OE Manufacturer help your selection
By TachMaker
Upgrade your vehicle with link hidden, please login to view designed to enhance convenience and performance. From practical add-ons to innovative accessories, these auto parts are tailored to meet the needs of modern drivers. Improve functionality, ensure ease of use, and enjoy a seamless driving experience with thoughtfully crafted components that prioritize both utility and style. Whether it’s for better organization, improved safety, or enhanced aesthetics, these details make every drive smoother and more enjoyable..
By APF
Choosing between original and aftermarket car parts — and even used parts of either type — is all about squaring your priorities with your budget.
» SIGN UP: link hidden, please login to view
Original equipment manufacturer (OEM) parts match those that came with your car, and are of the same quality as its original parts. They’re also the most expensive. Aftermarket parts are cheaper, and made by other manufacturers — often several, giving you more options. Used parts may have a bit of wear and tear, but should be inspected or rebuilt to ensure they’ll work. These are the cheapest option. Choosing between aftermarket and OEM parts
Aftermarket parts come at varying price points and levels of quality, but because they are cheaper, insurance companies often prefer them. If you want OEM parts but are dealing with an insurer that wants the shop to use aftermarket parts, ask to pay the difference.
If you’d like to modify your ride by adding something like a backup camera or back-seat TV screen, you’ll probably be looking for aftermarket parts. Certain aftermarket upgrades could increase
Dealership repair shops will offer only OEM parts — they have no reason to offer a cheaper product from a competitor link hidden, please login to view may be able to offer you a choice between OEM and aftermarket parts Independent garages that specialize in your type of vehicle will likely have both, but with quicker access to OEM parts, including used OEM parts, which can really save you Auto body shops can offer both, but if your collision repair is part of an insurance claim, the insurer will likely prefer aftermarket parts to save money Depending on the job, the cost of OEM versus aftermarket parts varies. Whenever you’re given the choice, ask to see estimates for both so you can weigh your options.
