WIX is Preferred Filter for World of Outlaws Sprint Car Series
to ensure their high-performance cars remain competitive on the racetrack,” said Tina Davis, senior marketing manager for WIX Filters. “World of Outlaws fans will have the opportunity to see the protection and reliability our filters provide in one of the most demanding racing series in the world.”
said it will highlight its long legacy in racing by sponsoring the WIX Filters Heat Race #3, which is one of the ways racers can make it to the Feature race and a chance at Victory Lane. In addition, WIX Filters will sponsor a Competitor Contingency Award Program, in which winners will receive a cash prize for displaying the WIX Filters decal.
“WIX Filters is an iconic automotive brand, and we’re excited to welcome them to the World of Outlaws and dirt racing community,” said Brian Carter, World of Outlaws CEO. “Many of their customers are already race fans and we look forward to entertaining them at every event and welcoming those who experience the World of Outlaws for the first time.”
      How to choose the correct battery for your car or truck
      MANN+HUMMEL announced the parts kit for its MANN-FILTER fuel filter PU 10 023/1 z KIT for pickups makes maintenance easier, thanks to the patented disassembly tool. It offers a very high degree of particle separation and efficient water separation, while also being ideally equipped for future fuel filtration requirements, the company said.
      “Efficient, fast, and clean – this is how the significantly improved handling of the PU 10 023/1 z KIT can be summed up,” explained Frank Bartel, product manager fuel filters at MANN+HUMMEL. This is made possible by the innovative handhold developed by
      link hidden, please login to view, which facilitates disassembly and is included with every filter, and by the modern and functional design of the filter element and housing cover. Changing the filter without this grip, however, requires a lot of force and is only possible with pliers or similar tools. Resistant to Dirt and Water
      “The innovative filter has an extremely high separation efficiency of more than 96 percent with a particle size of four micrometers,” MANN+HUMMEL said. “This means that 9,600 out of 10,000 incoming particles are retained. For context, these particles are up to 25 times smaller than a human hair.”
      It is not only impurities that can have a negative effect on the components of the injection system, but also water droplets. This applies particularly to modern common rail systems, which place high demands on fuel quality. The MANN-FILTER PU 10 023/1 z KIT filters out more than 95 percent of the water contained in the fuel and operates in three stages, the company said.
      In the first step, the filter medium reliably removes solid impurities from the diesel. The second filter stage works with a coalescing fleece that absorbs the finest water droplets from the fuel/water emulsion and combines them into much larger droplets. In the third filtration step, a water-repellent screen fabric ensures that the enlarged droplets do not enter the injection system. MANN+HUMMEL said it has developed this screen fabric in such a way that it is elastic and can withstand the mechanical requirements of pressure and temperature both during operation and at standstill. Bartel explains: “Thanks to its flexible design, it can effectively absorb the forces that arise and so has proven to be particularly robust, including in situations such as when the fuel freezes.”
      The seal materials of this fuel filter are resistant to standard diesel, biodiesel variants, and novel synthetic diesel fuels such as hydrogenated vegetable oils (HVO). They have the corresponding OE approvals and ensure a permanent hold as well as the complete sealing of the filter.
      Series Supplier
      link hidden, please login to view said it has already started series production of this highly efficient fuel filter for a renowned vehicle manufacturer. The filter is available on the independent automotive aftermarket in original equipment quality as a PU 10 023/1 z KIT for various Ford Ranger pickup models and complements the extensive MANN-FILTER product range. MANN+HUMMEL has been granted a patent for the disassembly handhold by the German Patent and Trademark Office as well as in other countries. Worldwide, more than 1,200 researchers and developers at MANN+HUMMEL work on pioneering solutions with the aim of creating real added value and optimally meeting customer needs, the company said.
      Bosch Mobility Aftermarket announced the re-launch of its passenger car and light duty truck battery offering, now known as the Bosch Premium Battery Program. The company said this revitalized program embraces a new name emphasizing its exclusive focus on premium batteries and includes new stock-keeping units (SKUs) for the Bosch S5 Premium Power Flooded Batteries and the Bosch S6 High Performance AGM Batteries.
      “This emphasized focus on premium batteries, with 90% market coverage, guarantees shop owners and end-users alike will confront less complexity in our battery line, while enjoying greater inventory efficiency,” said Dennis Krob, senior product manager at
      link hidden, please login to view. “We’ve been listening to customers and understand these two areas are critically important in today’s market. We’re proud to be refreshing our offerings at a premium level to meet these demands, while helping drive business and streamline operations.”
      link hidden, please login to view said it will expand its portfolio of S5 Premium Power Flooded Batteries by 13 new SKUs. These batteries boast a three-year warranty and provide dependable starting power, a long service life and reduced risk of acid leakage in newer car models with high electronic demand. The new program also includes three new SKUs for the Bosch S6 High Performance AGM Batteries. According to the company, these batteries promise a lifespan up to two times longer than conventional alternatives and provide consistent, optimal power for start-stop vehicles and models that use regenerative braking. The S6 batteries offer a warranty guaranteeing free replacement for four years after the date of purchase.
