      These days, many will tell you that the tuneup is dead – a vestige of a bygone era. But I say the answer is far more subjective.
      It’s true: People rarely ask for a tuneup. Once the “king” of automotive service, the process of regular adjustments to the carburetor or fuel system – as well as the ignition system – has all but fallen by the wayside. It’s all handled now by a computer. The best part is these computers, known to us as engine or powertrain control modules, do a really great job at it.
      The worst part is they do such a good job of adjusting things and keeping cars running seemingly flawlessly that many people overlook the basic maintenance that’s still required. What this means is the tuneup is far from dead. It’s more important than ever, and in many aspects the same as it always was.
      The Way it Was
      There are many reasons a tuneup was so popular back in the day. Fuel systems (namely carburetors) were inefficient and required occasional adjustment. Spark plugs wore out quickly, often needing cleaning, gap adjustment or replacement. Points wore in pre-electronic ignition systems, requiring a regular dwell adjustment and frequent replacement. Distributor caps, rotors and wires needed frequent replacement to keep ignition systems in top condition.
      All of these factors and more contributed to very noticeable drivability issues on older cars, prompting owners to get a tuneup.
      Common replacement items also included air and fuel filters, crankcase ventilation filters and positive crankcase ventilation (PCV) valves, not to mention additional services such as a valve adjustment or belt adjustment. So, how does all this stack up to today’s vehicles?
      Spark Plugs
      There’s no comparison between the plugs of yesterday and today. Modern spark plugs simply work better and last a long time, often as long as 100,000 miles. But here’s the catch: They still wear out. As they wear, the computer continuously adjusts fuel mixture and timing to maintain optimum combustion. The engine runs perfectly the whole time, but behind the scenes, more energy is required to jump the gap of the plug.
      This adds additional load to the coils, eventually causing premature coil failure. Then there’s the potential of trouble removing a plug that’s been stuck in the cylinder head for many years. Ignoring spark plugs can be a costly mistake.
      It all seems great at first, and plugs definitely don’t need replaced as often as they did in the old days. But, many manufacturers are slimming down the replacement intervals. For me, I’d rather spend a little extra and replace those plugs before the target mileage.
      Coils and Boots
      Most modern ignition systems are a coil-on-plug system. They generally work or they don’t, meaning replacing them isn’t going to improve performance. But they don’t last forever. If one has gone bad, the others won’t be far behind. And the boots between the coils and plugs? They’re equivalent to a plug wire – just shorter – and they wear out just the same. In most cases, you can’t see them. They’re hidden from view in the middle of the valve cover.
      Quite often, the spark-plug-well seals go bad, leaking oil onto the coil boots and destroying them. This is all the more reason for regular inspection, and a reason to replace valve-cover gaskets when replacing plugs, coils and boots. Valve-cover gaskets were never considered part of a tuneup. They can be now.
      Tuneups = Maintenance
      Air filters are only new for a second before they start to get dirty. Less air to an engine means less performance. The computer again adjusts the fuel mixture to compensate.
      Neglected fuel filters can overwork the fuel pump and cause it to fail prematurely.
      The mass airflow (MAF) sensor sends critical data to the computer for engine operation. Cleaning them can improve performance and prevent drivability issues.
      It’s amazing how dirty throttle bodies get.
      Oh, and PCV valves? They’re still on a lot of cars.
      Even electric vehicles will require a tuneup of sorts. Battery-management systems (BMS) have an algorithm that can cause the indicated range to be less than it actually is, depending on people’s driving and charging habits. Recalibrating the state of charge will prompt the BMS to recalculate and restore the lost range.
      The bottom line: Maintenance. That’s all a tuneup was and what it still is. And maintenance never goes out of style.
      While the premise of a vehicle with no steering wheel and no human driver is not something the motoring public is quite ready for, the case for Advanced Driver Assistance Systems (ADAS)
      is strong.
      In October, automaker Ford posted a third-quarter loss of $827 million, and said it was largely due to its self-driving tech partner Argo AI going under. That same month, J.D. Power and Associates released a study that showed consumer understanding of automated vehicles is rife with misinformation.
      On paper, one can make a pretty practical case for autonomous driving – the most obvious benefit being that it could potentially increase road safety and eliminate traffic deaths. Additional justification lies in the ability to reduce collision insurance claims and increase independence for certain populations who are currently limited in their options for safe and reliable transportation – such as the elderly and disabled.
      However, as real-world testing begins, the technology is encountering some pretty significant roadbumps, and consumer understanding of the technology isn’t belying the confidence to make the mass adoption of fully automated vehicles a realistic possibility any time soon.
      The recent J.D. Power study found 65% of consumers surveyed were unable to accurately define fully automated, self-driving vehicles. Plus, 56% of respondents incorrectly classified the driver-assist technologies available today as fully automated, self-driving technologies. The survey hints that consumers are lagging in understanding as well as preparation for higher levels of automation.
      The current system for classifying levels of automated driving was established by the Society of Automotive Engineers (SAE). Ranging from 0-5, the SAE levels run the gamut from Level 0 where the driver is fully responsible for the vehicle’s operation and supervision of the technology on the car at all times, to Level 5, which gives complete control of the vehicle to the operating system itself and requires no human supervision at all. At this time, there are no Level 3-5 autonomous vehicles on the road today, according to J.D. Power.
      Today, the most widely used safety technology on vehicles on roads today would be considered Level 2 – which would include such things as Advanced Driver Assistance Systems (ADAS) – automatic emergency braking (AEB), and Electronic Stability Control (ESC), lane assist, parking assist, driver drowsiness detection, gaze detection, etc. These technologies provide partial automation by taking over control in specific situations – such as turning a corner too fast, or coming to close to a vehicle in front of you. In 2008, ESC systems became mandated by NHTSA on all new vehicles by 2011. All automakers are currently participating in a voluntary commitment to make AEB standard on all vehicles as well.
      In a recent webinar hosted by Reason Foundation, Brookings Institution and Princeton Autonomous Vehicle Engineering, several experts on AVs shared their thoughts on the subject, hoping to correct some of the common misconceptions and inject a dose of realism into the public debates surrounding autonomous vehicle technology. One of the three speakers, Alan Kornhauser, professor, Operations Research and Financial Engineering, and faculty chair of Autonomous Vehicle Engineering at Princeton University, said he believes ADAS should be mandated.
      “ADAS is focused purely on safety,” said Kornhauser. “It’s on all the time, and it overrides drivers only to avoid getting into a crash situation. We’ve had a number of these systems in our vehicles for a long time. As long as we’re not using the brakes inappropriately, they just work the way we want. Otherwise, the system takes over and doesn’t allow you to lock your wheels. Same thing with electronic stability control. You can go around corners just fine. You go around too fast, all of a sudden, the system takes over and makes sure that you don’t lose your rear end. And maybe one of the most successful of these systems is reverse automated braking systems so that if you back up and there happens to be a child behind your car, the car stops.
      “This has enormous implication on insurance because in fact, if there is no crash, then there’s no insurance that needs to be paid out. There’s no lawyer, there’s no ambulance, there’s no medical payments that have to be paid,” Kornhauser added.
      When it comes to seeing federal or state regulations that could pave the way for more fully autonomous (i.e., driverless) cars on the road, Marc Scribner, senior transportation policy analyst at Reason Foundation, believes we aren’t quite there yet. Having consistent, published technical standards may be one of the bigger roadblocks, he said.
      “Automated vehicle regulation is not going to occur in the near term,” said Scribner. “I think the delay is, in part, due to the lack of published voluntary consensus standards that may be ripe for regulatory incorporation. But, there also seems to be generally, at least so far [in] this administration, perhaps less enthusiasm for automated driving systems than the previous two administrations. But, I do think the lack of published technical standards that could be incorporated into regulation is a hurdle. Where federal regulators are silent, states may act instead. States and locals have primary authority over vehicle operations and infrastructure management. They own the roads; they manage the roads. They license drivers, they register vehicles. All of that kind of thing goes in with the vehicles actually out there in the real world,” said Scribner.
      When available, remanufactured parts can be a great alternative for your customers, giving them the option to purchase a like-new or better product at a lower price point than the new part. With gasoline prices at multiyear highs and inflation squeezing consumers’ budgets, it’s the perfect time to talk to your customers about reman parts.
      Since 2010, MERA – The Association for Sustainable Manufacturing has been making the case for remanufactured parts, on behalf of the broader remanufacturing community across multiple industry sectors. One of the key challenges has been defining the concept. In aviation and aerospace, for example, remanufacturing is called “maintenance, repair and overhaul” (MRO). For medical devices, consumers goods and electronics, it’s known as “refurbishing.”
      With that in mind, MERA and five other trade associations from around the world have created a common definition of remanufacturing:
      Remanufacturing is a standardized industrial process by which previously sold, worn or non-functional products are returned to same-as-new, or better, condition and performance. The process is in line with specific technical specifications, including engineering, quality and testing standards. The process yields fully warranted products.
      When the definition was unveiled in September 2016, the trade associations hailed it as “a tremendous step forward in the industry’s quest to raise awareness and acceptance of remanufactured products.” To address misconceptions and points of confusion, the trade associations are highly intentional in the words that comprise their definition. Notably, the definition doesn’t include the word “used.”
      “There’s a reason for that,” explains John Chalifoux, president of MERA since its inception. “In the area of trade – particularly free-trade agreements – remanufactured goods have their own category. They’re not considered new; they’re not
      considered used.”
      Plus, the word “used” has a stigma attached to it. For some people, it’s synonymous with waste. And that’s not at all what remanufacturing is about.
      MERA is a division of the Motor & Equipment Manufacturers Association (MEMA). When
      MERA formed in 2010, it was the Motor & Equipment Remanufacturers Association. However, that changed in 2018, when MERA unveiled a new brand descriptor: MERA – the Association for Sustainable Manufacturing.
      “Our purpose really is to elevate and mainstream what our members do,” Chalifoux tells Counterman. “ … When I say ‘elevate,’ we’re trying to help the perception [of remanufacturing] catch up with the reality. And the ‘mainstream’ aspect is to give remanufacturing a better seat at the table for any discussion on the circular economy or even recycling.”
      That was the underlying thought process driving the name change in 2018. MERA’s staff drew some inspiration from Merriam-Webster’s definition of “sustainable,” which includes this description: “of, relating to or being a method of harvesting or using a resource so that the resource is not depleted or permanently damaged.”
      “That’s what our members do with cores,” Chalifoux adds. “They harvest the cores.”
      MERA offers this simple definition of sustainable manufacturing: It’s “manufacturing with reuse.”
      “It is a manufacturing process that restores original products in a factory setting, yielding goods that are like new, but better than the originals,” the MERA website explains. “The finished goods have like-new quality, they offer better value and they are better for the environment. As an eco-friendly process, sustainable manufacturing conserves materials and embodied energy, and it reduces landfill waste.”
      At AAPEX 2018 in Las Vegas, Chalifoux unveiled a new symbol to promote remanufacturing. It was the familiar recycling icon – consisting of three green arrows representing the reduce/reuse/recycle concept – along with a fourth arrow that represents remanufacturing. Now a registered trademark of MERA, the four-arrow symbol illustrates the association’s position that remanufacturing should occur before traditional recycling. In other words: Reduce, reuse, remanufacture, recycle.
      “All of this is helping us to better communicate both the quality and green associated with remanufacturing,” Chalifoux said during a press conference at AAPEX 2021. “Remanufacturing yields quality parts that are like new and delivers environmental benefits that are superior when compared to recycling. In the circular economy, the environment is better served when we reuse core materials rather than raw materials. The embodied energy, material and labor in cores are too valuable to ignore.”
      The core for a remanufactured part is completely disassembled down to individual components. All renewable components are cleaned and analyzed for failure modes, and then reassembled using a combination of new and refurbished components, resulting in a reliable finished product virtually identical to a new part.
      The great news for your customers is that some remanufacturers also address known OEM design issues, using upgraded components or processes to improve upon the OEM part. For example, CARDONE has re-engineered the power brake boosters for some Ford F-250 and F-350 models. The original design was prone to water entry, which caused a hard pedal during braking. CARDONE added a silicone seal around the shell neck – including the entire crimp area – to ensure a watertight seal and longer-lasting performance.
      It’s worth noting that Michael Cardone Jr., co-founder of CARDONE Industries, is the founding chairman of MERA. “MERA would not exist if not for Michael Cardone Jr.,” Chalifoux says. This article merely provides a snapshot of remanufacturing and the benefits of selling reman parts. For more information, visit
      link hidden, please login to view and link hidden, please login to view. The post
    • By Mighty Auto Parts
      link hidden, please login to view appeared first on link hidden, please login to view. LOW FLUID LEVEL CAUSES POWER TRANSFER UNIT FAILURE Are you accurately checking those fluid levels and recommending fluid flushes or exchanges, where applicable? Unfortunately, many service technicians fall into a pattern of just performing lubrication services requested by the customer, which is usually triggered by a service reminder light indicating that it is time for […]
      Paint scuffs, also known as paint transfer, can occur when your vehicle comes in contact with another object that transfers paint or ...
