The Engine Control Module: The Hidden Genius Behind Your Car's Performance
- ecm
- performance
- (and 2 more)
- 368 views
My Experience with AutoParts.co.ua - Highly Recommend!
By John Dow,
- auto parts
- autopartsshop
- (and 1 more)
- 123 views
- 1,281 views
Unlock Peak Vehicle Performance with Premium Auto Parts: Clifford Auto Parts Delivers Quality You Can Trust
- clifford auto parts
- carpart
- (and 3 more)
- 497 views
Understanding Auto Spare Parts: The Backbone of Vehicle Maintenance
By Muhammad,
- auto parts
- automotive
- (and 3 more)
- 241 views
link hidden, please login to view. While that might sound like just another specification in a long line of upgrades, for professional parts counter pros selling to independent repair shops, it’s a moment that carries real-world impact. Understanding what’s new—and how to help shop owners explain it to their customers—could be the difference between a routine oil sale and a value-driven recommendation. First, What Is GF-7?
link hidden, please login to view. “The caveat is that GF-7B category. Some engines don’t like thin oil because they’re just not made to operate that way. You have to be careful about misapplication. “The OEMs identified that and developed a shield icon with 0W-16 label to make it easy to identify it versus 0W-20 or heavier oil,” he said.
Selling the Upgrade
Bottom Line for Counter Pros
