Valvoline has been recognized for providing excellent customer service and has been ranked by Forbes on its “Best Customer Service 2025” list.
link hidden, please login to view was the top-ranked instant oil change company and placed 18th among the 300 brands on the list. The Forbes customer service list was based on surveys of 181,000 people in the United States who rated their interactions with more than 3,500 brands. Only the top 300-rated companies were included in the list. “Every year we serve millions of guests, and our goal is to deliver the very best customer service with each oil change and preventive automotive maintenance service,” said Laura Carpenter, Valvoline’s chief customer officer. “Our team members and franchise partners are focused and committed to go above and beyond for our guests each and every day. I’m proud of our franchise partners, teams and our retail service center managers who are delivering for our guests.”
link hidden, please login to view explained that customers gave the company a 4.7 out of 5-star rating* for its service. That’s based on a survey of more than 1 million Valvoline Instant Oil Change customers. The post
