs were higher, turbochargers were boosting like never before and horsepower wars like we hadn’t seen since the ‘60s were heating up again.
Smaller engines were producing more power than ever, and variable valve timing was pushing engine performance to the limit. Just like that, engine design required something that was narrower, more durable and more dependable than a timing belt, and consumers no longer wanted the associated maintenance. Hello chains.
As of the last decade, timing chains have risen back to the top. Design is far different than that of old, with modern chains traveling around awkward paths of sprockets, hydraulic tensioners and chain guides, offering a high level of dependability and performance. But they couldn’t do it without one critical thing on their side: lubricant technology.
A primary reason for timing-chain wear always has been related to lack of oil changes, lower-quality oil, and poor or non-existent positive crankcase ventilation (PCV) systems, which wreaks havoc on engine oil.
Modern engine oil is not only far superior than it was just a few decades ago, but PCV technology also is eliminating the majority of blow-by-related contaminants and moisture from building up, resulting in cleaner oil and better lubrication throughout the engine.
Timing chains and variable valve timing systems are dependent on clean, healthy lubrication and now they have it, but then again, does everyone change oil as often as they should?
Talk to the Techs
Timing belts generally are easier to service. This is primarily because they’re located on the outside of the engine and run dry, with no lubrication. When replacing a belt, there’s less cleanup and no time required to reseal engine covers. On the other hand, the engine water pump is frequently driven by the timing belt, so when you replace it, it’s a good practice to replace the pump, as well as any tensioners or rollers.
Timing belts came into prominence along with the inline four-cylinder engine. What this brought was more than just cam/crank timing, but also balance shafts and intermediate shafts that often drove distributors and oil pumps. These weren’t hard to work with, but had to be timed correctly during belt replacement.
As the timing belt migrated to V-configuration engines, it became a lot longer with additional rollers and a more difficult installation, plus some components such as thermostats were all of a sudden underneath. Some things got better, some got worse.
Inspection is an advantage with a timing belt; it’s usually just a couple of bolts and you’re looking right at it. One problem, and a challenge especially on a second-owner vehicle: If the mileage is over that of recommended timing-belt replacement and the owner doesn’t know if it was done, replacement is always recommended.
Many belts can look great on the outside but strip the teeth off a day later. The only way to inspect them closely enough to really look at the integrity of the teeth can be to remove them. And then, does it make sense to put the old one back on, and is there a technician who would want to take that gamble? One solution to this is the bright yellow replacement decal that’s included in almost every timing-belt kit, for a technician to fill out and affix under the hood. If only they got used more often.
Timing chains, as good as they have become, are not without faults. They can be a bear to inspect and replace, mainly because they’re located inside the engine so they can be lubricated by the engine oil. There’s a lot more cleaning to do and usually a seal or two that needs replaced. Just as with belts, there’s often a water pump that’s driven by the chain that should be replaced.
While the chains are more durable and dependable, if oil changes aren’t religious, the guides have a tendency to wear out really quickly. Most guides are steel with some type of nylon or plastic that the chain rides along. Remember the nylon-tooth cam gears? These guides do the same thing and beyond a certain point in wear, the tensioner can no longer take up the slack in the chain.
This often leads to a rattling noise and a “Check Engine” light. Most engines still run perfectly fine at this point, with the most common complaint a “Check Engine” light and a cam/crank correlation DTC.
Timing-chain replacement is often very expensive due to labor time, but, then again, so is engine repair when a timing belt breaks. They both require special tools at times, so there’s no winner on that argument. And, one more thing: Did we mention the latest technology of belt-in-oil drive systems? Here we go again. So, do you have a preference, or do you agree with my conclusion?
      Dayco, a supplier of engine products and drive systems for the automotive, industrial and aftermarket industries, is expanding its timing chain kit line with 41 part numbers to cover another 49 million vehicles in operation (VIO). Additionally, the company is introducing the next generation of its AutoPartIQ inventory assessment tool—with new features for a more productive customer experience.
      New Parts Bring Timing Chain Kit Coverage to 120+ Million
      Dayco’s aftermarket team launched the line in 2022 due to the car parc shift from timing belts to timing chains at the OE level. The
      link hidden, please login to view, which feature OE-quality components, cover high-volume light-duty engine applications. They include all the necessary components for a thorough and complete repair, building on Dayco’s mission of recommending system replacement as a best practice. Dayco says the kits include: Timing and secondary chains that prevent stretch for the life of the kit – and address the no. 1 replacement issue; Precision-machined cam and crank sprockets for quiet, noise-free performance; Direct fit OE-quality, high-grade plastic guides, as well as VVT solenoids and cam phasers when the application calls for it; and Packaging that features a QR code that links directly to detailed installation instructions. Dayco backs its entire timing chain kit line with an industry-leading two year or 60,000 mile (96,000 kilometer)  link hidden, please login to view, whichever occurs first, giving technicians confidence in what they’re installing. Three of the new part numbers are already available, and the remaining 38 are scheduled for Q1 or Q2 2025.
      “We entered the timing chain kit market to meet the needs of our customers. The line continues to grow with sales increasing year over year and we are supporting our high-quality product line with important investments in warranty and training material,” said Tom Tecklenburg, Vice President, Aftermarket, Dayco North America. “We encourage our customers as well as shop owners to reach out to our tech team to schedule virtual training and to learn more about this line if they aren’t already stocking it.”
      link hidden, please login to view announced the release of an expanded range of timing chain kits and components for Q3 2024. The company said this latest product launch provides aftermarket solutions for a broad selection of popular vehicle makes and models. Cloyes said this quarter’s new offerings include comprehensive timing chain kits for Ford and Subaru vehicles. They’re designed to support Ford models such as the F-150, Mustang, Expedition and Transit, with engine sizes ranging from 2.7L to 3.7L. Subaru models, including the Forester, Impreza, Outback, and BRZ, are also covered, with kits tailored for 2.0L and 2.5L engines.
      Cloyes further expanded its product line with new timing chain kits for Mercedes-Benz and Mazda vehicles. Mercedes-Benz kits are designed for the 2.1L and 2.7L engines found in models such as the E250, GLE300d, and Sprinter vans. For Mazda, owners of vehicles such as the Mazda 3, CX-5, and MX-5 Miata can benefit from Cloyes’ new timing and oil pump chain kits, the company said.
      In addition,
      link hidden, please login to view now offers expanded coverage for Hyundai, Kia, and General Motors vehicles. The new kits support popular Hyundai and Kia models like the Sonata, Optima, Santa Fe and Sorento, with engine sizes ranging from 2.0L to 2.4L. For GM, Cloyes has introduced timing chain kits for 1.4L and 1.5L engines in models such as the Chevrolet Spark, Malibu, and GMC Terrain. Cloyes said each kit is engineered for optimal engine performance and includes a variety of essential components such as timing chains, accessory drive belts, variable valve timing (VVT) components and water pumps, where applicable. The company added that the kits “provide all necessary timing and oil pump chain system components to ensure long-lasting, efficient engine performance, meeting or exceeding OEM standards.”
      link hidden, please login to view — which tracks demand conditions, shortages, transportation costs, inventories and backlogs based on a monthly survey of 27,000 businesses — rose in April to -0.18, from -0.32 in March, which signals that global supply chains are operating at close to full capacity. An Index greater than 0 indicates supply chain capacity is being stretched. The further above 0, the more stretched the supply chains are. An index less than 0 indicates supply chain capacity is being underutilized. The further below 0, the more underutilized supply chains are.
      Improving activity across global supply chains is a direct result of healthier demand, which has picked up consistently in the year-to-date after considerable weakness in 2023, GEP said. The Asian market is at the forefront of this trend, with input demand at the region’s factories remaining strong. Procurement managers in South Korea, Vietnam, India and China reported greater purchasing activity during April.
      According to GEP Consulting, the North American market is showing more evidence of tightening capacity, with backlogged work reported by manufacturers, particularly in Mexico. Demand for raw materials, commodities and components, while still subdued, also improved slightly. Meanwhile, demand conditions were less robust in Europe, with the region’s manufacturing sector continuing to underperform and lag other parts of the globe. Positively, however, the industrial recession across the continent has eased considerably since late last year.
