While constant velocity (CV) joints are the most popular type of driveline joint in use today, universal or “U” joints are still in use on the driveshaft of many larger SUVs, trucks and vans. U-joints can handle a lot of torque, making them popular for these applications, but why did the CV joint rise in popularity? The question can be answered by looking at the operational aspects of a U-joint.
The basics are this: U-joints are located on the ends of a driveshaft, mounted between the driveshaft and a front and rear yoke. The front yoke attaches to the transmission and the rear yoke attaches to rear differential. As the engine moves from the effects of torque and as the suspension of a vehicle travels up and down, the angle of the driveshaft changes.
A U-joint does two things. First, it transfers the motion between the yoke(s) and driveshaft and, second, it does this at different angles, allowing for driveline movement. Here’s where the fun begins. When a yoke and the driveshaft are in perfect alignment, the velocity from one is transferred to the other at the same rate. However, when there is an angle between the two, the velocity of the driven member fluctuates continuously during rotation.
It can be hard to visualize, but the reason this happens is that as the angle of the U-joint changes, the two halves of the U-joint cross are forced to rotate on a different axis. The drive axis remains at a constant velocity, and the ends of the U-joint connected to it rotate in a consistent circular path at the same velocity.
The driven axis, however, rotates in a path which causes the distance of travel at the outer ends of the U-joint cross to increase or decrease in relation to the consistent points of the drive axis.
This effect results in the continuous fluctuation of velocity between the input and output sides of the U-joint. While the input remains at a consistent speed, the output speeds up and slows down as the points of the driven axis continuously alter between a long and short path of travel.
So, why don’t we feel that on a vehicle with a traditional driveshaft? Because there are two U-joints and the fluctuation on each end balances out, effectively allowing the driveshaft to provide a consistent output speed to the rear differential. The angle of the two joints must be the same, however, and it doesn’t take much wear in one for the angles to differ, and subsequently cause a vibration.
U-joints are known for their propensity to cause vibration, and an inherent disadvantage they have is the greater the angle of the U-joint, the greater the fluctuation in velocity. Anything over 30 degrees and the fluctuation dramatically increases.
The driveshaft I’ve described here represents the majority, but U-joints have also been used frequently in the past on the end of the front axles for a 4WD vehicle, and in the rear of independent rear suspension vehicles on the ends of short driveshafts, known as half-shafts.  Have you ever noticed how jittery an old 4WD truck feels in the front when the hubs are locked, and you turn a corner? Now that you understand how the fluctuation in velocity of a U-joint changes as the angle increases, you know why.
You may have heard of a Double-Cardan U-joint. It is basically two joints side-by side with a common link-yoke in between. This is one of the original concepts for a true CV joint, and they are often referred to as this. The advantage they have is they offer smoother operation at greater angles, and they are common on 4WD trucks, and a common upgrade for lifted trucks where the driveshaft angle is altered considerably.
The drawback to a Double-Cardan joint is they are bulky, and they can still suffer from limitations due to operating angle. The operating limitations of a U-joint ultimately brought about the popularity of the modern CV joint, but the durability of U-joints means we’ll still be seeing them in certain applications.
      Cloyes Gear & Products, Inc. (
      link hidden, please login to view) announced it is the 2024 recipient of the “Technical Training” Supplier of the Year Award from O’Reilly Auto Parts. This achievement highlights Cloyes’ commitment to excellence in the automotive aftermarket industry, the company said. The award is given annually by O’Reilly Auto Parts to companies or individuals who demonstrate exceptional quality in providing technical training to their employees and customers, often recognizing their commitment to in-depth product knowledge and effective training programs.
      “This is a testament to the dedication, expertise and passion that our team members have for
      link hidden, please login to view through effective training techniques,” said John Hanighen, CEO of Cloyes. “We are honored to have their hard work recognized by O’Reilly Auto Parts and deeply appreciate their continued support and partnership.” Technical Product Director Cody Smith also was recognized for his outstanding contributions. His innovative training videos have set a new standard for quality in the industry, earning him well-deserved acclaim, Cloyes said.
      Additionally, the Cloyes team was applauded for its successful integration of Rotomaster, the company added. Cloyes was also previously honored with the Sales Support Award in 2022 and the Content and Cataloging Award in 2020.
      Announces Asset Optimization Program Targeting Reduction of 500 Corporate Stores, 200 Independently Owned Locations and Four Distribution Centers by Mid-2025 Introduces New Fiscal 2027 Financial Objectives Targeting Approximately 7% Adjusted Operating Income Margin (1) and Approximately 2.5x Debt Leverage Ratio; Provides Preliminary 2025 Guidance Identifies Over 500-basis points of Operating Margin Expansion Opportunity Through Fiscal 2027 With Focus on Core Retail Fundamental Excellence RALEIGH, N.C.--(BUSINESS WIRE)-- Advance Auto Parts, Inc. (NYSE: AAP), a leading automotive aftermarket parts provider in North America that serves both professional installer and do-it-yourself customers, announced its financial results for the third quarter ended October 5, 2024.
