The power steering hoses run fairly close to the left side exhaust manifold. And the rubber seems to start suffering after 2 years or so and cracking... Replaced another one today.
I was wondering if that exhaust wrap material coukd be wrapped around the rubber portion of the hoses to help protect it from the heat?
Edited by MCT
  • MCT changed the title to 1994 cheverolet suburban 5.7 power steering hosesing hoses
      Destructive testing: OE power steering coolers vs. Dorman OE FIX
      Hidden feature in Dorman OE FIX steering knuckles