      “After four years of supply shocks, inflation, stockpiling, and uncertainty, global supply chains are now operating in a Goldilocks zone, a steady state of full capacity, not expanding or contracting too quickly, which is excellent news for global suppliers and business,” Mike Seitz, vice president, GEP Consulting said. “In China, we’re seeing a steady pick-up in manufacturing activity, which will encourage Chinese Premier Li Qiang to accelerate efforts to remove barriers imposed by European markets and foster more FDI, especially as the potential for tougher U.S. tariffs and trade policies loom.“
      April 2024 key findings
      Demand: Global demand for raw materials, commodities and components remained close to its long-term average in April, highlighting vastly improved conditions in the worldwide manufacturing sector compared with late last year. As was also the case in March, Asia was the main positive force, with major goods-producing nations such as China, India and South Korea recording growth, according to GEP. Inventories: Inventory drawdowns persisted into April, albeit cooling in strength compared to March. Reports from global businesses of stockpiles rising because of price or supply concerns were among the lowest seen in over four years, GEP said. Material shortages: GEP said reports of a short supply for items, including semiconductors, foodstuff, chemicals, and metals, remain historically low. Labor shortages: After rising for the past three months, GEP said global reports of backlogged orders rising because of staff shortages fell in April and were broadly aligned with historically typical levels. Regional differences persisted, however, with North America seeing greater labor shortages than elsewhere. Transportation: Following recent increases in oil prices, global transportation costs rose for the first time this year in April, according to GEP. Regional supply chain volatility
      North America: Index broadly unchanged at -0.30, versus -0.31 previously. Although indicative of spare capacity, the input demand trend ticked higher in April, while increased backlogs of work were also reported, GEP said. Europe: Index fell to -0.55, from -0.62. GEP said April’s increase suggests the continent’s industrial downturn continued to ease. U.K.: Index decreased to -0.47, from -0.17 as U.K. manufacturers destock sharply instead of ordering from suppliers, GEP said. Asia: The Index rose to 0.07, from -0.07, signaling the first month of stretched supplier capacity since January, according to GEP. The post
      You might not be able to see it, but an accessory-drive belt is always both speeding up and slowing down. When a piston accelerates downward after the ignition of the fuel and air, the crankshaft speeds up and then slows down as it reaches the bottom of the stroke. These changes in speed are minimal, but big enough to cause problems over time.
      If the pulses aren’t minimized, they can hammer the belt and the attached rotating components. On a four-cylinder engine, the degrees of rotation between power pulses are greater than on a V-8 – so the amount of change in speed on the four-cylinder pulley is greater than on a V-6 or V-8. This has a direct effect on how the belt system is designed.
      The belt-drive system is working hardest when the engine is at idle. When the engine is below 1,000 rpm, the alternator, A/C compressor and power-steering pump are putting the greatest strain on the belt.
      Some of the forces can be taken up by the belt slipping on the pulleys. But, slipping causes friction and wear on the belt, as well as flutter. Over time, the slipping can get worse as removal of material from the ribs causes the belt to bottom out.
      There are three components that help to keep the belt on the pulleys without slipping. The tensioner, harmonic balancer and decoupler pulley work together to keep the accessory-belt system quiet and the belt lasting until the replacement interval.
      Tensioner
      The tensioner applies force on the belt. Some tensioners have devices that dampen the movement of the spring and arm, helping to keep constant force on the belt even under a wide variety of conditions.
      Harmonic Balancer
      The harmonic dampener puts a layer of soft material between the crankshaft and outer ring of the pulley. The material helps to dissipate the power pulses and resonant frequencies. While the dampener may only flex one or two degrees of movement, this takes a lot of strain off attached components.
      Decoupler Pulley
      Some alternators have a decoupler pulley. This device serves two purposes. First, it helps to decouple the pulley from the alternator with a one-way clutch. The decoupler reduces parasitic losses by not having to fight against the momentum of the armature in the alternator while the engine is decelerating and accelerating.
      Some decoupler pulleys have a spring and friction dampener to reduce vibration. When an alternator decoupler pulley is compromised, it can no longer absorb the same level of abuse, which has a trickle-down effect throughout the system.
      Alternator decouplers and pulleys should be inspected every 10,000 miles for wear. Early design versions have a service life of 40,000 to 60,000 miles, with more recent versions lasting more than 100,000 miles.
      When inspecting a decoupler or pulley, there are two signs that replacement is needed. First, after shutting down the engine, if there’s an audible buzzing, the bearings in the pulley have likely failed. The second sign depends on whether the vehicle has a one-way clutch (OWC), overrunning alternator pulley (OAP) or decoupler (OAD).
      With the inspection cap/cover removed and the center locked, turn the pulley or decoupler with the appropriate tool. If it’s an OAP or OWC, the pulley can only be turned in the clockwise direction. If it’s an OAD, a counterclockwise turn will reveal a noticeable increase in spring force; a clockwise turn will only have slight resistance. The tensioner, harmonic balancer and decoupler pulley work together to keep the belt in contact with grooves in the pulleys. The three components are engineered together to match the engine. If one part is compromised, all are compromised, including the belt.
      Timing Covers | Counterperson Training from Dorman Training Center
