      Automotive Parts Associates (APA) announced it recently wrapped up an action-packed weekend in Las Vegas, where winners of the Vegas Adrenaline Adventure Weekend promotion “experienced high-octane thrills and unforgettable moments.” From Feb. 28 to March 2, 10 winners and their guests enjoyed an all-expense-paid trip featuring off-road driving, machine gun shooting, Topgolf, plus $500!
      APA said the winners also got to enjoy a Friday night dinner sponsored by FCS. “A special shoutout to FCS for sponsoring a fantastic Friday night dinner, adding to the excitement of the weekend,” APA said.
      The promotion, which was open to
      link hidden, please login to viewshareholders’ and TruStar members’ customers from September 15 through October 31, awarded entries for every $200 purchased from sponsoring suppliers. In addition to the grand prize trip, 10 second-place winners received a $250 gift card and salespeople earned a $100 gift card for each winner. Following are quotes from participants sharing their appreciation for the experience:
      “Thank you very much for the great and memorable trip and your kind hospitality. We do appreciate it. I was glad to meet a lot of shop owners and great people and also exchange great information. We had a great time.” “Both of my sons thoroughly enjoyed themselves. Thanks for putting that together. It was a trip they may never take again together!” “Gail and I would like to say thank you to APA for a great weekend away, we really enjoyed ourselves!” “It was an unforgettable weekend,” said Jan Larson, director of marketing for APA. “What started as a group of strangers on Friday quickly turned into a close-knit group by Sunday, exchanging contact information and sharing stories like lifelong friends. I always encourage our shareholders and TruStar members to take advantage of these promotions. Participation is easy and can have a meaningful impact on employee morale. These events drive engagement, boost sales, and create lasting memories—don’t let your customers miss out on these incredible opportunities!”
      APA said it hosts two promotions annually, one in spring and one in fall. Up next is the 2025 Tanks For The Memories Sweepstakes, where ten winners will receive an all-expense-paid trip to drive real tanks at Drive A Tank in Kasota, MN.
    • By dwil4
