Surface Treatment Methods for Brake Discs
Longkou lihe machinery parts(rdbrake)2025 global exhibition schedule
By abiztime,
- rdbrake
- brake disc
- (and 3 more)
- 228 views
- 234 views
2024 Automechanika Shanghai Wraps Up Successfully(RDBRAKE)
By abiztime,
- brake disc
- rdbrake
- (and 5 more)
- 253 views
- 249 views
"Supplier of the Year 2024"-Longkou lihe machinery parts Co.,Ltd
By abiztime,
- rdbrake
- longkoulihe
- (and 5 more)
- 290 views
5, Pallet
The top OEM brake disc manufacturer in China: link hidden, please login to view
In 2008, the company expanded and registered the Rongdi trademark, and the company began to go abroad.
In 2015, the company established the domestic market department and "Longzhu" brand has launched focusing on serving the domestic auto parts aftermarket. In 2021, Longzhu brand won the prize of "Most Competitive Brake Disc Brand"
With the expansion of domestic market business, the company registered Yichen trademark. In 2021, Yichen brand was honored "Annual Breakthrough Brand"
