    • By dwil4
      Anchor Industries announced the release of additional late model Lexus and Toyota coverage. Eight new part numbers are in stock and available for immediate delivery, the company said.
      Covering over 2,300,000 applications and model years 2007-2025, these part numbers represent “excellent sales opportunities,” according to Anchor.
      All application data is available electronically on
      link hidden, please login to view, Epicor and WHI Solutions. For more details on
      link hidden, please login to view complete program availability, contact your local sales representative or call Anchor’s customer service department direct at 1-888-444-4616.
    • By abiztime
