The Engine Control Module: The Hidden Genius Behind Your Car's Performance
- ecm
- performance
- (and 2 more)
- 357 views
My Experience with AutoParts.co.ua - Highly Recommend!
By John Dow,
- auto parts
- autopartsshop
- 122 views
- 1,260 views
Unlock Peak Vehicle Performance with Premium Auto Parts: Clifford Auto Parts Delivers Quality You Can Trust
- clifford auto parts
- carpart
- (and 3 more)
- 487 views
Understanding Auto Spare Parts: The Backbone of Vehicle Maintenance
By Muhammad,
- auto parts
- automotive
- (and 3 more)
- 237 views
link hidden, please login to view Professional Series fuel pump modules in March, 2025. Fuel pump assembly application coverage includes several Audi, Toyota, Infiniti and Nissan models.
🚨 Check Engine Light Stays On
🚨 Poor Fuel Efficiency
🚨 Difficulty Starting the Car
🚨 Transmission Issues
🚨 Electrical Malfunctions
On Feb. 18, 2025, the automakers released a legislative proposal related to automotive right to repair; the views cited in this proposal represent a small fraction of the repair market and are not representative of the broader automotive aftermarket, MEMA said. The industry does appreciate automakers’ acknowledgment of the need for federal legislation to protect consumer choice in vehicle repair and looks forward to congressional consideration of the REPAIR Act.
Auto Care Association President and CEO Bill Hanvey and MEMA Aftermarket Suppliers President Paul McCarthy released the following statement:
“We’re pleased to see trade groups representing automakers finally admit what we’ve long known: congressional action is needed to ensure independent shops and aftermarket parts manufacturers can continue to offer Americans quality, affordable choices for vehicle repairs.
“That said, this latest proposal appears to be a tactic to delay and defeat pro-consumer right to repair legislation at every level. The bipartisan Right to Equitable and Professional Auto Industry Repair Act (REPAIR Act) is a straightforward approach to ensure safe and secure access to vehicle repair and maintenance data.
“The REPAIR Act, led by Congressman Neal Dunn, is the solution. Protection of consumer and fleet-owner choice ensured access to critical repair data, an established federal enforcement mechanism, and the prevention of repair monopolies is accomplished through the REPAIR Act. Without it, the aftermarket will lose the ability to not only innovate but continue to offer consumers options to keep their vehicles on the road.
