Mustang Gloc Pads
By roybrakepad
By roybrakepad
By Mia
1. Understand Brake Pad Wear
6. Choose Quality Brake Pads
By roybrakepad
1. By formula
2. By brand
Akebono Brake Corporation
Brembo
Bosch
TRW Automotive
By roybrakepad
1.Basic functions of brake pads:
The brake pads is use to make your car stop at the time and place you need, especially in emergencies.The effectiveness of braking directly affects the safety and comfort of drivers and passengers. With rear of brake pads, we need change our brake pads on time.
2.Overview of Market Status:
With the development of technology and the improvement of people’s economic level, the number of cars as the main means of transportation is gradually increasing, which also marks the growing demand for brake pad replacements in the market. There are many brands and models of brake pads in the auto aftermarket.
