RockAuto Promo - ACDelco Spark Plug Rebate
RockAuto
      link hidden, please login to view announced a national rebate promotion to help retailers and service shops across North America propel filter sales in time for the summer vacation travel season. Consumers can receive up to $15* on qualifying oil, air and cabin air filters under the Purolator, PurolatorTECHTM, PurolatorBOSS® and PurolatorONETM brands for purchases made between July 1 and August 31, 2024. To help promote the campaign,
      link hidden, please login to viewsaid it’s offering free point-of-sale marketing materials to all participants, including posters, window clings, tear-pad rebate forms and shelf talkers. “This rebate comes at the perfect time for budget-conscious families looking to prepare their vehicles for road trips while making their vacation travel even more affordable,” said Daryl Benton, vice president of sales and marketing for the automotive aftermarket with MANN+HUMMEL.
      Rebate forms and additional information on the promotion are available
      link hidden, please login to view. *Consumers may mix and match up to three items. Maximum rebate payout is $15. Limit one rebate payout per customer, per household.
      Why a magnetic drain plug is a worthwhile upgrade
      Should you use antiseize when installing spark plugs?
      Spark plugs are the “canary in the coal mine” of the combustion chamber. The electrodes and porcelain can reveal short- and long-term problems if you know where to look.
      Most OE spark plugs have a life of more than 50,000 miles, thanks to electrodes that contain precious metals like platinum and iridium. OEMs consider the spark plugs a part of the emissions system on most modern vehicles.
      If the plugs fail sooner than the recommended interval, it’s important to solve the problem before installing new plugs. If you’re replacing spark plugs to solve a misfire problem, the car will be back.
      But first, what causes spark plugs to foul quickly? What does a fouled spark plug look like, and what is spark plug fouling?
      Carbon Fouling
      If the spark plugs have a matte black or grey appearance, it could be carbon fouling – something typically caused by a fuel mixture that’s too rich.
      During normal combustion, most of the fuel oxidizes and changes into carbon dioxide and carbon monoxide gas. When there is more fuel than oxygen, the carbon in the unburned fuel polymerizes into carbon deposits. These molecules like to stick to the hot spots in the combustion chamber, and this includes the spark plug’s tip and insulator.
      Curing the problem will typically point to the fuel system and how the engine is breathing. If a fuel injector is clogged or sticking open, extra fuel can cause carbon problems.
      If the mass airflow sensor or oxygen sensors aren‘t accurately reporting the air that’s coming into the engine or the oxygen content in the exhaust stream, it could cause a rich-running condition that can cause carbon to foul the spark plugs.
      Another factor is how the air flows past the valves. If the air is restricted or has to flow past carbon deposits on the intake valves, it will be turbulent and disturb the flame front and fuel-droplet size in the combustion chamber. This means that the fuel injected into the intake port or combustion chamber won’t entirely burn.
      Oil Fouling
      Oil fouling of a spark plug typically results in a shiny, black appearance. If enough oil is in the combustion chamber, the deposits can build up on the tip, porcelain or shell.
      If you can’t determine if it’s carbon or oil fouling, smell the plug; it will smell like engine oil. The oil can come from the piston rings, valve stem seals or the positive crankcase ventilation (PCV) system. Leaking piston rings can be diagnosed with a leak-down test. If one cylinder has oil fouling, a relative compression check can help to assess mechanical issues with that cylinder.
      Malfunctioning PCV systems are becoming a leading cause of oil fouling in modern engines. These systems have become more than just a spring-loaded check valve. Modern systems can separate oil from the crankcase vapors and electronically regulate when the engine ingests the vapors.
      Some PCV systems have a heater to ensure that the valve doesn’t freeze under certain conditions when condensation is present. If the valve does freeze, it can cause higher-than-normal crankcase pressure. This can cause oil to be forced past the valve seals.
      If the PCV valve is stuck open, the excess vapors and oil droplets can quickly foul the spark plugs.
      A failed turbocharger can be another source of spark plug oil fouling. The seals on the turbine shaft are robust, but they can be victims of heat and poor oil quality. The oil that lubricates the shaft can enter into the pressurized intake and eventually the combustion chamber.
      OEMs have issued technical service bulletins concerning excessive oil consumption. Most of these problems relate to cylinder deactivation and variable valve timing (VVT).
      The main culprit in these problems is vacuum generated in the cylinders that sucks engine oil past the rings and into the combustion chamber. On vehicles with cylinder deactivation, the deactivated cylinder has negative pressure and draws oil droplets in the crankcase past the ring and eventually into the converter. This has happened on some GM and Honda engines.
      On some vehicles with VVT (typically on the exhaust and intake cams), the valve timing could produce higher-than-normal vacuum pressures that could suck oil past the rings. This was the case for some recent Toyota, Honda and GM models. The customer would report increased oil consumption that exceeded one quart every1,000 miles.
      Beyond the oil getting past the rings, the oil trapped in the rings can become carbonized and cause damage to the cylinder walls. This can lead to even more damage and more oil consumption. In some cases, the oil consumption results in a low-oil condition that would cause damage to the bearing surfaces.
      Coolant Problems
      Internal coolant leaks can foul a spark plug and cause a misfire. The problem could be a leaking intake manifold or a head gasket, and the fouled plug might be localized to one or two adjacent cylinders. The burned coolant leaves ashy, white deposits on the electrodes and insulator, creating hot spots that could cause pre-ignition and a misfire code to be set.
      When the plug is pulled, it might have a chalky appearance on the ground strap and center electrode. Modern coolants don’t cause this type of buildup quickly, due to the reduction of phosphate, zinc and other additives that can contaminate the catalytic converters.
      In the past, the converter would become clogged and stop the engine before significant damage occurred.
      Unfortunately, formulations mean that drivers can run a vehicle with a coolant leak for several thousand miles, while the plug becomes slowly fouled.
      ADD Group announced that the company has been honored with two awards: the Best Marketing Excellence from Advance Auto Parts and the APC Overdrive from ACDelco.
      The Best Marketing Excellence award highlights the company’s exceptional marketing services and support that have significantly contributed to Advance’s growth and success in 2023.
      The APC Overdrive recognizes ADD Group’s outstanding achievement across global supply chain, sustainability, innovation and product launch among others, the company stated.
      “We are deeply honored to receive these prestigious awards,” said Bruno Bello, director of global marketing at ADD. “They reflect our ongoing commitment to OE quality, product development, sales support, marketing excellence and logistic services. At ADD group we have a continuous improvement culture, so we are driving excellence and innovation for global OES and aftermarket.”
      The ADD Group is one of the world’s largest manufacturers of shocks, struts and complete strut assemblies. For more information about ADD products, call +86 576-8721-0118 or visit