      "We are pleased to have made progress on our strategic actions, including the completion of the sale of Worldpac and a comprehensive operational productivity review of our business,” said Shane O’Kelly, president and chief executive officer. “We are charting a clear path forward and introducing a new three-year financial plan, with a focus on executing core retail fundamentals to improve the productivity of all our assets and to create shareholder value."
      On November 1, 2024, the company completed its previously announced sale of Worldpac for aggregate cash consideration of approximately $1.5 billion, as adjusted for working capital and other items. Unless otherwise specified, results are presented on a continuing operations basis.
      Third Quarter 2024 Results (1,2,3,4)
      Third quarter 2024 net sales from continuing operations totaled $2.1 billion, compared with $2.2 billion in the third quarter of the prior year. Comparable store sales decreased 2.3%.
      The company's gross profit increased 11.0% to $907.9 million, or 42.3% of net sales compared with 36.9% in the third quarter of the prior year. The leverage improvement was primarily due to lapping the one-time impact in the change for inventory reserves in the prior year as well as stabilizing product costs offset by strategic pricing investments.
      The company's SG&A expenses were $907.5 million, or 42.2% of net sales. Adjusted SG&A expenses were $891.2 million, or 41.5% of net sales compared with 40.2% in the third quarter of 2023, primarily due to lower sales. The company also incurred high labor-related expenses due to wage investments in frontline team members that were partially offset by a reduction in marketing expenses.
      The company's operating income was $403.0 thousand, or zero percent of net sales. Adjusted operating income was $16.7 million, or 0.8% of net sales compared with (3.3)% in the third quarter of 2023. In addition, our operating income margin was negatively impacted by approximately 125 basis points of atypical items and headwinds in the period (such as lost revenue from Hurricane Helene and downtime from the CrowdStrike outage) that are not included in non-GAAP adjustments.
      The company's effective tax rate was (58.4)%, compared with 24.5% in the third quarter of 2023. The company's diluted loss per share for the quarter was $0.42. The company's adjusted diluted loss per share was $0.04 compared with a loss per share of $1.19 in the third quarter of 2023. The types of unusual headwinds in the quarter noted above, which are not included in the non-GAAP adjustments, negatively impacted the company's earnings per share by 34 cents.
      Net cash provided by operating activities was $81.0 million through the third quarter of 2024 versus $28.3 million of cash used in operating activities in the same period of the prior year. Free cash flow through the third quarter of 2024 was an outflow of $48.7 million compared with an outflow of $202.5 million in the same period of the prior year.
      (1)
        Adjusted Operating Income Margin is a non-GAAP measure. For a better understanding of the company’s non-GAAP adjustments, refer to the reconciliation of non-GAAP financial measures in the accompanying financial tables.
      (2)
        All comparisons are based on continuing operations for the same time period in the prior year, unless otherwise specified. The company calculates comparable store sales based on the change in store or branch sales starting once a location has been open for approximately one year and by including e-commerce sales and excluding sales fulfilled by distribution centers to independently owned Carquest locations. Acquired stores are included in the company's comparable store sales one year after acquisition. The company includes sales from relocated stores in comparable store sales from the original date of opening.
      (3)
        As reported in the company’s fourth quarter and full year 2023 earnings release, the company corrected non-material errors in certain previously reported financials. All comparisons are based on the corrected historical results as presented in the company’s prior earnings release dated February 28, 2024.
      (4)
        On August 22, 2024, the company entered into a definitive purchase agreement to sell its Worldpac Inc. business (“Worldpac”), which reflects a strategic shift in its business. The sale was completed on November 1, 2024. As a result, the company has classified the results of operations and cash flows of Worldpac as discontinued operations in its condensed consolidated statements of operations and condensed consolidated statements of cash flows for all periods presented. The related assets and liabilities associated with the discontinued operations are classified as held for sale in the condensed consolidated balance sheets.
      Capital Allocation
      On October 29, 2024, the company declared a regular cash dividend of $0.25 per share to be paid on January 24, 2025, to all common stockholders of record as of January 10, 2025.
      Full Year 2024 Guidance
      For the balance of 2024, the company is providing guidance that includes expectations for continuing operations as well as adjusted metrics that take into account non-GAAP adjustments.
      As of November 14, 2024
      ($ in millions, except per share data)
      Low
      High
      Net sales from continuing operations
      Approx. $9,000
      Comparable store sales (1)
      Approx. (1.0%)
      Adjusted operating income margin from continuing operations
      0.25
      0.75
      Adjusted diluted EPS from continuing operations
      (0.60
      0.00
      Capital expenditures
      175
      225
      Free cash flow (2)
      Approx. flat (including strategic costs)
      (1)
      (2)
        Adjusted operating income margin from continuing operations, Adjusted diluted EPS from continuing operations and Free cash flow are non-GAAP measures. For a better understanding of the company's non-GAAP adjustments, refer to the reconciliation of non-GAAP financial measures in the accompanying financial tables. The company is not able to provide a reconciliation of these forward-looking non-GAAP measures because it is unable to predict with reasonable accuracy the value of certain adjustments and as a result, the comparable GAAP measures are unavailable without unreasonable efforts.
      Strategic Priorities and Financial Objectives
      The company is executing a strategic plan to improve business performance with a focus on core retail improvements. The company has identified opportunities that it believes can improve adjusted operating income margin by more than 500-basis points through fiscal 2027. This strategic plan is anchored on three pillars outlined below to put the company on the path to deliver consistent profitable growth.
      Store operations Reduction in U.S. asset footprint - closing 523 Advance corporate stores, exiting 204 independent locations, and closing four distribution centers. Standardization of store operating model and improving labor productivity. Acceleration in pace of new store openings. Merchandising excellence Strategic sourcing to improve first costs and bring parts to market faster. Assortment management to enhance availability of parts. Pricing and promotions management to improve gross margin. Supply chain Consolidation of distribution centers to operate 13 large facilities by 2026. Opening of 60 market hub locations by mid-2027. Optimization of transportation routes and freight to lower costs and improve productivity. Financial Objectives (Advance Auto Parts continuing operations)
      The company is introducing new fiscal 2027 financial objectives and providing preliminary fiscal 2025 guidance.
      Preliminary FY 2025 Guidance (53 weeks)
      FY 2027 Objectives
      Net sales ($ in millions)
      $8,400 - $8,600
      Approx. $9,000
      Comparable sales growth
      0.50% - 1.50%
      Positive low-single-digit %
      New store growth
      30 new stores
      50 to 70 new stores
      Adjusted operating income margin (1)
      2.00% - 3.00%
      Approx. 7.00%
      Leverage Ratio (Adj. debt/ Adj. EBITDAR) (1)
      3.0x – 4.0x
      Approx. 2.5x
      (1)
        Adjusted operating income margin is based on performance of Advance continuing operations and excludes intercompany margins related to Worldpac. Adjusted operating income margin from continuing operations and Adjusted Debt to Adjusted EBITDAR ratio (“leverage ratio”) are non-GAAP measures. For a better understanding of the company’s non-GAAP adjustments, refer to the reconciliation of non-GAAP financial measures in the accompanying financial tables. The company is not able to provide a reconciliation of these forward-looking non-GAAP measures because it is unable to predict with reasonable accuracy the value of certain adjustments and as a result, the comparable GAAP measures are unavailable without unreasonable efforts.
      Investor Conference Call
      The company will detail its results for the third quarter ended October 5, 2024, via a webcast scheduled to begin at 8 a.m. Eastern Time on Thursday, November 14, 2024. The webcast will be accessible via the Investor Relations page of the company's website (
      link hidden, please login to view). To join by phone, please pre-register online for dial-in and passcode information. Upon registering, participants will receive a confirmation with call details and a registrant ID. While registration is open through the live call, the company suggests registering a day in advance or at minimum 10 minutes before the start of the call. A replay of the conference call will be available on the company's Investor Relations website for one year.
      Advance Auto Parts, Inc. is a leading automotive aftermarket parts provider that serves both professional installers and do-it-yourself customers. As of October 5, 2024, Advance operated 4,781 stores primarily within the United States, with additional locations in Canada, Puerto Rico and the U.S. Virgin Islands. The company also served 1,125 independently owned Carquest branded stores across these locations in addition to Mexico and various Caribbean islands. Additional information about Advance, including employment opportunities, customer services and online shopping for parts, accessories and other offerings can be found at
      Certain statements herein are “forward-looking statements” within the meaning of the Private Securities Litigation Reform Act of 1995. Forward-looking statements are usually identifiable by words such as “anticipate,” “believe,” “could,” “estimate,” “expect,” “forecast, “guidance,” “intend,” “likely,” “may,” “plan,” “position,” “possible,” “potential,” “probable,” “project,” “should,” “strategy,” “target,” “will,” or similar language. All statements other than statements of historical fact are forward-looking statements, including, but not limited to, statements about the company’s strategic initiatives, restructuring and asset optimization plans, financial objectives, operational plans and objectives, statements about the sale of the company’s Worldpac business, including statements regarding the benefits of the sale and use of proceeds therefrom, statements regarding expectations for economic conditions, future business and financial performance, as well as statements regarding underlying assumptions related thereto. Forward-looking statements reflect the company’s views based on historical results, current information and assumptions related to future developments. Except as may be required by law, the company undertakes no obligation to update any forward-looking statements made herein. Forward-looking statements are subject to a number of risks and uncertainties that could cause actual results to differ materially from those projected or implied by the forward-looking statements. They include, among others, the company’s ability to hire, train and retain qualified employees, the timing and implementation of strategic initiatives, risks associated with the company’s restructuring and asset optimization plans, deterioration of general macroeconomic conditions, geopolitical factors, the highly competitive nature of the industry, demand for the company’s products and services, ongoing risks associated with the disposition of Worldpac, the company’s ability to maintain credit ratings, risks relating to the impairment of assets, including intangible assets such as goodwill, access to financing on favorable terms, complexities in the company’s inventory and supply chain and challenges with transforming and growing its business. Please refer to “Item 1A. Risk Factors” of the company’s most recent Annual Report on Form 10-K filed with the Securities and Exchange Commission (“SEC”), as updated by the company’s subsequent filings with the SEC, for a description of these and other risks and uncertainties that could cause actual results to differ materially from those projected or implied by the forward-looking statements.
      Advance Auto Parts, Inc. and Subsidiaries
      Condensed Consolidated Balance Sheets
      (In thousands) (unaudited)
        October 5, 2024
      December 30, 2023
      Assets
      Current assets:
      Cash and cash equivalents
      464,492
      488,049
      Receivables, net
      668,937
      609,528
      Inventories, net
      4,042,200
      3,893,569
      Other current assets
      180,448
      180,402
      Current assets held for sale
      2,137,690
      1,205,473
      Total current assets
      7,493,767
      6,377,021
      Property and equipment, net
      1,479,738
      1,555,985
      Operating lease right-of-use assets
      2,399,630
      2,347,073
      Goodwill
      600,182
      601,159
      Other intangible assets, net
      409,501
      419,161
      Other noncurrent assets
      85,366
      85,988
      Noncurrent assets held for sale
      889,939
      Total assets
      12,468,184
      12,276,326
      Liabilities and Stockholders' Equity
      Current liabilities:
      Accounts payable
      3,498,460
      3,526,079
      Accrued expenses
      641,914
      616,067
      Other current liabilities
      458,343
      396,408
      Current liabilities held for sale
      994,824
      768,851
      Total current liabilities
      5,593,541
      5,307,405
      Long-term debt
      1,788,513
      1,786,361
      Noncurrent operating lease liabilities
      2,018,383
      2,039,908
      Deferred income taxes
      380,118
      355,635
      Other long-term liabilities
      89,949
      83,538
      Noncurrent liabilities held for sale
      183,751
      Total stockholders' equity
      2,597,680
      2,519,728
      Total liabilities and stockholders’ equity
      12,468,184
      12,276,326
      Condensed Consolidated Statements of Operations
      (In thousands, except per share data) (unaudited)
        Twelve Weeks Ended
      Forty Weeks Ended
        October 5, 2024
      October 7, 2023 (1)
      October 5, 2024
      October 7, 2023 (1)
      Net sales
      2,147,991
      2,218,205
      7,098,302
      7,194,670
      Cost of sales, including purchasing and warehousing costs
      1,240,093
      1,400,638
      4,036,898
      4,154,190
      Gross profit
      907,898
      817,567
      3,061,404
      3,040,480
      Selling, general and administrative expenses
      907,495
      896,145
      2,954,707
      2,959,238
      Operating income (loss)
      403
      (78,578
      106,697
      81,242
      Other, net:
      Interest expense
      (18,805
      (19,375
      (62,127
      (69,948
      Other income (expense), net
      2,393
      (305
      12,769
      232
      Total other, net
      (16,412
      (19,680
      (49,358
      (69,716
      (Loss) income before provision for income taxes
      (16,009
      (98,258
      57,339
      11,526
      Provision for income taxes
      9,354
      (24,072
      34,763
      6,360
      Net (loss) income from continuing operations
      (25,363
      (74,186
      22,576
      5,166
      Net income from discontinued operations
      19,349
      12,149
      56,413
      59,696
      Net (loss) income
      (6,014
      (62,037
      78,989
      64,862
      Basic (loss) earnings per common share from continuing operations
      (0.42
      (1.25
      0.38
      0.09
      Basic earnings per common share from discontinued operations
      0.32
      0.20
      0.95
      1.00
      (0.10
      (1.05
      1.33
      1.09
      Basic weighted-average common shares outstanding
      59,684
      59,474
      59,618
      59,411
      Diluted (loss) earnings per common share from continuing operations
      (0.42
      (1.24
      0.38
      0.09
      Diluted earnings per common share from discontinued operations
      0.32
      0.20
      0.94
      1.00
      (0.10
      (1.04
      1.32
      1.09
      Diluted weighted-average common shares outstanding
      59,902
      59,630
      59,878
      59,588
      (1)
        The condensed consolidated statement of operations for the twelve and forty weeks ended October 7, 2023, reflects the correction of non-material errors the company discovered in previously reported results.
      Condensed Consolidated Statements of Cash Flows
        Forty Weeks Ended
        October 5, 2024
      October 7, 2023
      Cash flows from operating activities:
      Net income
      78,989
      64,862
      56,413
      59,696
      Net income from continuing operations
      22,576
      5,166
      Adjustments to reconcile net income to net cash used in operating activities:
      Depreciation and amortization
      217,197
      206,658
      Share-based compensation
      33,810
      33,777
      (Gain) Loss on sale and impairment of long-lived assets
      (14,273
      1,886
      Provision for deferred income taxes
      24,289
      (27,811
      Other, net
      2,986
      2,436
      Net change in:
      Receivables, net
      (60,383
      (161,629
      Inventories, net
      (152,229
      (110,871
      Accounts payable
      (25,225
      (77,336
      Accrued expenses
      30,794
      171,117
      Other assets and liabilities, net
      1,477
      (71,707
      Net cash provided by (used in) operating activities from continuing operations
      81,019
      (28,314
      Net cash provided by operating activities from discontinued operations
      76,917
      57,148
      157,936
      28,834
      Cash flows from investing activities:
      Purchases of property and equipment
      (129,714
      (174,186
      Proceeds from sales of property and equipment
      13,232
      2,001
      Net cash used in investing activities of continuing operations
      (116,482
      (172,185
      Net cash used in investing activities of discontinued operations
      (7,988
      (13,015
      (124,470
      (185,200
      Cash flows from financing activities:
      Borrowings under credit facilities
      4,805,000
      Payments on credit facilities
      (4,990,000
      Borrowings on senior unsecured notes
      599,571
      Dividends paid
      (44,882
      (194,322
      Purchases of noncontrolling interests
      (9,101
      Proceeds from the issuance of common stock
      2,995
      3,045
      Repurchases of common stock
      (5,601
      (14,237
      Other, net
      (1,143
      (5,010
      Net cash (used in) provided by financing activities
      (57,732
      204,047
        Forty Weeks Ended
        October 5, 2024
      October 7, 2023
      Effect of exchange rate changes on cash
      11,766
      (1,932
      Net (decrease) increase in cash and cash equivalents
      (12,500
      45,749
      Cash and cash equivalents, beginning of period
      503,471
      270,805
      Cash and cash equivalents, end of period
      490,971
      316,554
      Summary of cash and cash equivalents:
      Cash and cash equivalents of continuing operations, end of period
      464,492
      308,804
      Cash and cash equivalents of discontinued operations, end of period
      26,479
      7,750
      Cash and cash equivalents , end of period
      490,971
      316,554
      (1)
        The condensed consolidated statement of cash flows for the forty weeks ended October 7, 2023, reflects the correction of non-material errors the company discovered in previously reported results.
      Restatement of Previously Issued Financial Statements
      During the fiscal year ended December 30, 2023, the company identified errors primarily impacting cost of sales, selling, general and administrative costs and other income/expenses, net, incurred in prior years but not previously recognized. The company evaluated the errors and determined that the related impacts were not material to the previously issued consolidated financial statements for any prior period. A summary of the corrections to the impacted financial statement line items in the company's Condensed Consolidated Statement of Operations for the twelve and forty weeks ended October 7, 2023, and the company's Condensed Consolidated Statement of Cash Flows for the forty weeks ended October 7, 2023, included in the company's previously filed Annual Report on Form 10-K are presented below:
      October 7, 2023
        Twelve Weeks Ended
      (in thousands)
        As Previously Reported
      Adjustments
      As Corrected
      Discontinued Operations
      As Corrected, after Discontinued Operations
      Cost of sales
      1,732,420
      16,379
      1,748,799
      348,161
      1,400,638
      Gross profit
      986,659
      (16,379
      970,280
      152,713
      817,567
      1,030,355
      878
      1,031,233
      135,088
      896,145
      Operating (loss) income
      (43,696
      (17,257
      (60,953
      17,625
      (78,578
      (Loss) Income before provision for income taxes
      (64,319
      (17,257
      (81,576
      16,682
      (98,258
      (15,686
      (3,853
      (19,539
      4,533
      (24,072
      Net (loss) income
      (48,633
      (13,404
      (62,037
      12,149
      (74,186
      Basic (loss) earnings per share
      (0.82
      (0.23
      (1.05
      0.20
      (1.25
      (0.82
      (0.22
      (1.04
      0.20
      (1.24
      October 7, 2023
        Forty Weeks Ended
      (in thousands)
      Adjustments
      As Corrected
      Cost of sales
      5,220,200
      29,877
      5,250,077
      1,095,887
      4,154,190
      Gross profit
      3,602,538
      (29,877
      3,572,661
      532,181
      3,040,480
      3,407,445
      2,272
      3,409,717
      450,479
      2,959,238
      195,093
      (32,149
      162,944
      81,702
      81,242
      Income (loss) before provision for income taxes
      124,894
      (32,149
      92,745
      81,219
      11,526
      34,649
      (6,766
      27,883
      21,523
      6,360
      Net income (loss)
      90,245
      (25,383
      64,862
      59,696
      5,166
      Basic earnings (loss) per share
      1.52
      (0.43
      1.09
      1.00
      0.09
      Diluted earnings (loss) per common share
      1.51
      (0.42
      1.09
      1.00
      0.09
      Forty Weeks Ended October 7, 2023
      (in thousands)
      Adjustments
      As Corrected
      Net income
      90,245
      (25,383
      64,862
      59,696
      5,166
      (33,059
      5,248
      (27,811
      (27,811
      Other, net
      1,499
      937
      2,436
      2,436
      Net change in:
      Receivables, net
      (170,371
      (9,519
      (179,890
      (18,261
      (161,629
      Inventories, net
      (41,025
      15,442
      (25,583
      85,288
      (110,871
      Accounts payable
      (191,871
      28,500
      (163,371
      (86,035
      (77,336
      Accrued expenses
      145,704
      21,521
      167,225
      (3,892
      171,117
      (45,015
      (38,316
      (83,331
      (11,624
      (71,707
      30,404
      (1,570
      28,834
      57,148
      (28,314
      Other, net (1)
      (4,073
      (937
      (5,010
      (5,010
      Net cash provided by financing activities
      204,984
      (937
      204,047
      (1,942
      10
      (1,932
      Net increase (decrease) in cash and cash equivalents
      48,246
      (2,497
      45,749
      269,282
      1,523
      270,805
      50,670
      220,135
      317,528
      (974
      316,554
      7,750
      308,804
      (1)
        The summary of corrections table above inadvertently omitted disclosure for proceeds from the issuance of common stock as follows: $3.0 million as previously reported, $0 adjustments and $3.0 million as corrected.
      Reconciliation of Non-GAAP Financial Measures
      The company's financial results include certain financial measures not derived in accordance with accounting principles generally accepted in the United States of America (“GAAP”). Non-GAAP financial measures, including Adjusted Net income, Adjusted EPS, Adjusted SG&A Margin, and Adjusted Operating Income, should not be used as a substitute for GAAP financial measures, or considered in isolation, for the purpose of analyzing our operating performance, financial position or cash flows.
      The company has presented these non-GAAP financial measures as the company believes that the presentation of the financial results that exclude (1) transformation expenses under the company’s turnaround plan, (2) other significant costs and (3) nonrecurring tax expense are useful and indicative of the company's base operations because the expenses vary from period to period in terms of size, nature and significance. These measures assist in comparing the company’s current operating results with past periods and with the operational performance of other companies in the industry. The disclosure of these measures allows investors to evaluate the company’s performance using the same measures management uses in developing internal budgets and forecasts and in evaluating management’s compensation. Included below is a description of the expenses the company has determined are not normal, recurring cash operating expenses necessary to operate the company’s business and the rationale for why providing these measures is useful to investors as a supplement to the GAAP measures.
      Transformation Expenses — Costs incurred in connection with the company's turnaround plan and specific transformative activities related to asset optimization that the company does not view to be normal cash operating expenses. These expenses primarily include:
      Distribution network optimization — Costs primarily relating to the conversion of the stores and DCs to market hubs, including temporary labor, team member severance, long-lived asset write off charges and incremental depreciation, as a result of accelerating depreciation of long-lived assets over a shorter useful life as a result of the optimization plans. Third-party professional services — Costs relating to non-recurring services rendered by third-party vendors assisting with the turnaround initiatives. Other Expenses — Costs incurred by the company that are not viewed as normal cash operating expenses and vary from period to period in terms of size, nature, and significance, including but not limited to executive turnover and incremental costs associated with remediating the company's previously-disclosed material weaknesses in internal control over financial reporting.
      Nonrecurring Tax Expense — Income tax incurred by the company from the book to tax basis difference in the Worldpac Canada stock directly resulting from the sale of Worldpac.
      The following tables include reconciliations of this information to the most comparable GAAP measures:
      Reconciliation of Adjusted Net Income and Adjusted EPS:
        Twelve Weeks Ended
      Forty Weeks Ended
      (in thousands, except per share data)
        October 5, 2024
      October 7, 2023
      October 5, 2024
      October 7, 2023
      Net (loss) income from continuing operations (GAAP)
      (25,363
      (74,186
      22,576
      5,166
      adjustments:
      Transformation expenses:
      8,909
      13,943
      3,582
      50
      5,301
      320
      Other charges:
      Executive turnover
      87
      3,799
      1,561
      5,360
      Material weakness remediation
      1,293
      429
      3,649
      429
      Other significant costs (1)
      2,394
      3,491
      Provision for income taxes on adjustments (2)
      (4,066
      (1,070
      (6,986
      (1,527
      Nonrecurring tax expense
      10,000
      10,000
      Adjusted net (loss) income (Non-GAAP)
      (3,164
      (70,978
      53,535
      9,748
      Diluted (loss) earnings per share from continuing operations (GAAP)
      (0.42
      (1.24
      0.38
      0.09
      Adjustments, net of tax
      0.38
      0.05
      0.52
      0.08
      Adjusted EPS (Non-GAAP)
      (0.04
      (1.19
      0.90
      0.17
        (1)
        During the twelve and forty weeks ended October 5, 2024, the Company recorded expense of $2.4 million and $3.5 million for costs incurred following a cybersecurity incident that occurred over these periods.
      (2)
        The income tax impact of non-GAAP adjustments is calculated using the estimated tax rate in effect for the respective non-GAAP adjustments.
      Reconciliation of Adjusted Selling, General and Administrative Expenses
        Twelve Weeks Ended
      Forty Weeks Ended
      (in thousands)
        October 5, 2024
      October 7, 2023
      October 5, 2024
      October 7, 2023
      SG&A (GAAP)
      907,495
      896,145
      2,954,707
      2,959,238
      SG&A adjustments
      16,265
      4,278
      27,945
      6,109
      Adjusted SG&A (Non-GAAP)
      891,230
      891,867
      2,926,762
      2,953,129
      Reconciliation of Adjusted Operating Income:
        Twelve Weeks Ended
      Forty Weeks Ended
      (in thousands)
        October 5, 2024
      October 7, 2023
      October 5, 2024
      October 7, 2023
      Operating income (GAAP)
      403
      (78,578
      106,697
      81,242
      SG&A adjustments
      16,265
      4,278
      27,945
      6,109
      Adjusted operating income (Non-GAAP)
      16,668
      (74,300
      134,642
      87,351
      NOTE:
        Adjusted SG&A, Adjusted SG&A as a percentage of Net sales, Adjusted operating income and Adjusted operating income margin (calculated by dividing Adjusted operating income by Net sales) are non-GAAP measures. Management believes these non-GAAP measures are important metrics in assessing the overall performance of the business and utilizes these metrics in its ongoing reporting. On that basis, management believes it is useful to provide these metrics to investors and prospective investors to evaluate the company’s operating performance across periods adjusting for these items (refer to the reconciliations of non-GAAP adjustments above). These non-GAAP measures might not be calculated in the same manner as, and thus might not be comparable to, similarly titled measures reported by other companies. Non-GAAP measures should not be used by investors or third parties as the sole basis for formulating investment decisions, as they may exclude a number of important cash and non-cash recurring items.
      Reconciliation of Free Cash Flow: (1)
        Forty Weeks Ended
      (in thousands)
        October 5, 2024
      October 7, 2023
      Cash flows provided by operating activities of continuing operations
      81,019
      (28,314
      (129,714
      (174,186
      Free cash flow
      (48,695
      (202,500
      Adjusted Debt to Adjusted EBITDAR: (1)
        Four Quarters Ended
      (In thousands, except adjusted debt to adjusted EBITDAR ratio)
        October 5, 2024
      December 30, 2023
      Total GAAP debt
      1,788,513
      1,786,361
      Add: Operating lease liabilities
      2,711,578
      2,660,827
      Adjusted debt
      4,500,091
      4,447,188
      GAAP Net income
      50,819
      29,735
      309,566
      306,454
      Interest expense
      80,559
      88,055
      Other expense, net
      (16,174
      (5,525
      23,843
      2,112
      Rent expense
      638,232
      613,859
      46,557
      45,647
      Other charges (2)
      40,091
      12,419
      Transformation related charges
      27,131
      29,719
      Adjusted EBITDAR
      1,200,624
      1,122,475
      3.7
      4.0
      (1)
        The four quarters ended October 5, 2024, includes the correction of non-material errors the company discovered in previously reported results.
      (2)
        The adjustments to the four quarters ended October 5, 2024, and December 30, 2023, include expenses associated with the company's material weakness remediation efforts and executive turnover.
      NOTE:
        Management believes its Adjusted Debt to Adjusted EBITDAR ratio (“leverage ratio”) is a key financial metric for debt securities, as reviewed by rating agencies, and believes its debt levels are best analyzed using this measure. The company’s goal is to maintain an investment grade rating. The company's credit rating directly impacts the interest rates on borrowings under its existing credit facility and could impact the company's ability to obtain additional funding. If the company was unable to maintain its investment grade rating, this could negatively impact future performance and limit growth opportunities. Similar measures are utilized in the calculation of the financial covenants and ratios contained in the company's financing arrangements. The leverage ratio calculated by the company is a non-GAAP measure and should not be considered a substitute for debt to net earnings, as determined in accordance with GAAP. The company adjusts the calculation to remove rent expense and to add back the company’s existing operating lease liabilities related to their right-of-use assets to provide a more meaningful comparison with the company’s peers and to account for differences in debt structures and leasing arrangements. The company’s calculation of its leverage ratio may not be calculated in the same manner as other companies, and thus may not be comparable to similarly titled measures used by other companies.
      Store Information
      During the forty weeks ended October 5, 2024, 23 stores were opened and 29 were closed, resulting in a total of 4,781 stores as of October 5, 2024, compared with a total of 4,786 stores as of December 30, 2023.
      The below table summarizes the changes in the number of company-operated stores during the twelve and forty weeks ended October 5, 2024:
      Twelve Weeks Ended
      AAP
      CARQUEST
      Total
      July 15, 2024
      4,484
      292
      4,776
      New
      9
      9
      Closed
      (2
      (2
      (4
      Converted
      1
      (1
      October 5, 2024
      4,492
      289
      4,781
      Forty Weeks Ended
      AAP
      CARQUEST
      Total
      December 30, 2023
      4,484
      302
      4,786
      New
      23
      23
      Closed
      (17
      (12
      (29
      Converted
      2
      (1
      1
      October 5, 2024
      4,492
      289
      4,781
      Motion technology provider
      link hidden, please login to view announced it entered into a partnership with ATSG to become its primary sponsor. Through this agreement, Schaeffler will provide ongoing technical education support to the members of ATSG, which has offered technical support and repair information for transmission technicians for almost 40 years. Through its LuK brand, Schaeffler’s partnership with ATSG will “bring significant educational benefits to technicians in the aftermarket transmission repair industry,” the company said. Schaeffler added it will deliver technical educational content to ATSG members via in-person and online training events focused on trouble shooting and repair best practices.
      “Having the opportunity to partner with ATSG demonstrates our commitment to providing both innovation and education to the aftermarket,” said Rob Steinmetz, product manager, Schaeffler. “As vehicles continue to become more complex, Schaeffler strives to support repair technicians with the resources they need to get the job done. We are thrilled to partner with ATSG and look forward to supporting its members.”
      Reed Trueblood, managing director of ATSG, added: “We are eagerly anticipating the value and important resources this partnership will bring to technicians; Schaeffer’s dedication to excellence aligns with ATSG’s vision of driving innovation and empowering our customers with cutting-edge solutions.”
      Throughout 2024 and 2025, Schaeffler and ATSG will host a series of training events, offering a range of opportunities for technicians to connect and learn. To sign up for these events and learn more about this partnership, visit
      link hidden, please login to view.  The post
      The Office of the United States Trade Representative has released a four-year review of the Section 301 tariffs on imports from China.
      link hidden, please login to view link hidden, please login to view link hidden, please login to view According to the report, the USTR has recommended that the products from China currently subject to Section 301 tariffs should remain tariffed.
      Modifications have been proposed to add or increase tariffs for certain products in strategic sectors.
      link hidden, please login to view Bill Hanvey, Auto Care Association president and CEO, reacted to the USTR four-year review of Section 301 China tariffs.
      “We commend the Biden Administration and the USTR for their thorough review of the Section 301 China tariffs that were implemented in 2018 as a way to address China’s unfair trade practices,” said Hanvey. “We applaud our members’ efforts in reducing their reliance on sourcing from China and investing in resilient U.S. supply chains. However, we want to reiterate that tariffs continue to negatively impact our members and the automotive aftermarket industry. Many products lack manufacturing alternatives outside of China due to infrastructure issues, significant investments in tooling and the knowledge to produce a high-quality safety product.
      “We do not believe the Section 301 tariffs have forced China to address their technology transfer-related practices. Additionally, tariffs are not paid for by China; they are passed on to the final consumer, drive up consumer prices, and disrupt vehicle maintenance and repair schedules.
      “As part of the USTR’s recommendations, we urge the USTR to establish a comprehensive and transparent exclusion process that encompasses all products while renewing the existing exclusions that are set to expire at the end of May. We eagerly anticipate ongoing collaboration to uphold fair trade practices and to safeguard the interests of American workers and businesses,” Hanvey said.
      You can read
      link hidden, please login to view here. The post
