We offer only the best in the braking world. From Brake pads and fluid to brake cooler kits and components, Race Brake Shop is your one source for sports car brake parts and information. You can get the best
Pads only at Race Brake Shop. Glock Brakes offer better bite and a maximum operating temperature than standard replacement pads used in luxury vehicles.
      German lighting specialist
      link hidden, please login to view announced it has partnered with Brian Deegan in an agreement that will run into 2026. Deegan has equipped his 2025 Can-Am Maverick R side-by-side with a number of the latest HELLA LED lighting technology to help him both see and be seen, the company said. “A new addition this year – and a brand I’m stoked to be with because it has so much heritage and has been around for over 125 years – is
      link hidden, please login to view lights,” said Deegan, when he introduced the Maverick R to his fans. “They’re big in rally, too, which is cool for me!”  “When a legend like Brian Deegan chooses HELLA lighting, it’s a big deal,” said Rob Tinson, vice president of sales and marketing for
      link hidden, please login to view. “He knows performance, reliability and visibility win races, and we’re proud to provide the lighting technology that’ll keep him at the front of the pack!” Built for King of the Hammers and competing in other events, the Maverick is fully equipped for desert racing. The team added a full-length HELLA Black Magic 40” single row LED lightbar above the front roll bar, providing powerful illumination. Additionally, 3.2” HELLA Black Magic LED Cube lights were added to the front winch bar to spotlight obstacles and hazards.
      HELLA explained it joined an impressive motorsports roll call on the Deegan Maverick R, which also included Bilstein shocks, Evo tune, Obor RocScraper tires, Method Beadlock wheels and PRP seats, giving Brian the best chance of finishing the race and reaching the podium.
      In qualifying for the 2025 Can-Am UTV Hammers Championship, #38 qualified 24th of 100 drivers, which equated to third in the 4900 Pro Stock Turbo UTV class. In the race, a technical issue resulted in a DNF, although Deegan was classified 49th, HELLA said.
      In addition to his Can-Am Maverick R racer, HELLA also provides lighting for Brian’s personal Ford Raptor R and the water truck he uses to take care of his beautiful dirt track compound where the family
    • By abiztime
    • By abiztime
      5, Pallet
