The power steering hoses run fairly close to the left side exhaust manifold. And the rubber seems to start suffering after 2 years or so and cracking... Replaced another one today.
I was wondering if that exhaust wrap material coukd be wrapped around the rubber portion of the hoses to help protect it from the heat?
Edited by MCT
  • MCT changed the title to 1994 cheverolet suburban 5.7 power steering hosesing hoses
      Electric power steering systems have gained widespread popularity in the U.S. since their introduction in 1990, primarily due to the increasing number of hybrid and electric vehicles in today’s market. Like any new(er) technology, each manufacturer has a slightly different method of achieving the same goal, in this case effortless power steering assist, and some are better suited than others for certain applications.
      The first (but never fully-realized in production) was an electro-hydraulic system intended for the 1989 Pontiac Fiero. When GM decided that 1988 would be the last year for the Fiero, the system was shelved for later use in its short-lived EV-1 battery electric vehicle. Electro-hydraulic power steering (EHPS) is itself a sort of hybrid, with an electric motor-driven hydraulic pump replacing the belt-driven unit common to “traditional” power steering systems, but retaining the familiar hydraulic rack and pinion assembly, the associated hoses and hard lines, and often a system-specific hydraulic fluid. Found across a wide variety of marques, EHPS remains relevant today as we find ourselves transitioning between ICE, hybrid and BEV technologies.
      Fully-electric power steering systems use DC motors rather than hydraulic pressure to provide the assistive force required to turn the wheels. Electric motors are long-wearing and quiet, eliminating the squeals and groans common to hydraulic systems, and the power losses associated with belt-driven accessories. These features make them an ideal choice for luxury cars as well as those quiet-running BEVs and hybrids. When compared to hydraulic systems, EPS also represents a weight reduction, adding to vehicle efficiency. Current EPS designs fall into three general categories, based upon the location of the assist motor(s).
      C-EPS, or “column assist” systems are commonly found in compact vehicles. The motor, sensors and other electronics are integrated into the upper steering column assembly. This location maximizes underhood space, with the bulk of the assembly hidden below the dashboard, and still allows for integration with ADAS features like self-parking, lane assist, handsfree and self-driving technologies. This system is the only one of the three EPS designs that does not attach to or integrate with the rack and pinion. With no plumbing or wiring, the C-EPS rack unit is effectively a manual steering gear.
      R-EPS, also known as “rack assist” systems feature assist motors integrated into or attached in parallel to the rack body. A recirculating ball gear and toothed rubber belt convert the assist motor’s rotation into a linear (side-to side) motion. Capable of high applied force, this “parallel axis” design is used primarily in light trucks, SUVs and other vehicles where extra steering effort is required. The rubber belt is a common failure point for this type of rack, but repair kits are widely available for many domestic applications, and offer substantial savings when compared to the cost of a complete steering gear.
      The last category is the “pinion-assist” or P-EPS system. Single-pinion designs locate a relatively large assist motor at the lower end of the steering column, and force is applied directly to the pinion gear at the input shaft. Due to space and safety considerations, many manufacturers have eliminated this system in favor of a dual-pinion setup. The input pinion gear connects to the column, but the assist motor drives a second pinion gear at the opposite end of the rack, isolating the motor from the column, and resulting in improved steering feel. Limited mostly to mid-size cars, P-EPS is not powerful enough for use in heavy vehicles and most light trucks.
      Vehicle electrification will continue to drive future EPS technologies, but existing ICE vehicles have already proven the advantages of these systems across multiple platforms. The progression from manual to hydraulic to electric power steering systems leaves us on the verge of the next technology, known as “steer by wire.” Just as “throttle by wire” has largely replaced the accelerator cable with a pedal position sensor, engineers are removing the physical linkage between the steering wheel and the steering gear. Steering angle sensors, torque sensors and vehicle speed sensors contribute information to the steering module, which determines the amount of assist required under different driving conditions. This data is sent to actuators in the rack unit that perform the commanded steering functions. Once the realm of science fiction, SBW can now be found in the Infiniti Q60, the Lexus RZ and the Tesla Cybertruck.
      In the fast-paced world of automobiles, the allure of shiny new parts is undeniable. But amidst the gleaming chrome and cutting-edge technology, a sustainable revolution is quietly gaining momentum - the used car parts market. It's a world where eco-consciousness meets affordability, and Green Gears Auto Limited is leading the charge.
      Used Car Parts: The Unsung Heroes of Automotive Sustainability
      Let's face it, manufacturing new car parts takes a toll on our planet. From the extraction of raw materials to the energy-intensive production processes, the environmental impact is significant.
      Used car parts offer a brilliant solution - they give a second life to perfectly functional components, reducing the need for new production and minimizing waste.  It's not just about the environment though. Used auto parts, often Original Equipment Manufacturer (OEM) parts, offer significant cost savings compared to their brand-new counterparts. This means that keeping your car on the road doesn't have to break the bank.
      Green Gears Auto Limited: Your One-Stop Shop for Sustainable Solutions
      Enter Green Gears Auto Limited, a company dedicated to making sustainable car part solutions accessible to all. Their extensive inventory includes a wide range of used car parts, from engines and transmissions to body panels and electrical components. They even specialize in hard-to-find parts, ensuring that even owners of older or less common vehicles can find what they need.
      Whether you're a DIY enthusiast, a professional mechanic, or simply a car owner looking for affordable and eco-friendly solutions, Green Gears Auto Limited has you covered. They offer:
      Quality Assurance: All parts are thoroughly inspected to ensure they meet high standards of quality and functionality. Wide Selection: Their inventory covers a broad spectrum of makes and models, making it easy to find the right part for your vehicle. Expert Support: Their knowledgeable team is always ready to assist you in finding the perfect part and answering any questions you may have. Embrace the Green Revolution
      The automotive industry is evolving, and sustainability is at the forefront of this transformation. Choosing used car parts isn't just a smart financial decision; it's a conscious choice to reduce your environmental footprint.
      So, the next time your car needs a little TLC, consider the sustainable option. Visit
      link hidden, please login to view and discover a world of affordable, eco-friendly car parts. Together, let's keep our cars running smoothly and our planet healthy. Remember, every used part is a step towards a greener future.
      Dorman turbocharger accessories for Ford 6.7L Power Stroke diesel vehicles
    • By carbdoc
      I can't find a rebuilt brake booster for my 1978 Dodge D-150 truck anywhere; I have been hunting for months.  The Chrysler number is 4094149.  The A-1 Cardone number is 54-73716.   I would settle for a rebuildable core at this point; my old booster is rusted-out on the back side so it is no good as a core.
    • By 1772668470
      Installing a power steering pump involves several steps. It’s important to have the correct tools and follow safety precautions. Here’s a step-by-step guide to help you through the process:
      Tools and Materials Needed:
      New power steering pump
      Power steering fluid
      Wrench set
      Screwdrivers
      Pulley puller (if necessary)
      Jack and jack stands
      Drain pan
      Safety glasses and gloves
      Torque wrench
      Steps to Install a Power Steering Pump:
