Sean Nguyen, Pennzoil technical scientist and automotive lubricant specialist
Nguyen adds that it is vital for drivers to let the engine idle for 30 seconds to a minute before driving, especially in cold temperatures. This warm-up time ensures the oil flows effectively, protecting the engine from wear and tear during those dry starts. That, along with thinner oil weight, will provide faster oil flow to critical areas of the engine.
      Selling the Upgrade
      Bottom Line for Counter Pros
      A Dynamic Kickoff
      Judge Denise Casper dismissed the entirety of the Alliance for Automotive Innovation’s suit challenging the 2020 Massachusetts Data Access Law. The automakers’ bid to block the Massachusetts
      link hidden, please login to viewlaw has failed and the law remains in effect. The judge’s written decision is still under seal but should be made available to the public soon.   “Today’s ruling is a significant victory for the people of Massachusetts—and all Americans,” said Bill Hanvey, president and CEO, Auto Care Association. “This decision by Judge Casper ensures that car owners have the right to access their vehicle’s repair and diagnostic data, empowering them to make informed choices about maintenance and repairs. It levels the playing field, allowing independent repair shops to compete fairly, which in turn drives down costs for consumers. As car owners, we all deserve the freedom to control and manage the data that’s generated by our own vehicles. This ruling is a crucial step toward fostering greater transparency, affordability, and innovation in the automotive industry for the benefit of all Americans.”
      link hidden, please login to view said it will update its members with additional information as it becomes available.  The post
